Changed Soft AP name, need to reset
I was tinkering with changing the soft AP name, and didn’t realize the Photon app uses that name to identify when connected to a Photon.
I changed it via a System.set(SYSTEM_CONFIG_SOFTAP_PREFIX call, and would like to change it back so I can connect to wifi.
I attempted to use DFU mode to change it back to “Photon”, as described here: Change Photon SSID
However, that doesn’t seem to do it. DFU-util gives me some trouble, so I’m not sure it’s even working. The Photon is blinking yellow when trying to run this, but the error seems like it’s not actually in DFU mode. I tried to reset into safe mode after, which theoretically would not run my code that changes the soft AP prefix, but it’s still set to my own prefix.
Here’s a run of dfu-util and and a hexdump of the ssid info I’m using (which should set it back to Photon). Thanks!
[ben@Cray-1:~]$ dfu-util -l
dfu-util 0.8
Found Runtime: [05ac:8290] ver=0114, devnum=3, cfg=1, intf=5, alt=0, name="UNKNOWN", serial="UNKNOWN"
[ben@Cray-1:~]$ dfu-util -d 05ac:8290 -a 0 -s 1826 -D ssid_prefix
dfu-util 0.8
dfu-util: File too short for DFU suffix
ID 05ac:8290
Run-time device DFU version 0038
Claiming USB DFU Runtime Interface...
Determining device status: state = appDETACH, status = 0
Device really in Runtime Mode, send DFU detach request...
dfu-util: error detaching
Resetting USB...
dfu-util: Lost device after RESET?
[ben@Cray-1:~]$ hexdump ssid_prefix
0000000 06 50 68 6f 74 6f 6e
0000007
[ben@Cray-1:~]$
The SSID program does not need to run permanently to alter SSID. It sets and stores the SSID once so that it will always come up with the custom SSID even if you flash other firmware.
Try changing it back to what it was by use of that same code that you used to customize it.
You also seem to use an odd venID:prodID combination there 05ac:8290. Shouldn’t it be 2b04:d006?
