Circuit Board Identification for Photon
Hi everyone!
I have a client that is using a Particle Photon device to control their entry and exit doors to their facility. Long story short, the client wants to add two more of these devices in his office; however, the person that originally handled the hardware is no longer around. I am hoping someone can assist me with identifying the type of circuit board in use. Below is a picture of the circuit board in question. The client has a few spare Photons around and also has someone that is handling the programming (the original programmer actually). The problem is I have no idea where this circuit board came from or how to go about obtaining one (I am afraid it may be a one-off design?). Thank you for your help everyone !
EDIT: I did remove the PCB to check the back for any identification markings but unfortunately there is nothing.
Unfortunately; that’s a DIY circuit board, possibly etched by hand since it appears to be a single layer board. I’m assuming bare copper on the bottom?
It should be trivial to recreate as it’s likely something like 24/12V in and a regulator to feed the Particle device 5V (circuit below the photon) it appears a MosFET is driving the relay.
PCB’s are dirt cheap these days and a competent EE can knock that out for you in two days + update it to support the new Photon 2 devices.
Hi @vwco11 -
I would be happy to see whether I can assist. Would it be possible to remove the board and send a photo of the bottom side? If you prefer you can send me a direct message.
As @no1089 mentioned, this seems to be a custom PCB so there will be cost to redesign, based on the complexity of the board. Fortunately it seems no to be very complex :slight_smile:
Looking forward to your response.
Regards
Friedl
Thanks for the responses everyone! @no1089, I was afraid this was going to be the case :slight_smile: I am 90% sure the bottom was bare copper when I looked at it, but I will confirm.
@friedl_1977 , I will remove the board and take another pic of the bottom later today and will send you a DM.
Thanks again everyone!
I apologize but I can't figure out how to send a DM (I may be restricted since I just joined ?). Anyways, here are a few more pictures including some pictures of the 6 wire connector cable. I also included pictures of a separate box that was providing power to the circuit board.
The Photon controls/manages the following components:
  1. Maglock for the door
  2. Motion sensor (disables the maglock when someone walks under it)
  3. Crash bar sensor (disables the mag lock when someone pushes on the door handle/bar)
  4. Push button exit (I believe this is required by fire code as an emergency bypass of some sort. It's a green button that says "push to exit").
Regarding the enclosure box, I believe I have found that here: https://www.mouser.com/ProductDetail/Hammond-Manufacturing/1591CFLBK?qs=MwrRT%252BN4KLZZRY8XVpjhag%3D%3D
Here are some pics. thanks so much for your help!
Bottom of PCB
Connector cable 1
EDIT: the forum will only let me embed two items, so I will add more pics in a separate post
Here are some additional pictures
Connector cable 2
Power Supply
Here are the final 2 pictures of the other end of the connector cable
Hi @vwco11 -
Thanks. I sent you a DM, let me know if you have trouble finding it :wink:
Regards
Friedl
