Hi all.
I have setup my spark core and it is connected to the web IDE. I can flash code (magenta color on the board), and then goes back to cyan - connected to the cloud.
However, I can’t even run the most basic examples - such as the LED…not even the D7 led works!
Just one thing I noticed, right before it blinks fast the cyan light when it is about to connect, it flashes a couple of times green color and then goes to breathing cyan. I don’t know if it is a sign for something…
Thanks I will do that, but still I don’t think there is a solution to this problem as I have verified the D7 LED works fine, however it does not run after I flash even the most simple code (as posted above) - even in manual system mode.
It looks that it connects and flashes the code correctly, but nothing further than that…
How are you confirming your code is loaded on your core? Are you hitting the api to send commands, or verify the list of exposed functions / variables? What isn’t running? Have you installed the Spark-cli?
spark list
spark call my_core function_name params
If you flashed the code with SYSTEM_MODE(MANUAL) and was able to reflash new code again, your core probably did not reflash with the new firmware since in Manual mode, the core is not going to connect to the cloud and OTA flashing is not at all possible.
child_process: customFds option is deprecated, use stdio instead.
gyp ERR! configure error
gyp ERR! stack Error: “pre” versions of node cannot be installed, use the --nodedir flag instead
gyp ERR! stack at install (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/install.js:66:16)
gyp ERR! stack at Object.self.commands.(anonymous function) [as install] (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js:66:37)
gyp ERR! stack at getNodeDir (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:152:20)
gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:95:9
gyp ERR! stack at ChildProcess.exithandler (child_process.js:723:7)
gyp ERR! stack at ChildProcess.emit (events.js:110:17)
gyp ERR! stack at maybeClose (child_process.js:1000:16)
gyp ERR! stack at Socket. (child_process.js:1168:11)
gyp ERR! stack at Socket.emit (events.js:107:17)
gyp ERR! stack at Pipe.close (net.js:461:12)
gyp ERR! System Darwin 10.8.0
gyp ERR! command “/usr/local/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild” “–name=serialport” “–configuration=Release” “–module_name=serialport” “–version=1.4.5” “–major=1” “–minor=4” “–patch=5” “–runtime=node” “–node_abi=node-v14” “–platform=darwin” “–target_platform=darwin” “–arch=x64” “–target_arch=x64” “–module_main=./serialport” “–host=https://node-serialport.s3.amazonaws.com/” “–module_path=/usr/local/lib/node_modules/spark-cli/node_modules/serialport/build/serialport/v1.4.5/Release/node-v14-darwin-x64” “–remote_path=./serialport/v1.4.5/Release/” “–package_name=node-v14-darwin-x64.tar.gz” “–staged_tarball=build/stage/serialport/v1.4.5/Release/node-v14-darwin-x64.tar.gz” “–hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.4.5/Release/” "–hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.4.5/Release/node-v14-darwin-x64.tar.gz"
gyp ERR! cwd /usr/local/lib/node_modules/spark-cli/node_modules/serialport
gyp ERR! node -v v0.13.0-pre
gyp ERR! node-gyp -v v1.0.1
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/local/bin/node rebuild --name=serialport --configuration=Release --module_name=serialport --version=1.4.5 --major=1 --minor=4 --patch=5 --runtime=node --node_abi=node-v14 --platform=darwin --target_platform=darwin --arch=x64 --target_arch=x64 --module_main=./serialport --host=https://node-serialport.s3.amazonaws.com/ --module_path=/usr/local/lib/node_modules/spark-cli/node_modules/serialport/build/serialport/v1.4.5/Release/node-v14-darwin-x64 --remote_path=./serialport/v1.4.5/Release/ --package_name=node-v14-darwin-x64.tar.gz --staged_tarball=build/stage/serialport/v1.4.5/Release/node-v14-darwin-x64.tar.gz --hosted_path=https://node-serialport.s3.amazonaws.com/serialport/v1.4.5/Release/ --hosted_tarball=https://node-serialport.s3.amazonaws.com/serialport/v1.4.5/Release/node-v14-darwin-x64.tar.gz’ (1)
node-pre-gyp ERR! stack at ChildProcess. (/usr/local/lib/node_modules/spark-cli/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:76:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:110:17)
node-pre-gyp ERR! stack at maybeClose (child_process.js:1000:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1072:5)
node-pre-gyp ERR! System Darwin 10.8.0
node-pre-gyp ERR! command “node” “/usr/local/lib/node_modules/spark-cli/node_modules/serialport/node_modules/.bin/node-pre-gyp” “install” "–fallback-to-build"
node-pre-gyp ERR! cwd /usr/local/lib/node_modules/spark-cli/node_modules/serialport
node-pre-gyp ERR! node -v v0.13.0-pre
node-pre-gyp ERR! node-pre-gyp -v v0.5.19
node-pre-gyp ERR! not ok
npm ERR! serialport@1.4.5 install: node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the serialport@1.4.5 install script.
npm ERR! This is most likely a problem with the serialport package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-pre-gyp install --fallback-to-build
npm ERR! You can get their info via:
npm ERR! npm owner ls serialport
npm ERR! There is likely additional logging output above.
npm ERR! System Darwin 10.8.0
npm ERR! command “/usr/local/bin/node” “/usr/local/bin/npm” “install” “-g” "spark-cli"
npm ERR! cwd /Users/stavrosdidakis
npm ERR! node -v v0.13.0-pre
npm ERR! npm -v 1.4.28
npm ERR! code ELIFECYCLE
npm ERR! not ok code 0
