hi there
if you installed your CLI using our installer / install script (described here) or use Workbench, read on
occasionally, the CLI will get itself into a bad state and the only fix is to reinstall it. here’s how you do that:
open the directory containing the CLI’s files:
- macOS / Linux:
~/.particle - Windows:
C:\Users\<your username>\AppData\Local\particle
- macOS / Linux:
delete the following files and directories if available:
.npm-cacheautoupdateerror.log-
node-v8.15.0-<os>-<cpu>
(e.g.node-v8.15.0-windows-x64,node-v8.15.0-darwin-x64,node-v8.15.0-linux-x64) node_modulespackage-lock.jsonplugin-cache.jsonprofile.jsontmp
update the CLI:
if Workbench:
- run the
Particle: Update CLIcommand
if stand-alone CLI
- open a terminal (powershell, cmd.exe, bash, zsh, etc)
- run
particle update-cliand wait for the operation to complete (might take a bit)
- run the
once that completes, the CLI should be in a better state - you can confirm by running the particle usb list and particle serial inspect CLI commands. in Workbench, run Particle: Launch CLI and type the aforementioned commands into the terminal pane that launches.
if the output includes any mention of missing modules / dependencies, then the reset failed - please report the issue as described here.
