CLI updated automatically now cannot find 'semver' I'm in Windows 10 using workbench- cannot figure out how to run the 'sudo npm...' commands that fixed for others. No plans to run in linux
error.log:
2020/11/16 04:27:53 Updating CLI…
2020/11/16 04:28:06 no plugins to update.
2020/11/16 04:28:06 Time since last update 13.2589363s, update in background
2020/11/16 04:28:25 Time since last update 31.5669023s, update in block
2020/11/16 04:28:29 Time since last update 35.6709238s, update in background
2020/11/16 04:52:30 Time since last update 24m36.8248024s, update in block
2020/11/16 04:52:31 Time since last update 24m37.429847s, update in background
2020/11/16 04:52:50 Time since last update 24m56.3686433s, update in block
2020/11/16 04:52:51 Time since last update 24m57.7826613s, update in background
2020/11/16 05:02:21 Time since last update 34m27.9218389s, update in block
2020/11/16 05:02:23 Time since last update 34m29.508885s, update in background
2020/11/16 15:27:20 Time since last update 10h59m26.4681055s, update in block
2020/11/16 15:27:28 Time since last update 10h59m34.6205848s, update in background
2020/11/16 15:27:28 Time since last update 10h59m34.6385698s, update in block
2020/11/16 15:27:28 Time since last update 10h59m34.6395712s, update in background
2020/11/16 15:27:28 Manifest version 1.1.0-12d6799, Installed version 1.1.0-12d6799
2020/11/16 15:27:28 Updating CLI…
2020/11/16 15:32:23 Time since last update 4m55.4514379s, update in block
2020/11/16 20:32:23 internal/modules/cjs/loader.js:985
throw err;
Error: Cannot find module ‘semver’
Require stack:
  • C:\Users\Dave\AppData\Local\particle\node_modules\particle-cli\dist\lib\has-supported-node.js
  • C:\Users\Dave\AppData\Local\particle\node_modules\particle-cli\dist\index.js
  • C:\Users\Dave\AppData\Local\particle[eval]
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:982:15)
    at Function.Module._load (internal/modules/cjs/loader.js:864:27)
    at Module.require (internal/modules/cjs/loader.js:1044:19)
    at require (internal/modules/cjs/helpers.js:77:18)
    at Object. (C:\Users\Dave\AppData\Local\particle\node_modules\particle-cli\dist\lib\has-supported-node.js:5:16)
    at Module._compile (internal/modules/cjs/loader.js:1158:30)
    at Object.Module._extensions…js (internal/modules/cjs/loader.js:1178:10)
    at Module.load (internal/modules/cjs/loader.js:1002:32)
    at Function.Module._load (internal/modules/cjs/loader.js:901:14)
2020/11/16 15:32:23 Time since last update 4m55.5654388s, update in background
2020/11/16 15:34:08 Time since last update 6m39.8673398s, update in block
UPDATE: I totally uninstalled Particle CLI and reinstalled it with fresh download of ParticleWorkbenchInstaller.exe and it works now… Just reinstalling over existing did not do it.
glad you got things working again. sorry for the bumps. in case it's helpful, just wanted to point out we have manual reset instructions over here:
