This is such a noobie question, but I have my first Boron / hardware, and I’m beginningto look at what language Boron uses. I found in some obscure documentation page that it uses “Wiring” language, but that’s based on C++? Basically, I’m looking for 2 things:
- Confirmation on what language(s) Boron/Particle uses in its programs.
- A good resource to begin learning the language. This is not my industry and I’m not sure of the best resources to go to learn these particular languages
Any advice from more knowledgeable people would be helpful! Thank you.
Yup, Wiring is a language based on C++. But you won’t find much under that name because it’s more widely known as the language popularized (invented by?) Arduino.
Check out basic Arduino tutorials here: https://www.arduino.cc/en/Tutorial/HomePage?from=Main.Tutorials
If you go to https://build.particle.io/build/new, you can find some specific Arduino examples for the Particle hardware.
Almost 100% of Arduino-based code will work on Particle. Enjoy!
Thank you! I’m sure I’ll have much more questions. I tried doing a “blink LED” example but it turned out I didn’t have the resistors hooked up to the boron / breadboard, so I’m guessing that’s why it didn’t work
. https://docs.particle.io/tutorials/hardware-projects/hardware-examples/boron/
