First, i run
dfu-util -d 2b04:d006 -a 0 -s 0x8020000 -D reset.bin
to reset the photon. After that the photon can connect to cloud easily, but when i check with
particle serial identify
it didn't return firmware version. I assume that the reset.bin remove the firmware. So i run,
particle flash --usb tinker
partcle update
particle keys server
particle keys doctor MyID
but it make the photon cant connect to cloud.. it just fast blinking CYAN and then short blink ORANGE and also short blink GREEN and back to CYAN all time..
what is actually should i do?
Where does reset.bin come from?
What version CLI are you using?
What does particel serial inspect give you?
i download reset.bin from https://github.com/spark/firmware/releases/tag/v0.4.1
$ particle --version
1.32.4
$ particle serial inspect
Platform: 6 - Photon
Modules
Bootloader module #0 - version 101, main location, 16384 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 207, main location, 262144 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #2 - version 207, main location, 262144 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
Bootloader module #0 - version 7
User module #1 - version 2, main location, 131072 bytes max size
UUID: 2BA4E71E840F596B812003882A
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #2 - version 1
empty - factory location, 131072 bytes max size
i don't understand the output of inspect..
The most important info I was looking for was the bootloader version 101 and your system versoin(s) 207 which seem to be OK.
I'd not recommend resetting your device back to 0.4.1, but since inspect didn't revealy any issue, I guess it's fine.
However, I'd just repeat my suggestion from the other thread
and even if your other devices have no issue connecting to the same network, just try it anyway. And to be sure, I'd also recommend to wipe any stored credentials from the device by holding the SETUP button for 10+ seconds till the RGB LED starts flashing blue rapidly and then apply only the credentials of the new (non-WEP) WiFi network.
Thanks for the response,
i have tried it but still can’t get it to cloud.
