Hi
Is there any way of changing the SSID of the Photons soft AP?
We are doing a demo and would very much like it to show our product name instead of Photon-XXX
//Henrik
Hi
//Henrik
@henkep, Iâm guessing that if you build locally, you can change these 2 lines.
Iâm not sure if this is linked anywhere else or what implications would be by changing it.
There was a similar question before, maybe you can bump that one
Photon memory map - https://github.com/spark/docs/issues/82 - shows where to change the SSID prefix, but doesnât tell the format except itâs in softap.cpp. This must be FAQ and described somewhere but I couldnât find it. So, this is how to do it.
$ echo âMy Cool Prefix Hereâ | perl -ne âchop; printf("%c%s", length, $_)â > ssid_prefix
$ dfu-util -d 1d50:607f -a 1 -s 1826 -D ssid_prefix
Note that the maximum length of the prefix is 25, and you need to match [SparkSetupCustomization sharedInstance].networkNamePrefix as well.
If you change the SSID, the mobile apps and the particle CLI wonât find the device, which would seem to reduce the usefulness of SoftAP mode.
Please tell me more about your use case for making the SoftAP mode name configurable.
Cheers,
mat.
How do you figure that?
If a Photon ever should be used commercially I don´t think many companies would like to use the Particle app or Particle-CLI for claiming devices. That is why Particle have released the libraries for iOS development and so on.
We are developing a commercial product and of course want our product name as the SSID, we also have our own iOS client that will do the claiming.
//Henrik
Hi @henkep, that makes perfect sense, sorry wasnât thinking clearly, and thinking back to how things were for very early versions of the mobile SDK.
The format of the SSID in memory is
1-byte for the length of the SSID prefix
N-bytes for the SSID prefix.
This is something that weâll add to firmware so the SSID prefix can be set from code.
No worries.
Any ETA on when that firmware change can be in effect?
//Henrik
Any news wrt this matter? This is something that is critical for the application I am currently working on as well.
There is a way to set the SSID using DFU on each photon - does that help as an interim solution until we add this to firmware?
@mdma Yes!
Ok, hereâs the deets on setting the SSID. The SSID is made of two parts - a prefix and the device serial.
The SSID prefix can be set by writing the prefix value to the device.
First, create a file that contains the length of the prefix, followed by the prefix itself. In bash, this is done like this:
echo -e -n "\x03Rad" > ssid_prefix
The \x03 writes a literal value 3 (not the ASCII character â3â) to the file - 3 being the length of our prefix âRadâ. The value is specified on the command line as hex, so values over 10 start âAâ, âBâ etc⌠The maximum allowed length of the prefix is 24.
(Thereâs no need to add a trailing â-â to the prefix, the device automatically adds a â-â between the prefix and the 6-digit serial.)
Then flash this to the device like this:
dfu-util -d 2b04:d006 -a 1 -s 1826 -D ssid_prefix
Next time the device enters softAP mode it will use the given prefix.
The Device Serial can be set by writing the 6-digit serial to the device.
First, create a file that contains the 6-digit device serial. In bash, this is done like this:
echo -n "ABCDEF" > serial
Then flash the serial to the device:
dfu-util -d 2b04:d006 -a 1 -s 1852:6 -D serial
Next time the device enters softAP mode, it will use the given serial.
Ok, so Iâve just done this on a Photon running 0.4.4.
Both flash operations completed correctly. But:
"\x3Rad"). But then I tried "\x7Example", and it reverts back to âPhoton.âIn fact, perplexingly, nothing except "\x3Rad" works. I tried "\x3Exa", and it just comes out as âPhotonâ.
Not sure what to suggest. I just tried it here with a 12-character SSID and it worked. Double check the contents of the ssid_prefix file thatâs produced with a hex editor (or use xxd to dump to binary) to be sure nothing spooky has crept in there.
Mine is a 13 byte file that looks like this:
0000000: 0c4d 6174 7468 6577 2d4d 444d 41 .Matthew-MDMA
Here you see the first byte is 0x0c - 12 - for the length of the prefix followed by the 12 prefix name characters.
Yes! Ok, it seems the problem was integers < 10 in hex representation need to be specified using a leading 0 when saved to the SSID prefix file.
So, for example, "\x7Example" was getting saved as 7e78 616d ... instead of 0745 7861 .... The fix was saving the file as "\x07Example".
Which OS are you using? For me the single char was working on OSXâŚbut so does 0 padded, so letâs stick to that. Iâll edit the original post.
Ubuntu 15.04
The problem was probably that the âEâ in âExampleâ is a valid hex digit. Whereas the âMâ in âMatthew-MDMAâ is not.
So, \x7Example was getting interpreted as \x7E + xample, but since âMâ isnât a hex digit (and likewise for âRâ in the âRadâ example), the shell was stopping with the last valid hex character, to give \xb + Matthew-MMDA.
This only seems to interpolate the first 1 or 2 hex digits, so \xdeadbeef results in \xde + adbeef, and not the 32 bit value of 3,735,928,559.
Youâre absolutely right! It did bother me that \x3Rad had worked (which was all I had to go on initially) but not others. I guess it really just means you definitely got pad those 0âs to make sure the integers get parsed correctly.
