So I’ve been testing code on my Boron for the last few days. Last night I set it out to run and I wakeup this morning and it’s flashing red. sos 10X flash. I tried flashing new code but its unsuccessful. Any ideas why?
Ten total times flash before repeating? You should read the docs on SOS codes.
These are the numbers of slow blinks between the SOS flashes (… - - - …)
If it’s in fact an SOS+1 (… - - - … —) then I’d first suspect a missing return statement in a Particle.function()
But to be sure we need to see your code.
Here’s the code.
It’s a lot of piecing things together from question I’ve asked, so I’m sure there’s probably some interference somewhere.
I’m using it for 2 purposes. I have a solar charger charging the system so I have 2 current sensors (1 for boron battery and other for LED battery) monitoring the battery voltage and sending details to me every 30 minutes.
I also have the system turning on a series of leds via pinSwitch. The “sig” (signal) led is linked directly to the boron. And the main leds are connect to a latching relay( which is why I have 2 pins “led” & “ledoff”). There is also an event publish for me to track when the leds have been turned on.
The numerous // are there for me to more easily switch one and off new code while testing. //battery code & //end battery code are there to bracket the addition of my current sensor code that’s been added to the existing ledSwitch code
#include <adafruit-ina219.h> // Call the current sensor library
//Adafruit_INA219 ina219;
//Adafruit_INA219 ina219_0x40 = Adafruit_INA219();
//Adafruit_INA219 ina219_0x41 = Adafruit_INA219();
int led = D2;
int ledoff = D3;
//int sig = D4;
//int = D5; // Signal LED
//int = D6;
int sig = D7; // OnBoardLED (obd)
//int = D8;
//char voltageStr40[30]; // New String for voltage
//char voltageStr41[30]; // New String for voltage
// start battery code
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
// Settings
const int VOLTAGE_LEN = 30;
const size_t SENSOR_COUNT = 2;
// Addresses of sensors
const size_t SENSOR_ADDRS[SENSOR_COUNT] = {0x40, 0x41};
// Sensor array
Adafruit_INA219* sensors[SENSOR_COUNT];
// Data gathered from sensors
struct INA219Data {
float shuntVoltage;
float busVoltage;
float loadVoltage;
char voltageStr[VOLTAGE_LEN];
} readings[SENSOR_COUNT];
// Forward declarations
const char* voltageStr40();
const char* voltageStr41();
void takeReadings();
// end battery code
void setup(void) {
uint32_t currentFrequency;
Serial.begin(115200);
pinMode(led, OUTPUT);
pinMode(ledoff, OUTPUT);
pinMode(sig, OUTPUT);
Particle.function("switch", pinSwitch); // Register a cloud function named "switch"
Particle.variable("voltageStr40", voltageStr40);
Particle.variable("voltageStr41", voltageStr41);
//ina219.begin();
ina219_0x40.begin();
ina219_0x41.begin();
for (size_t i = 0; i < SENSOR_COUNT; ++i) {
sensors[i] = new Adafruit_INA219(SENSOR_ADDRS[i]);
sensors[i]->begin();
// Connect to Particle cloud
Particle.connect();
// end battery code
void loop(void)
// Update readings
takeReadings();
// Print readings to serial
Serial.printlnf("D%X-Voltage: %s", SENSOR_ADDRS[i], readings[i].voltageStr);
// Publish
char payload[30];
snprintf(payload, sizeof(payload), "%s and %s", readings[0].voltageStr, readings[1].voltageStr);
delay(1000);
Particle.publish("loadMe", payload);
delay(1800000);
// end battery code
// float shuntvoltage40 = 0;
// float busvoltage40 = 0;
// float current_mA40 = 0;
// float loadvoltage40 = 0;
// char voltageStr40[30];
// float shuntvoltage41 = 0;
// float busvoltage41 = 0;
// float current_mA41 = 0;
// float loadvoltage41 = 0;
// char voltageStr41[30];
// shuntvoltage40 = ina219_0x40.getShuntVoltage_mV();
// busvoltage40 = ina219_0x40.getBusVoltage_V();
// current_mA40 = ina219_0x40.getCurrent_mA();
// loadvoltage40 =((busvoltage40 + (shuntvoltage40 / 1000))*(3.3/1.32));
// shuntvoltage41 = ina219_0x41.getShuntVoltage_mV();
// busvoltage41 = ina219_0x41.getBusVoltage_V();
// current_mA41 = ina219_0x41.getCurrent_mA();
// loadvoltage41 =((busvoltage41 + (shuntvoltage41 / 1000))*(3.3/1.32));
// sprintf(voltageStr40, "%f", loadvoltage40); // Convert loadvoltage (float) to a string voltageStr using function("%f")
// sprintf(voltageStr41, "%f", loadvoltage41); // Convert loadvoltage (float) to a string voltageStr using function("%f")
// Particle.publish("loadMe",voltageStr40); // Publish voltageStr with publish event name "loadMe"
// Serial.println("D40-Voltage: ");Serial.print(voltageStr40);
// delay(1000);
// Serial.println("D41-Voltage: ");Serial.print(voltageStr41);
// delay(1000);
// Voltage of first sensor
const char* voltageStr40() {
return readings[0].voltageStr;
// Voltage of second sensor
const char* voltageStr41() {
return readings[1].voltageStr;
// Populate reading data
void takeReadings() {
INA219Data* reading = &readings[i];
float shunt = sensors[i]->getShuntVoltage_mV();
float bus = sensors[i]->getBusVoltage_V();
reading->loadVoltage = ((bus + (shunt / 1000))*(3.3/1.32));
reading->shuntVoltage = shunt;
reading->busVoltage = bus;
snprintf(reading->voltageStr, VOLTAGE_LEN, "%f", reading->loadVoltage);
// end battery code
int pinSwitch(String state) {
// float loadvoltage40 = 0; /// Designate as float
// char voltageStr40[30]; /// Designate as string
// float shuntvoltage40 = 0; /// Designate as float
// float busvoltage40 = 0; /// Designate as float
// float current_mA40 = 0; /// Designate as float
// shuntvoltage40 = ina219_0x40.getShuntVoltage_mV(); // Define
// Serial.println("40Voltage: ");Serial.print(voltageStr40);
// delay(1000);
if ( state == "on" ) { // Set pin state based on given parameters
Serial.println("TURND ONNN ");
digitalWrite(sig, HIGH); /// Signal flash on 5 time
delay(500);
digitalWrite(sig, LOW);
delay(500);
delay(500);
delay(500);
digitalWrite(led, HIGH);
digitalWrite(ledoff,LOW); /// Signal flash on 5 time
delay(30000);
digitalWrite(led, LOW);
digitalWrite(ledoff,HIGH);
delay(200);
delay(500);
delay(500);
delay(500);
delay(500);
Particle.publish("playtime","He Turned Me On",PRIVATE);
} else if ( state == "off" ) {
} else {
return -1;
return 0;
Not sure why you use size_t as type here. It should rather be uint8_t.
You may also want to make your pin variables const int so that they don't take up RAM space.
You are declaring this
But then use some intermediate ina219_0x40 and ina219_0x40 where it would be better to use the sensors[] fields directly.
Doing it your way means you are creating two instances per sensor resulting in four objects where you only have two sensors.
You also use a lot of excessively long delay() calls I'd do away with.
This could be a "streamlined" version of your code where I wouldn't see a reason for an SOS panic crash
const int LED_ON = D2;
const int LED_OFF = D3;
const int LED_SIG = D7; // OnBoardLED (obd)
const int LEN_VOLT = 12;
const uint32_t LOOP_DELAY = 1800000;
const uint8_t SENSOR_ADDRS[] = { 0x40, 0x41 };
const size_t SENSOR_COUNT = sizeof(SENSOR_ADDRS) / sizeof(SENSOR_ADDRS[0]);
struct INA219Data { // Data gathered from sensors
float shuntVoltage;
float busVoltage;
float loadVoltage;
char voltageStr[LEN_VOLT];
int pinSwitch(const char*);
void blink();
int blinkStep = 0;
Timer timerBlink(500, blink);
void setup(void) {
pinMode(LED_ON , OUTPUT);
pinMode(LED_OFF, OUTPUT);
pinMode(LED_SIG, OUTPUT);
Particle.variable("voltageStr40", readings[0].voltageStr);
Particle.variable("voltageStr41", readings[1].voltageStr);
Particle.connect();
void loop(void) {
static uint32_t msDelay = 0;
if (millis() - msDelay < LOOP_DELAY) return; // non-blocking delay - while not due for next action, bail out
msDelay = millis();
takeReadings(); // Update readings
for (size_t i = 0; i < SENSOR_COUNT; ++i) { // Print readings to serial
Serial.printlnf("D%02X-Voltage: %s", SENSOR_ADDRS[i], readings[i].voltageStr);
char payload[30];
void takeReadings() { // Populate reading data
readings[i].loadVoltage = 3.3 * (1000 * bus + shunt) / 1320.0;
readings[i].shuntVoltage = shunt;
readings[i].busVoltage = bus;
snprintf(readings[i].voltageStr, LEN_VOLT, "%.3f", readings[i].loadVoltage);
int pinSwitch(const char* state) {
int retVal = -1;
if (!strcmp(state, "on")) { // Set pin state based on given parameters
retVal = 1;
blinkStep = 0;
timerBlink.start();
Particle.publish("playtime", "He Turned Me On");
else if (!strcmp(state, "off")) {
retVal = 0;
digitalWrite(LED_SIG, LOW);
return retVal;
void blink() { // FSM for blink pattern 500ms per step
switch(blinkStep++) {
case 0:
case 2:
case 66:
case 68:
digitalWrite(LED_SIG, HIGH);
break;
case 1:
case 3:
case 67:
case 69:
break;
case 4:
digitalWrite(LED_ON , HIGH);
digitalWrite(LED_OFF, LOW);
break;
case 5 ... 64: // 30 seconds do nothing
break;
case 65:
digitalWrite(LED_ON , LOW);
digitalWrite(LED_OFF, HIGH);
break;
case 70:
blinkStep = 0;
timerBlink.stop();
break;
default:
break;
Are you driving these relays directly from a GPIO pin or through a driving transistor?
Directly from the pin, but as soon as I get everything working I’ll be flashing the signal for (200) to latch instead of constantly holding it on.
@LADD, is the relay on a breakout board? If you are really driving the relay coil directly, you will most likely damage your processor to due something called "flyback". Look here:
@peekay123 Im using one on a breakout board from adafruit.
