Cloud service in south africa?
Is the access to the cloud available in south africa and if so how to connect?
Yes, most Particle devices can be used in South Africa.
If you are using the Boron, the exceptions are the Boron LTE models: BRN402, BRN404, and BRN404X, which cannot be used in South Africa.
The 2G/3G Boron models BRN310 and BRN314 can be used.
Make sure you follow the normal setup process to activate the SIM.
Morning Rick
Thanks very much. Apologies but I haven’t had any experience with Particle products!
Please send me a link or how I can get documentation on the BRN310 and BRN314.
Secondly is there a cost to using them to connect to the cloud?
Regards
Mike
