Boron 404x bricked
@Particle-Tech Hi,
We have a batch of Particle Boron 404x for our project. But 4 of them keep failing to connect to cloud. I used Particle doctor on them and got log files. Could you tell me a way to share the log files with you and help me diagnose them?
Thank you!
Ray
You can paste the log into a reply to this post. You can obscure the things like the ICCID and Device ID, if you prefer to.
Device 33:
0000000327 [system.nm] TRACE: Request to power on interface 4
0000000327 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000000328 [ncp.client] TRACE: Already on
0000000329 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000528 [ncp.client] TRACE: Muxer is not currently running
0000000529 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000530 [mux] INFO: Starting GSM07.10 muxer
0000000531 [mux] INFO: GSM07.10 muxer thread started
0000000831 [mux] INFO: Stopping GSM07.10 muxer
0000000831 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000000832 [mux] INFO: Closing all muxed channels
0000000833 [mux] INFO: Muxed channel 1 already closed
0000000833 [mux] INFO: Muxed channel 2 already closed
0000000834 [mux] INFO: Muxed channel 3 already closed
0000000835 [mux] INFO: Muxed channel 4 already closed
0000000835 [mux] INFO: Sending CLD (multiplexer close down)
0000001736 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000001786 [mux] INFO: GSM07.10 muxer thread exiting
0000001786 [mux] INFO: GSM07.10 muxer stopped
0000001787 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000001788 [mux] INFO: Starting GSM07.10 muxer
0000001789 [mux] INFO: GSM07.10 muxer thread started
0000002089 [mux] INFO: Stopping GSM07.10 muxer
0000002089 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000002090 [mux] INFO: Closing all muxed channels
0000002091 [mux] INFO: Muxed channel 1 already closed
0000002091 [mux] INFO: Muxed channel 2 already closed
0000002092 [mux] INFO: Muxed channel 3 already closed
0000002092 [mux] INFO: Muxed channel 4 already closed
0000002093 [mux] INFO: Sending CLD (multiplexer close down)
0000002994 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000003044 [mux] INFO: GSM07.10 muxer thread exiting
0000003044 [mux] INFO: GSM07.10 muxer stopped
0000003046 [ncp.at] TRACE: > AT
0000004046 [ncp.at] TRACE: > AT
0000005046 [ncp.client] TRACE: Not responsive @ 460800 baudrate
0000005047 [ncp.at] TRACE: > AT
0000005253 [app] INFO: Auto-connect disabled
0000006047 [ncp.at] TRACE: > AT
0000007047 [ncp.at] TRACE: > AT
0000008047 [ncp.at] TRACE: > AT
0000009047 [ncp.at] TRACE: > AT
0000010047 [ncp.client] TRACE: Not responsive @ 115200 baudrate
0000010047 [ncp.client] ERROR: No response from NCP
0000010048 [ncp.client] TRACE: Hard reset
0000010248 [net.pppncp] TRACE: NCP event 3
0000010248 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000010249 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000010250 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000010350 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000010350 [ncp.client] TRACE: Already on
0000010351 [net.pppncp] TRACE: NCP event 3
0000010352 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000010352 [system.nm] TRACE: Interface 4 power state changed: UP
0000011553 [ncp.at] TRACE: > AT
0000012553 [ncp.at] TRACE: > AT
0000013553 [ncp.at] TRACE: > AT
0000014553 [ncp.at] TRACE: > AT
0000015553 [ncp.at] TRACE: > AT
0000016553 [ncp.at] TRACE: > AT
0000017553 [ncp.at] TRACE: > AT
0000018553 [ncp.at] TRACE: > AT
0000019553 [ncp.at] TRACE: > AT
0000020553 [ncp.at] TRACE: > AT
0000021553 [ncp.at] TRACE: > AT
0000022554 [ncp.at] TRACE: > AT
0000023554 [ncp.at] TRACE: > AT
0000024554 [ncp.at] TRACE: > AT
0000025554 [ncp.at] TRACE: > AT
0000026554 [ncp.client] ERROR: No response from NCP
0000026554 [ncp.client] TRACE: Hard reset
0000026755 [net.pppncp] TRACE: NCP event 3
0000026755 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000026756 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000026757 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000026857 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000026857 [ncp.client] TRACE: Already on
0000026858 [net.pppncp] TRACE: NCP event 3
0000026859 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000026859 [system.nm] TRACE: Interface 4 power state changed: UP
0000028060 [ncp.at] TRACE: > AT
0000029060 [ncp.at] TRACE: > AT
0000030060 [ncp.at] TRACE: > AT
0000031060 [ncp.at] TRACE: > AT
0000032060 [ncp.at] TRACE: > AT
0000033060 [ncp.at] TRACE: > AT
0000034060 [ncp.at] TRACE: > AT
0000035060 [ncp.at] TRACE: > AT
0000036060 [ncp.at] TRACE: > AT
0000037060 [ncp.at] TRACE: > AT
0000038060 [ncp.at] TRACE: > AT
0000039061 [ncp.at] TRACE: > AT
0000040061 [ncp.at] TRACE: > AT
0000041061 [ncp.at] TRACE: > AT
0000042061 [ncp.at] TRACE: > AT
0000043061 [ncp.client] ERROR: No response from NCP
0000043061 [ncp.client] TRACE: Hard reset
0000043262 [net.pppncp] TRACE: NCP event 3
0000043262 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000043263 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000043264 [ncp.client] TRACE: Emergency hardware shutdown the modem (STD)
Device 13:
0000000333 [system.nm] TRACE: Request to power on interface 4
0000000334 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000000334 [ncp.client] TRACE: Already on
0000000335 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000534 [ncp.client] TRACE: Muxer is not currently running
0000000535 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000536 [mux] INFO: Starting GSM07.10 muxer
0000000537 [mux] INFO: GSM07.10 muxer thread started
0000000837 [mux] INFO: Stopping GSM07.10 muxer
0000000837 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000000838 [mux] INFO: Closing all muxed channels
0000000839 [mux] INFO: Muxed channel 1 already closed
0000000839 [mux] INFO: Muxed channel 2 already closed
0000000840 [mux] INFO: Muxed channel 3 already closed
0000000840 [mux] INFO: Muxed channel 4 already closed
0000000841 [mux] INFO: Sending CLD (multiplexer close down)
0000001742 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000001792 [mux] INFO: GSM07.10 muxer thread exiting
0000001793 [mux] INFO: GSM07.10 muxer stopped
0000001793 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000001794 [mux] INFO: Starting GSM07.10 muxer
0000001795 [mux] INFO: GSM07.10 muxer thread started
0000002095 [mux] INFO: Stopping GSM07.10 muxer
0000002096 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000002096 [mux] INFO: Closing all muxed channels
0000002097 [mux] INFO: Muxed channel 1 already closed
0000002097 [mux] INFO: Muxed channel 2 already closed
0000002098 [mux] INFO: Muxed channel 3 already closed
0000002099 [mux] INFO: Muxed channel 4 already closed
0000002099 [mux] INFO: Sending CLD (multiplexer close down)
0000003000 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000003050 [mux] INFO: GSM07.10 muxer thread exiting
0000003051 [mux] INFO: GSM07.10 muxer stopped
0000003052 [ncp.at] TRACE: > AT
0000004052 [ncp.at] TRACE: > AT
0000005052 [ncp.client] TRACE: Not responsive @ 460800 baudrate
0000005053 [ncp.at] TRACE: > AT
0000005250 [app] INFO: Auto-connect disabled
0000006054 [ncp.at] TRACE: > AT
0000007054 [ncp.at] TRACE: > AT
0000008054 [ncp.at] TRACE: > AT
0000009054 [ncp.at] TRACE: > AT
0000010054 [ncp.client] TRACE: Not responsive @ 115200 baudrate
0000010055 [ncp.client] ERROR: No response from NCP
0000010055 [ncp.client] TRACE: Hard reset
0000010255 [net.pppncp] TRACE: NCP event 3
0000010255 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000010256 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000010257 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000010357 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000010358 [ncp.client] TRACE: Already on
0000010358 [net.pppncp] TRACE: NCP event 3
0000010359 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000010359 [system.nm] TRACE: Interface 4 power state changed: UP
0000011561 [ncp.at] TRACE: > AT
0000012561 [ncp.at] TRACE: > AT
0000013561 [ncp.at] TRACE: > AT
0000014561 [ncp.at] TRACE: > AT
0000015561 [ncp.at] TRACE: > AT
0000016561 [ncp.at] TRACE: > AT
0000017561 [ncp.at] TRACE: > AT
0000018561 [ncp.at] TRACE: > AT
0000019561 [ncp.at] TRACE: > AT
0000020561 [ncp.at] TRACE: > AT
0000021561 [ncp.at] TRACE: > AT
0000022562 [ncp.at] TRACE: > AT
0000023562 [ncp.at] TRACE: > AT
0000024562 [ncp.at] TRACE: > AT
0000025562 [ncp.at] TRACE: > AT
0000026562 [ncp.client] ERROR: No response from NCP
0000026563 [ncp.client] TRACE: Hard reset
0000026763 [net.pppncp] TRACE: NCP event 3
0000026763 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000026764 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000026765 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000026865 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000026866 [ncp.client] TRACE: Already on
0000026866 [net.pppncp] TRACE: NCP event 3
0000026867 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000026867 [system.nm] TRACE: Interface 4 power state changed: UP
0000028069 [ncp.at] TRACE: > AT
0000029069 [ncp.at] TRACE: > AT
0000030069 [ncp.at] TRACE: > AT
0000031069 [ncp.at] TRACE: > AT
0000032069 [ncp.at] TRACE: > AT
0000033069 [ncp.at] TRACE: > AT
0000034069 [ncp.at] TRACE: > AT
0000035069 [ncp.at] TRACE: > AT
0000036069 [ncp.at] TRACE: > AT
0000037069 [ncp.at] TRACE: > AT
0000038069 [ncp.at] TRACE: > AT
0000039070 [ncp.at] TRACE: > AT
0000040071 [ncp.at] TRACE: > AT
0000041071 [ncp.at] TRACE: > AT
0000042071 [ncp.at] TRACE: > AT
0000043071 [ncp.client] ERROR: No response from NCP
0000043072 [ncp.client] TRACE: Hard reset
0000043272 [net.pppncp] TRACE: NCP event 3
0000043272 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000043273 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000043274 [ncp.client] TRACE: Emergency hardware shutdown the modem (STD)
0000068774 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000068874 [ncp.client] TRACE: Powering on, ncpId: 0x47
Device 40:
0000000310 [system.nm] TRACE: Request to power on interface 4
0000000311 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000000311 [ncp.client] TRACE: Already on
0000000312 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000511 [ncp.client] TRACE: Muxer is not currently running
0000000512 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000513 [mux] INFO: Starting GSM07.10 muxer
0000000514 [mux] INFO: GSM07.10 muxer thread started
0000000814 [mux] INFO: Stopping GSM07.10 muxer
0000000814 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000000815 [mux] INFO: Closing all muxed channels
0000000816 [mux] INFO: Muxed channel 1 already closed
0000000816 [mux] INFO: Muxed channel 2 already closed
0000000817 [mux] INFO: Muxed channel 3 already closed
0000000817 [mux] INFO: Muxed channel 4 already closed
0000000818 [mux] INFO: Sending CLD (multiplexer close down)
0000001719 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000001769 [mux] INFO: GSM07.10 muxer thread exiting
0000001770 [mux] INFO: GSM07.10 muxer stopped
0000001770 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000001771 [mux] INFO: Starting GSM07.10 muxer
0000001772 [mux] INFO: GSM07.10 muxer thread started
0000001911 [app] INFO: Auto-connect disabled
0000002072 [mux] INFO: Stopping GSM07.10 muxer
0000002072 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000002073 [mux] INFO: Closing all muxed channels
0000002074 [mux] INFO: Muxed channel 1 already closed
0000002074 [mux] INFO: Muxed channel 2 already closed
0000002075 [mux] INFO: Muxed channel 3 already closed
0000002076 [mux] INFO: Muxed channel 4 already closed
0000002076 [mux] INFO: Sending CLD (multiplexer close down)
0000002977 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000003027 [mux] INFO: GSM07.10 muxer thread exiting
0000003028 [mux] INFO: GSM07.10 muxer stopped
0000003029 [ncp.at] TRACE: > AT
0000003031 [ncp.at] TRACE: < OK
0000003032 [ncp.client] TRACE: NCP ready to accept AT commands
0000003032 [ncp.at] TRACE: > AT
0000003034 [ncp.at] TRACE: < OK
0000003034 [ncp.at] TRACE: > ATI9
0000003037 [ncp.at] TRACE: < 03.15,A00.01
0000003038 [ncp.at] TRACE: < OK
0000003038 [ncp.client] TRACE: App firmware: 1
0000003039 [ncp.at] TRACE: > AT+UGPIOC?
0000003041 [ncp.at] TRACE: < +UGPIOC:
0000003042 [ncp.at] TRACE: < 16,255
0000003042 [ncp.at] TRACE: < 19,255
0000003043 [ncp.at] TRACE: < 23,0
0000003044 [ncp.at] TRACE: < 24,255
0000003044 [ncp.at] TRACE: < 25,255
0000003045 [ncp.at] TRACE: < 33,255
0000003046 [ncp.at] TRACE: < 42,255
0000003046 [ncp.at] TRACE: < 46,255
0000003047 [ncp.at] TRACE: < OK
0000003048 [ncp.at] TRACE: > AT+UGPIOR=23
0000003050 [ncp.at] TRACE: < +UGPIOR: 23,1
0000003051 [ncp.at] TRACE: < OK
0000003051 [ncp.client] INFO: Using internal SIM card
0000003052 [ncp.at] TRACE: > AT+CPIN?
0000003054 [ncp.at] TRACE: < ERROR
0000004054 [ncp.at] TRACE: > AT+CPIN?
0000004056 [ncp.at] TRACE: < ERROR
0000005056 [ncp.at] TRACE: > AT+CPIN?
0000005058 [ncp.at] TRACE: < ERROR
0000006058 [ncp.at] TRACE: > AT+CPIN?
0000006060 [ncp.at] TRACE: < ERROR
0000007060 [ncp.at] TRACE: > AT+CPIN?
0000007062 [ncp.at] TRACE: < ERROR
0000008062 [ncp.at] TRACE: > AT+CPIN?
0000008064 [ncp.at] TRACE: < ERROR
0000009064 [ncp.at] TRACE: > AT+CPIN?
0000009066 [ncp.at] TRACE: < ERROR
0000010066 [ncp.at] TRACE: > AT+CPIN?
0000010068 [ncp.at] TRACE: < ERROR
0000011068 [ncp.at] TRACE: > AT+CPIN?
0000011070 [ncp.at] TRACE: < ERROR
0000012070 [ncp.at] TRACE: > AT+CPIN?
0000012072 [ncp.at] TRACE: < ERROR
0000013072 [ncp.client] ERROR: Failed to perform early initialization
0000013073 [ncp.client] TRACE: Hard reset
0000013273 [net.pppncp] TRACE: NCP event 3
0000013273 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000013274 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000013275 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000013375 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000013376 [ncp.client] TRACE: Already on
0000013376 [net.pppncp] TRACE: NCP event 3
0000013377 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000013377 [system.nm] TRACE: Interface 4 power state changed: UP
0000014578 [ncp.at] TRACE: > AT
0000014583 [ncp.at] TRACE: < OK
0000014584 [ncp.client] TRACE: NCP ready to accept AT commands
0000014584 [ncp.at] TRACE: > AT
0000014587 [ncp.at] TRACE: < OK
0000014587 [ncp.at] TRACE: > ATI9
0000014590 [ncp.at] TRACE: < 03.15,A00.01
0000014591 [ncp.at] TRACE: < OK
0000014591 [ncp.client] TRACE: App firmware: 1
0000014592 [ncp.at] TRACE: > AT+UGPIOC?
0000014594 [ncp.at] TRACE: < +UGPIOC:
0000014594 [ncp.at] TRACE: < 16,255
0000014595 [ncp.at] TRACE: < 19,255
0000014596 [ncp.at] TRACE: < 23,0
0000014596 [ncp.at] TRACE: < 24,255
0000014597 [ncp.at] TRACE: < 25,255
0000014598 [ncp.at] TRACE: < 33,255
0000014598 [ncp.at] TRACE: < 42,255
0000014599 [ncp.at] TRACE: < 46,255
0000014599 [ncp.at] TRACE: < OK
0000014600 [ncp.at] TRACE: > AT+UGPIOR=23
0000014603 [ncp.at] TRACE: < +UGPIOR: 23,1
0000014604 [ncp.at] TRACE: < OK
0000014604 [ncp.client] INFO: Using internal SIM card
0000014605 [ncp.at] TRACE: > AT+CPIN?
0000014607 [ncp.at] TRACE: < ERROR
0000015607 [ncp.at] TRACE: > AT+CPIN?
0000015609 [ncp.at] TRACE: < ERROR
0000016609 [ncp.at] TRACE: > AT+CPIN?
0000016611 [ncp.at] TRACE: < ERROR
0000017611 [ncp.at] TRACE: > AT+CPIN?
0000017613 [ncp.at] TRACE: < ERROR
0000018613 [ncp.at] TRACE: > AT+CPIN?
0000018615 [ncp.at] TRACE: < ERROR
0000019615 [ncp.at] TRACE: > AT+CPIN?
0000019617 [ncp.at] TRACE: < ERROR
0000020617 [ncp.at] TRACE: > AT+CPIN?
0000020619 [ncp.at] TRACE: < ERROR
0000021619 [ncp.at] TRACE: > AT+CPIN?
0000021621 [ncp.at] TRACE: < ERROR
0000022621 [ncp.at] TRACE: > AT+CPIN?
0000022623 [ncp.at] TRACE: < ERROR
0000023623 [ncp.at] TRACE: > AT+CPIN?
0000023625 [ncp.at] TRACE: < ERROR
0000024625 [ncp.client] ERROR: Failed to perform early initialization
0000024626 [ncp.client] TRACE: Hard reset
0000024826 [net.pppncp] TRACE: NCP event 3
0000024826 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000024827 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000024828 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000024928 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000024929 [ncp.client] TRACE: Already on
0000024929 [net.pppncp] TRACE: NCP event 3
0000024930 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000024930 [system.nm] TRACE: Interface 4 power state changed: UP
0000026131 [ncp.at] TRACE: > AT
0000026136 [ncp.at] TRACE: < OK
0000026137 [ncp.client] TRACE: NCP ready to accept AT commands
0000026137 [ncp.at] TRACE: > AT
0000026140 [ncp.at] TRACE: < OK
0000026140 [ncp.at] TRACE: > ATI9
0000026143 [ncp.at] TRACE: < 03.15,A00.01
0000026144 [ncp.at] TRACE: < OK
0000026144 [ncp.client] TRACE: App firmware: 1
0000026145 [ncp.at] TRACE: > AT+UGPIOC?
0000026147 [ncp.at] TRACE: < +UGPIOC:
0000026147 [ncp.at] TRACE: < 16,255
0000026148 [ncp.at] TRACE: < 19,255
0000026149 [ncp.at] TRACE: < 23,0
0000026149 [ncp.at] TRACE: < 24,255
0000026150 [ncp.at] TRACE: < 25,255
0000026150 [ncp.at] TRACE: < 33,255
0000026151 [ncp.at] TRACE: < 42,255
0000026152 [ncp.at] TRACE: < 46,255
0000026152 [ncp.at] TRACE: < OK
0000026153 [ncp.at] TRACE: > AT+UGPIOR=23
0000026156 [ncp.at] TRACE: < +UGPIOR: 23,1
0000026157 [ncp.at] TRACE: < OK
0000026157 [ncp.client] INFO: Using internal SIM card
0000026158 [ncp.at] TRACE: > AT+CPIN?
0000026160 [ncp.at] TRACE: < ERROR
0000027160 [ncp.at] TRACE: > AT+CPIN?
0000027163 [ncp.at] TRACE: < ERROR
0000028163 [ncp.at] TRACE: > AT+CPIN?
0000028166 [ncp.at] TRACE: < ERROR
0000029166 [ncp.at] TRACE: > AT+CPIN?
0000029169 [ncp.at] TRACE: < ERROR
0000030169 [ncp.at] TRACE: > AT+CPIN?
0000030172 [ncp.at] TRACE: < ERROR
0000031172 [ncp.at] TRACE: > AT+CPIN?
0000031175 [ncp.at] TRACE: < ERROR
0000032175 [ncp.at] TRACE: > AT+CPIN?
0000032178 [ncp.at] TRACE: < ERROR
0000033178 [ncp.at] TRACE: > AT+CPIN?
0000033181 [ncp.at] TRACE: < ERROR
0000034181 [ncp.at] TRACE: > AT+CPIN?
0000034184 [ncp.at] TRACE: < ERROR
0000035184 [ncp.at] TRACE: > AT+CPIN?
0000035187 [ncp.at] TRACE: < ERROR
0000036187 [ncp.client] ERROR: Failed to perform early initialization
0000036188 [ncp.client] TRACE: Hard reset
0000036388 [net.pppncp] TRACE: NCP event 3
0000036388 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000036389 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000036390 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000036490 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000036491 [ncp.client] TRACE: Already on
0000036491 [net.pppncp] TRACE: NCP event 3
0000036492 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000036492 [system.nm] TRACE: Interface 4 power state changed: UP
0000037693 [ncp.at] TRACE: > AT
0000037698 [ncp.at] TRACE: < OK
0000037699 [ncp.client] TRACE: NCP ready to accept AT commands
0000037699 [ncp.at] TRACE: > AT
0000037702 [ncp.at] TRACE: < OK
0000037702 [ncp.at] TRACE: > ATI9
0000037705 [ncp.at] TRACE: < 03.15,A00.01
0000037706 [ncp.at] TRACE: < OK
0000037706 [ncp.client] TRACE: App firmware: 1
0000037707 [ncp.at] TRACE: > AT+UGPIOC?
0000037709 [ncp.at] TRACE: < +UGPIOC:
0000037710 [ncp.at] TRACE: < 16,255
0000037710 [ncp.at] TRACE: < 19,255
0000037711 [ncp.at] TRACE: < 23,0
0000037711 [ncp.at] TRACE: < 24,255
0000037712 [ncp.at] TRACE: < 25,255
0000037713 [ncp.at] TRACE: < 33,255
0000037713 [ncp.at] TRACE: < 42,255
0000037714 [ncp.at] TRACE: < 46,255
0000037715 [ncp.at] TRACE: < OK
0000037715 [ncp.at] TRACE: > AT+UGPIOR=23
0000037718 [ncp.at] TRACE: < +UGPIOR: 23,1
0000037719 [ncp.at] TRACE: < OK
0000037720 [ncp.client] INFO: Using internal SIM card
0000037720 [ncp.at] TRACE: > AT+CPIN?
0000037723 [ncp.at] TRACE: < ERROR
0000038723 [ncp.at] TRACE: > AT+CPIN?
0000038725 [ncp.at] TRACE: < ERROR
0000039725 [ncp.at] TRACE: > AT+CPIN?
0000039727 [ncp.at] TRACE: < ERROR
0000040727 [ncp.at] TRACE: > AT+CPIN?
0000040729 [ncp.at] TRACE: < ERROR
0000041729 [ncp.at] TRACE: > AT+CPIN?
0000041731 [ncp.at] TRACE: < ERROR
0000042731 [ncp.at] TRACE: > AT+CPIN?
0000042733 [ncp.at] TRACE: < ERROR
0000043733 [ncp.at] TRACE: > AT+CPIN?
0000043735 [ncp.at] TRACE: < ERROR
0000044735 [ncp.at] TRACE: > AT+CPIN?
0000044737 [ncp.at] TRACE: < ERROR
0000045737 [ncp.at] TRACE: > AT+CPIN?
0000045739 [ncp.at] TRACE: < ERROR
0000046739 [ncp.at] TRACE: > AT+CPIN?
0000046741 [ncp.at] TRACE: < ERROR
0000047741 [ncp.client] ERROR: Failed to perform early initialization
0000047742 [ncp.client] TRACE: Hard reset
0000047942 [net.pppncp] TRACE: NCP event 3
0000047942 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000047943 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000047944 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000048044 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000048045 [ncp.client] TRACE: Already on
0000048045 [net.pppncp] TRACE: NCP event 3
0000048046 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000048046 [system.nm] TRACE: Interface 4 power state changed: UP
0000049247 [ncp.at] TRACE: > AT
0000049252 [ncp.at] TRACE: < OK
0000049253 [ncp.client] TRACE: NCP ready to accept AT commands
0000049254 [ncp.at] TRACE: > AT
0000049255 [ncp.at] TRACE: < OK
0000049256 [ncp.at] TRACE: > ATI9
0000049259 [ncp.at] TRACE: < 03.15,A00.01
0000049259 [ncp.at] TRACE: < OK
0000049260 [ncp.client] TRACE: App firmware: 1
0000049260 [ncp.at] TRACE: > AT+UGPIOC?
0000049263 [ncp.at] TRACE: < +UGPIOC:
0000049263 [ncp.at] TRACE: < 16,255
0000049264 [ncp.at] TRACE: < 19,255
0000049264 [ncp.at] TRACE: < 23,0
0000049265 [ncp.at] TRACE: < 24,255
0000049266 [ncp.at] TRACE: < 25,255
0000049266 [ncp.at] TRACE: < 33,255
0000049267 [ncp.at] TRACE: < 42,255
0000049267 [ncp.at] TRACE: < 46,255
0000049268 [ncp.at] TRACE: < OK
0000049269 [ncp.at] TRACE: > AT+UGPIOR=23
0000049272 [ncp.at] TRACE: < +UGPIOR: 23,1
0000049272 [ncp.at] TRACE: < OK
0000049273 [ncp.client] INFO: Using internal SIM card
0000049274 [ncp.at] TRACE: > AT+CPIN?
0000049276 [ncp.at] TRACE: < ERROR
0000050276 [ncp.at] TRACE: > AT+CPIN?
0000050279 [ncp.at] TRACE: < ERROR
0000051279 [ncp.at] TRACE: > AT+CPIN?
0000051282 [ncp.at] TRACE: < ERROR
0000052282 [ncp.at] TRACE: > AT+CPIN?
0000052285 [ncp.at] TRACE: < ERROR
0000053285 [ncp.at] TRACE: > AT+CPIN?
0000053288 [ncp.at] TRACE: < ERROR
0000054288 [ncp.at] TRACE: > AT+CPIN?
0000054291 [ncp.at] TRACE: < ERROR
0000055291 [ncp.at] TRACE: > AT+CPIN?
0000055294 [ncp.at] TRACE: < ERROR
0000056294 [ncp.at] TRACE: > AT+CPIN?
0000056297 [ncp.at] TRACE: < ERROR
0000057297 [ncp.at] TRACE: > AT+CPIN?
0000057300 [ncp.at] TRACE: < ERROR
0000058300 [ncp.at] TRACE: > AT+CPIN?
0000058303 [ncp.at] TRACE: < ERROR
0000059303 [ncp.client] ERROR: Failed to perform early initialization
0000059304 [ncp.client] TRACE: Hard reset
0000059504 [net.pppncp] TRACE: NCP event 3
0000059504 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000059505 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000059506 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000059606 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000059607 [ncp.client] TRACE: Already on
0000059607 [net.pppncp] TRACE: NCP event 3
0000059608 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000059608 [system.nm] TRACE: Interface 4 power state changed: UP
0000060809 [ncp.at] TRACE: > AT
0000060814 [ncp.at] TRACE: < OK
0000060815 [ncp.client] TRACE: NCP ready to accept AT commands
0000060815 [ncp.at] TRACE: > AT
0000060817 [ncp.at] TRACE: < OK
0000060818 [ncp.at] TRACE: > ATI9
0000060820 [ncp.at] TRACE: < 03.15,A00.01
0000060821 [ncp.at] TRACE: < OK
0000060822 [ncp.client] TRACE: App firmware: 1
0000060822 [ncp.at] TRACE: > AT+UGPIOC?
0000060824 [ncp.at] TRACE: < +UGPIOC:
0000060825 [ncp.at] TRACE: < 16,255
0000060826 [ncp.at] TRACE: < 19,255
0000060826 [ncp.at] TRACE: < 23,0
0000060827 [ncp.at] TRACE: < 24,255
0000060827 [ncp.at] TRACE: < 25,255
0000060828 [ncp.at] TRACE: < 33,255
0000060829 [ncp.at] TRACE: < 42,255
0000060829 [ncp.at] TRACE: < 46,255
0000060830 [ncp.at] TRACE: < OK
0000060830 [ncp.at] TRACE: > AT+UGPIOR=23
0000060833 [ncp.at] TRACE: < +UGPIOR: 23,1
0000060834 [ncp.at] TRACE: < OK
0000060835 [ncp.client] INFO: Using internal SIM card
0000060835 [ncp.at] TRACE: > AT+CPIN?
0000060837 [ncp.at] TRACE: < ERROR
0000061837 [ncp.at] TRACE: > AT+CPIN?
0000061839 [ncp.at] TRACE: < ERROR
0000062840 [ncp.at] TRACE: > AT+CPIN?
0000062843 [ncp.at] TRACE: < ERROR
Device 39:
0000000323 [system.nm] TRACE: Request to power on interface 4
0000000324 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000000325 [ncp.client] TRACE: Already on
0000000325 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000524 [ncp.client] TRACE: Muxer is not currently running
0000000525 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000526 [mux] INFO: Starting GSM07.10 muxer
0000000527 [mux] INFO: GSM07.10 muxer thread started
0000000827 [mux] INFO: Stopping GSM07.10 muxer
0000000828 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000000828 [mux] INFO: Closing all muxed channels
0000000829 [mux] INFO: Muxed channel 1 already closed
0000000830 [mux] INFO: Muxed channel 2 already closed
0000000830 [mux] INFO: Muxed channel 3 already closed
0000000831 [mux] INFO: Muxed channel 4 already closed
0000000831 [mux] INFO: Sending CLD (multiplexer close down)
0000001732 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000001782 [mux] INFO: GSM07.10 muxer thread exiting
0000001783 [mux] INFO: GSM07.10 muxer stopped
0000001784 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000001784 [mux] INFO: Starting GSM07.10 muxer
0000001785 [mux] INFO: GSM07.10 muxer thread started
0000001931 [app] INFO: Auto-connect disabled
0000002085 [mux] INFO: Stopping GSM07.10 muxer
0000002086 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000002086 [mux] INFO: Closing all muxed channels
0000002087 [mux] INFO: Muxed channel 1 already closed
0000002088 [mux] INFO: Muxed channel 2 already closed
0000002088 [mux] INFO: Muxed channel 3 already closed
0000002089 [mux] INFO: Muxed channel 4 already closed
0000002089 [mux] INFO: Sending CLD (multiplexer close down)
0000002990 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000003040 [mux] INFO: GSM07.10 muxer thread exiting
0000003041 [mux] INFO: GSM07.10 muxer stopped
0000003042 [ncp.at] TRACE: > AT
0000003044 [ncp.at] TRACE: < OK
0000003045 [ncp.client] TRACE: NCP ready to accept AT commands
0000003048 [ncp.at] TRACE: > ATI9
0000003051 [ncp.at] TRACE: < 03.15,A00.01
0000003052 [ncp.client] TRACE: App firmware: 1
0000003052 [ncp.at] TRACE: > AT+UGPIOC?
0000003054 [ncp.at] TRACE: < +UGPIOC:
0000003055 [ncp.at] TRACE: < 16,255
0000003056 [ncp.at] TRACE: < 19,255
0000003056 [ncp.at] TRACE: < 23,0
0000003057 [ncp.at] TRACE: < 24,255
0000003058 [ncp.at] TRACE: < 25,255
0000003058 [ncp.at] TRACE: < 33,255
0000003059 [ncp.at] TRACE: < 42,255
0000003060 [ncp.at] TRACE: < 46,255
0000003060 [ncp.at] TRACE: < OK
0000003061 [ncp.at] TRACE: > AT+UGPIOR=23
0000003064 [ncp.at] TRACE: < +UGPIOR: 23,1
0000003064 [ncp.at] TRACE: < OK
0000003065 [ncp.client] INFO: Using internal SIM card
0000003065 [ncp.at] TRACE: > AT+CPIN?
0000003067 [ncp.at] TRACE: < ERROR
0000004067 [ncp.at] TRACE: > AT+CPIN?
0000004070 [ncp.at] TRACE: < ERROR
0000005069 [ncp.at] TRACE: > AT+CPIN?
0000005072 [ncp.at] TRACE: < ERROR
0000006071 [ncp.at] TRACE: > AT+CPIN?
0000006074 [ncp.at] TRACE: < ERROR
0000007073 [ncp.at] TRACE: > AT+CPIN?
0000007076 [ncp.at] TRACE: < ERROR
0000008075 [ncp.at] TRACE: > AT+CPIN?
0000008078 [ncp.at] TRACE: < ERROR
0000009077 [ncp.at] TRACE: > AT+CPIN?
0000009080 [ncp.at] TRACE: < ERROR
0000010079 [ncp.at] TRACE: > AT+CPIN?
0000010082 [ncp.at] TRACE: < ERROR
0000011081 [ncp.at] TRACE: > AT+CPIN?
0000011084 [ncp.at] TRACE: < ERROR
0000012083 [ncp.at] TRACE: > AT+CPIN?
0000012086 [ncp.at] TRACE: < ERROR
0000013085 [ncp.client] ERROR: Failed to perform early initialization
0000013086 [ncp.client] TRACE: Hard reset
0000013286 [net.pppncp] TRACE: NCP event 3
0000013287 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000013288 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000013288 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000013388 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000013389 [ncp.client] TRACE: Already on
0000013389 [net.pppncp] TRACE: NCP event 3
0000013390 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000013391 [system.nm] TRACE: Interface 4 power state changed: UP
0000014598 [ncp.at] TRACE: < OK
0000014598 [ncp.client] TRACE: NCP ready to accept AT commands
0000014599 [ncp.at] TRACE: > AT
0000014601 [ncp.at] TRACE: < OK
0000014601 [ncp.at] TRACE: > ATI9
0000014604 [ncp.at] TRACE: < 03.15,A00.01
0000014605 [ncp.at] TRACE: < OK
0000014605 [ncp.client] TRACE: App firmware: 1
0000014606 [ncp.at] TRACE: > AT+UGPIOC?
0000014608 [ncp.at] TRACE: < +UGPIOC:
0000014608 [ncp.at] TRACE: < 16,255
0000014609 [ncp.at] TRACE: < 19,255
0000014610 [ncp.at] TRACE: < 23,0
0000014610 [ncp.at] TRACE: < 24,255
0000014611 [ncp.at] TRACE: < 25,255
0000014611 [ncp.at] TRACE: < 33,255
0000014612 [ncp.at] TRACE: < 42,255
0000014613 [ncp.at] TRACE: < 46,255
0000014613 [ncp.at] TRACE: < OK
0000014614 [ncp.at] TRACE: > AT+UGPIOR=23
0000014617 [ncp.at] TRACE: < +UGPIOR: 23,1
0000014618 [ncp.at] TRACE: < OK
0000014618 [ncp.client] INFO: Using internal SIM card
0000014619 [ncp.at] TRACE: > AT+CPIN?
0000014622 [ncp.at] TRACE: < ERROR
0000015622 [ncp.at] TRACE: > AT+CPIN?
0000015625 [ncp.at] TRACE: < ERROR
0000016625 [ncp.at] TRACE: > AT+CPIN?
0000016628 [ncp.at] TRACE: < ERROR
0000017628 [ncp.at] TRACE: > AT+CPIN?
0000017631 [ncp.at] TRACE: < ERROR
0000018631 [ncp.at] TRACE: > AT+CPIN?
0000018634 [ncp.at] TRACE: < ERROR
0000019634 [ncp.at] TRACE: > AT+CPIN?
0000019637 [ncp.at] TRACE: < ERROR
0000020637 [ncp.at] TRACE: > AT+CPIN?
0000020640 [ncp.at] TRACE: < ERROR
0000021640 [ncp.at] TRACE: > AT+CPIN?
0000021643 [ncp.at] TRACE: < ERROR
0000022643 [ncp.at] TRACE: > AT+CPIN?
0000022646 [ncp.at] TRACE: < ERROR
0000023646 [ncp.at] TRACE: > AT+CPIN?
0000023649 [ncp.at] TRACE: < ERROR
0000024649 [ncp.client] ERROR: Failed to perform early initialization
0000024650 [ncp.client] TRACE: Hard reset
0000024850 [net.pppncp] TRACE: NCP event 3
0000024851 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000024852 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000024852 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000024952 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000024953 [ncp.client] TRACE: Already on
0000024953 [net.pppncp] TRACE: NCP event 3
0000024954 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000024955 [system.nm] TRACE: Interface 4 power state changed: UP
0000026156 [ncp.at] TRACE: > AT
0000026162 [ncp.at] TRACE: < OK
0000026162 [ncp.client] TRACE: NCP ready to accept AT commands
0000026163 [ncp.at] TRACE: > AT
0000026165 [ncp.at] TRACE: < OK
0000026166 [ncp.at] TRACE: > ATI9
0000026169 [ncp.at] TRACE: < 03.15,A00.01
0000026169 [ncp.at] TRACE: < OK
0000026170 [ncp.client] TRACE: App firmware: 1
0000026170 [ncp.at] TRACE: > AT+UGPIOC?
0000026172 [ncp.at] TRACE: < +UGPIOC:
0000026173 [ncp.at] TRACE: < 16,255
0000026174 [ncp.at] TRACE: < 19,255
0000026174 [ncp.at] TRACE: < 23,0
0000026175 [ncp.at] TRACE: < 24,255
0000026176 [ncp.at] TRACE: < 25,255
0000026176 [ncp.at] TRACE: < 33,255
0000026177 [ncp.at] TRACE: < 42,255
0000026177 [ncp.at] TRACE: < 46,255
0000026178 [ncp.at] TRACE: < OK
0000026179 [ncp.at] TRACE: > AT+UGPIOR=23
0000026182 [ncp.at] TRACE: < +UGPIOR: 23,1
0000026182 [ncp.at] TRACE: < OK
0000026183 [ncp.client] INFO: Using internal SIM card
0000026183 [ncp.at] TRACE: > AT+CPIN?
0000026186 [ncp.at] TRACE: < ERROR
0000027185 [ncp.at] TRACE: > AT+CPIN?
0000027188 [ncp.at] TRACE: < ERROR
0000028187 [ncp.at] TRACE: > AT+CPIN?
0000028190 [ncp.at] TRACE: < ERROR
0000029189 [ncp.at] TRACE: > AT+CPIN?
0000029192 [ncp.at] TRACE: < ERROR
0000030191 [ncp.at] TRACE: > AT+CPIN?
0000030194 [ncp.at] TRACE: < ERROR
0000031193 [ncp.at] TRACE: > AT+CPIN?
0000031196 [ncp.at] TRACE: < ERROR
0000032195 [ncp.at] TRACE: > AT+CPIN?
0000032198 [ncp.at] TRACE: < ERROR
0000033197 [ncp.at] TRACE: > AT+CPIN?
0000033200 [ncp.at] TRACE: < ERROR
0000034199 [ncp.at] TRACE: > AT+CPIN?
0000034202 [ncp.at] TRACE: < ERROR
0000035201 [ncp.at] TRACE: > AT+CPIN?
0000035204 [ncp.at] TRACE: < ERROR
0000036203 [ncp.client] ERROR: Failed to perform early initialization
0000036204 [ncp.client] TRACE: Hard reset
0000036404 [net.pppncp] TRACE: NCP event 3
0000036405 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000036406 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000036406 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000036506 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000036507 [ncp.client] TRACE: Already on
0000036507 [net.pppncp] TRACE: NCP event 3
0000036508 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000036509 [system.nm] TRACE: Interface 4 power state changed: UP
0000037710 [ncp.at] TRACE: > AT
0000037716 [ncp.at] TRACE: < OK
0000037716 [ncp.client] TRACE: NCP ready to accept AT commands
0000037717 [ncp.at] TRACE: > AT
0000037720 [ncp.at] TRACE: > ATI9
0000037723 [ncp.at] TRACE: < 03.15,A00.01
0000037723 [ncp.at] TRACE: < OK
0000037724 [ncp.client] TRACE: App firmware: 1
0000037724 [ncp.at] TRACE: > AT+UGPIOC?
0000037726 [ncp.at] TRACE: < +UGPIOC:
0000037727 [ncp.at] TRACE: < 16,255
0000037728 [ncp.at] TRACE: < 19,255
0000037728 [ncp.at] TRACE: < 23,0
0000037729 [ncp.at] TRACE: < 24,255
0000037729 [ncp.at] TRACE: < 25,255
0000037730 [ncp.at] TRACE: < 33,255
0000037731 [ncp.at] TRACE: < 42,255
0000037731 [ncp.at] TRACE: < 46,255
0000037732 [ncp.at] TRACE: < OK
0000037732 [ncp.at] TRACE: > AT+UGPIOR=23
0000037735 [ncp.at] TRACE: < +UGPIOR: 23,1
0000037736 [ncp.at] TRACE: < OK
0000037737 [ncp.client] INFO: Using internal SIM card
0000037737 [ncp.at] TRACE: > AT+CPIN?
0000037739 [ncp.at] TRACE: < ERROR
0000038739 [ncp.at] TRACE: > AT+CPIN?
0000038741 [ncp.at] TRACE: < ERROR
0000039741 [ncp.at] TRACE: > AT+CPIN?
0000039744 [ncp.at] TRACE: < ERROR
0000040743 [ncp.at] TRACE: > AT+CPIN?
0000040746 [ncp.at] TRACE: < ERROR
0000041745 [ncp.at] TRACE: > AT+CPIN?
0000041747 [ncp.at] TRACE: < ERROR
0000042747 [ncp.at] TRACE: > AT+CPIN?
0000042750 [ncp.at] TRACE: < ERROR
0000043749 [ncp.at] TRACE: > AT+CPIN?
0000043752 [ncp.at] TRACE: < ERROR
0000044751 [ncp.at] TRACE: > AT+CPIN?
0000044754 [ncp.at] TRACE: < ERROR
0000045753 [ncp.at] TRACE: > AT+CPIN?
0000045756 [ncp.at] TRACE: < ERROR
0000046755 [ncp.at] TRACE: > AT+CPIN?
0000046758 [ncp.at] TRACE: < ERROR
0000047757 [ncp.client] ERROR: Failed to perform early initialization
0000047758 [ncp.client] TRACE: Hard reset
0000047958 [net.pppncp] TRACE: NCP event 3
0000047959 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000047960 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000047960 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000048060 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000048061 [ncp.client] TRACE: Already on
0000048061 [net.pppncp] TRACE: NCP event 3
0000048062 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000048063 [system.nm] TRACE: Interface 4 power state changed: UP
0000049264 [ncp.at] TRACE: > AT
0000049270 [ncp.at] TRACE: < OK
0000049270 [ncp.client] TRACE: NCP ready to accept AT commands
0000049271 [ncp.at] TRACE: > AT
0000049273 [ncp.at] TRACE: < OK
0000049274 [ncp.at] TRACE: > ATI9
0000049276 [ncp.at] TRACE: < 03.15,A00.01
0000049277 [ncp.at] TRACE: < OK
0000049277 [ncp.client] TRACE: App firmware: 1
0000049278 [ncp.at] TRACE: > AT+UGPIOC?
0000049280 [ncp.at] TRACE: < +UGPIOC:
0000049281 [ncp.at] TRACE: < 16,255
0000049281 [ncp.at] TRACE: < 19,255
0000049282 [ncp.at] TRACE: < 23,0
0000049283 [ncp.at] TRACE: < 24,255
0000049283 [ncp.at] TRACE: < 25,255
0000049284 [ncp.at] TRACE: < 33,255
0000049284 [ncp.at] TRACE: < 42,255
0000049285 [ncp.at] TRACE: < 46,255
0000049286 [ncp.at] TRACE: < OK
0000049286 [ncp.at] TRACE: > AT+UGPIOR=23
0000049289 [ncp.at] TRACE: < +UGPIOR: 23,1
0000049290 [ncp.at] TRACE: < OK
0000049290 [ncp.client] INFO: Using internal SIM card
0000049291 [ncp.at] TRACE: > AT+CPIN?
0000049293 [ncp.at] TRACE: < ERROR
0000050293 [ncp.at] TRACE: > AT+CPIN?
0000050296 [ncp.at] TRACE: < ERROR
0000051296 [ncp.at] TRACE: > AT+CPIN?
0000051299 [ncp.at] TRACE: < ERROR
0000052299 [ncp.at] TRACE: > AT+CPIN?
0000052302 [ncp.at] TRACE: < ERROR
0000053302 [ncp.at] TRACE: > AT+CPIN?
0000053305 [ncp.at] TRACE: < ERROR
0000054305 [ncp.at] TRACE: > AT+CPIN?
0000054308 [ncp.at] TRACE: < ERROR
0000055308 [ncp.at] TRACE: > AT+CPIN?
0000055311 [ncp.at] TRACE: < ERROR
0000056311 [ncp.at] TRACE: > AT+CPIN?
0000056314 [ncp.at] TRACE: < ERROR
0000057314 [ncp.at] TRACE: > AT+CPIN?
0000057317 [ncp.at] TRACE: < ERROR
0000058317 [ncp.at] TRACE: > AT+CPIN?
0000058320 [ncp.at] TRACE: < ERROR
0000059320 [ncp.client] ERROR: Failed to perform early initialization
0000059321 [ncp.client] TRACE: Hard reset
0000059521 [net.pppncp] TRACE: NCP event 3
0000059522 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000059523 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000059523 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000059623 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000059624 [ncp.client] TRACE: Already on
0000059624 [net.pppncp] TRACE: NCP event 3
0000059625 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000059626 [system.nm] TRACE: Interface 4 power state changed: UP
0000060827 [ncp.at] TRACE: > AT
0000060833 [ncp.at] TRACE: < OK
0000060833 [ncp.client] TRACE: NCP ready to accept AT commands
0000060834 [ncp.at] TRACE: > AT
0000060836 [ncp.at] TRACE: < OK
0000060837 [ncp.at] TRACE: > ATI9
0000060839 [ncp.at] TRACE: < 03.15,A00.01
0000060840 [ncp.at] TRACE: < OK
0000060841 [ncp.client] TRACE: App firmware: 1
0000060841 [ncp.at] TRACE: > AT+UGPIOC?
0000060843 [ncp.at] TRACE: < +UGPIOC:
0000060844 [ncp.at] TRACE: < 16,255
0000060845 [ncp.at] TRACE: < 19,255
0000060845 [ncp.at] TRACE: < 23,0
0000060846 [ncp.at] TRACE: < 24,255
0000060846 [ncp.at] TRACE: < 25,255
0000060847 [ncp.at] TRACE: < 33,255
0000060848 [ncp.at] TRACE: < 42,255
0000060848 [ncp.at] TRACE: < 46,255
0000060849 [ncp.at] TRACE: < OK
0000060849 [ncp.at] TRACE: > AT+UGPIOR=23
0000060853 [ncp.at] TRACE: < +UGPIOR: 23,1
0000060853 [ncp.at] TRACE: < OK
0000060854 [ncp.client] INFO: Using internal SIM card
0000060854 [ncp.at] TRACE: > AT+CPIN?
0000060856 [ncp.at] TRACE: < ERROR
0000061856 [ncp.at] TRACE: > AT+CPIN?
0000061859 [ncp.at] TRACE: < ERROR
0000062858 [ncp.at] TRACE: > AT+CPIN?
0000062861 [ncp.at] TRACE: < ERROR
0000063860 [ncp.at] TRACE: > AT+CPIN?
0000063863 [ncp.at] TRACE: < ERROR
0000064862 [ncp.at] TRACE: > AT+CPIN?
0000064865 [ncp.at] TRACE: < ERROR
0000065864 [ncp.at] TRACE: > AT+CPIN?
0000065867 [ncp.at] TRACE: < ERROR
0000066866 [ncp.at] TRACE: > AT+CPIN?
0000066869 [ncp.at] TRACE: < ERROR
0000067868 [ncp.at] TRACE: > AT+CPIN?
0000067871 [ncp.at] TRACE: < ERROR
0000068870 [ncp.at] TRACE: > AT+CPIN?
0000068873 [ncp.at] TRACE: < ERROR
0000069872 [ncp.at] TRACE: > AT+CPIN?
0000069875 [ncp.at] TRACE: < ERROR
0000070874 [ncp.client] ERROR: Failed to perform early initialization
0000070875 [ncp.client] TRACE: Hard reset
0000071075 [net.pppncp] TRACE: NCP event 3
0000071076 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000071077 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000071077 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000071177 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000071178 [ncp.client] TRACE: Already on
0000071178 [net.pppncp] TRACE: NCP event 3
0000071179 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000071180 [system.nm] TRACE: Interface 4 power state changed: UP
0000072381 [ncp.at] TRACE: > AT
0000072387 [ncp.at] TRACE: < OK
0000072387 [ncp.client] TRACE: NCP ready to accept AT commands
0000072388 [ncp.at] TRACE: > AT
0000072390 [ncp.at] TRACE: < OK
0000072390 [ncp.at] TRACE: > ATI9
0000072393 [ncp.at] TRACE: < 03.15,A00.01
0000072394 [ncp.at] TRACE: < OK
0000072394 [ncp.client] TRACE: App firmware: 1
0000072395 [ncp.at] TRACE: > AT+UGPIOC?
0000072397 [ncp.at] TRACE: < +UGPIOC:
0000072397 [ncp.at] TRACE: < 16,255
0000072398 [ncp.at] TRACE: < 19,255
0000072399 [ncp.at] TRACE: < 23,0
0000072399 [ncp.at] TRACE: < 24,255
0000072400 [ncp.at] TRACE: < 25,255
0000072400 [ncp.at] TRACE: < 33,255
0000072401 [ncp.at] TRACE: < 42,255
0000072402 [ncp.at] TRACE: < 46,255
0000072402 [ncp.at] TRACE: < OK
0000072403 [ncp.at] TRACE: > AT+UGPIOR=23
0000072406 [ncp.at] TRACE: < +UGPIOR: 23,1
0000072407 [ncp.at] TRACE: < OK
0000072407 [ncp.client] INFO: Using internal SIM card
0000072408 [ncp.at] TRACE: > AT+CPIN?
0000072410 [ncp.at] TRACE: < ERROR
0000073410 [ncp.at] TRACE: > AT+CPIN?
0000073413 [ncp.at] TRACE: < ERROR
0000074413 [ncp.at] TRACE: > AT+CPIN?
0000074416 [ncp.at] TRACE: < ERROR
0000075416 [ncp.at] TRACE: > AT+CPIN?
0000075419 [ncp.at] TRACE: < ERROR
0000076419 [ncp.at] TRACE: > AT+CPIN?
0000076422 [ncp.at] TRACE: < ERROR
0000077422 [ncp.at] TRACE: > AT+CPIN?
0000077425 [ncp.at] TRACE: < ERROR
0000078425 [ncp.at] TRACE: > AT+CPIN?
0000078428 [ncp.at] TRACE: < ERROR
0000079428 [ncp.at] TRACE: > AT+CPIN?
0000079431 [ncp.at] TRACE: < ERROR
0000080431 [ncp.at] TRACE: > AT+CPIN?
0000080434 [ncp.at] TRACE: < ERROR
0000081434 [ncp.at] TRACE: > AT+CPIN?
0000081437 [ncp.at] TRACE: < ERROR
0000082437 [ncp.client] ERROR: Failed to perform early initialization
0000082438 [ncp.client] TRACE: Hard reset
0000082638 [net.pppncp] TRACE: NCP event 3
0000082639 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000082640 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000082640 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000082740 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000082741 [ncp.client] TRACE: Already on
0000082741 [net.pppncp] TRACE: NCP event 3
0000082742 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000082743 [system.nm] TRACE: Interface 4 power state changed: UP
0000083944 [ncp.at] TRACE: > AT
0000083950 [ncp.at] TRACE: < OK
0000083950 [ncp.client] TRACE: NCP ready to accept AT commands
0000083951 [ncp.at] TRACE: > AT
0000083953 [ncp.at] TRACE: < OK
0000083953 [ncp.at] TRACE: > ATI9
0000083956 [ncp.at] TRACE: < 03.15,A00.01
0000083957 [ncp.at] TRACE: < OK
0000083957 [ncp.client] TRACE: App firmware: 1
0000083958 [ncp.at] TRACE: > AT+UGPIOC?
0000083960 [ncp.at] TRACE: < +UGPIOC:
0000083960 [ncp.at] TRACE: < 16,255
0000083961 [ncp.at] TRACE: < 19,255
0000083962 [ncp.at] TRACE: < 23,0
0000083962 [ncp.at] TRACE: < 24,255
0000083963 [ncp.at] TRACE: < 25,255
0000083963 [ncp.at] TRACE: < 33,255
0000083964 [ncp.at] TRACE: < 42,255
0000083965 [ncp.at] TRACE: < 46,255
0000083965 [ncp.at] TRACE: < OK
0000083966 [ncp.at] TRACE: > AT+UGPIOR=23
0000083969 [ncp.at] TRACE: < +UGPIOR: 23,1
0000083970 [ncp.at] TRACE: < OK
0000083970 [ncp.client] INFO: Using internal SIM card
0000083971 [ncp.at] TRACE: > AT+CPIN?
0000083973 [ncp.at] TRACE: < ERROR
0000084973 [ncp.at] TRACE: > AT+CPIN?
0000084976 [ncp.at] TRACE: < ERROR
0000085976 [ncp.at] TRACE: > AT+CPIN?
0000085979 [ncp.at] TRACE: < ERROR
0000086979 [ncp.at] TRACE: > AT+CPIN?
0000086982 [ncp.at] TRACE: < ERROR
0000087982 [ncp.at] TRACE: > AT+CPIN?
0000087985 [ncp.at] TRACE: < ERROR
0000088985 [ncp.at] TRACE: > AT+CPIN?
0000088988 [ncp.at] TRACE: < ERROR
0000089988 [ncp.at] TRACE: > AT+CPIN?
0000089991 [ncp.at] TRACE: < ERROR
0000090991 [ncp.at] TRACE: > AT+CPIN?
0000090994 [ncp.at] TRACE: < ERROR
0000091994 [ncp.at] TRACE: > AT+CPIN?
0000091997 [ncp.at] TRACE: < ERROR
0000092997 [ncp.at] TRACE: > AT+CPIN?
0000093000 [ncp.at] TRACE: < ERROR
0000094000 [ncp.client] ERROR: Failed to perform early initialization
0000094001 [ncp.client] TRACE: Hard reset
0000094201 [net.pppncp] TRACE: NCP event 3
0000094202 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000094203 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000094203 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000094303 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000094304 [ncp.client] TRACE: Already on
0000094304 [net.pppncp] TRACE: NCP event 3
0000094305 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000094306 [system.nm] TRACE: Interface 4 power state changed: UP
0000095507 [ncp.at] TRACE: > AT
0000095513 [ncp.at] TRACE: < OK
0000095513 [ncp.client] TRACE: NCP ready to accept AT commands
0000095514 [ncp.at] TRACE: > AT
0000095516 [ncp.at] TRACE: < OK
0000095516 [ncp.at] TRACE: > ATI9
0000095519 [ncp.at] TRACE: < 03.15,A00.01
0000095520 [ncp.at] TRACE: < OK
0000095520 [ncp.client] TRACE: App firmware: 1
0000095521 [ncp.at] TRACE: > AT+UGPIOC?
0000095523 [ncp.at] TRACE: < +UGPIOC:
0000095524 [ncp.at] TRACE: < 16,255
0000095524 [ncp.at] TRACE: < 19,255
0000095525 [ncp.at] TRACE: < 23,0
0000095525 [ncp.at] TRACE: < 24,255
0000095526 [ncp.at] TRACE: < 25,255
0000095527 [ncp.at] TRACE: < 33,255
0000095527 [ncp.at] TRACE: < 42,255
0000095528 [ncp.at] TRACE: < 46,255
0000095528 [ncp.at] TRACE: < OK
0000095529 [ncp.at] TRACE: > AT+UGPIOR=23
0000095532 [ncp.at] TRACE: < +UGPIOR: 23,1
0000095533 [ncp.at] TRACE: < OK
0000095533 [ncp.client] INFO: Using internal SIM card
0000095534 [ncp.at] TRACE: > AT+CPIN?
0000095537 [ncp.at] TRACE: < ERROR
0000096537 [ncp.at] TRACE: > AT+CPIN?
0000096540 [ncp.at] TRACE: < ERROR
0000097540 [ncp.at] TRACE: > AT+CPIN?
0000097543 [ncp.at] TRACE: < ERROR
0000098543 [ncp.at] TRACE: > AT+CPIN?
0000098546 [ncp.at] TRACE: < ERROR
0000099546 [ncp.at] TRACE: > AT+CPIN?
0000099549 [ncp.at] TRACE: < ERROR
0000100549 [ncp.at] TRACE: > AT+CPIN?
0000100552 [ncp.at] TRACE: < ERROR
0000101552 [ncp.at] TRACE: > AT+CPIN?
0000101555 [ncp.at] TRACE: < ERROR
0000102555 [ncp.at] TRACE: > AT+CPIN?
0000102558 [ncp.at] TRACE: < ERROR
0000103558 [ncp.at] TRACE: > AT+CPIN?
0000103561 [ncp.at] TRACE: < ERROR
0000104561 [ncp.at] TRACE: > AT+CPIN?
0000104564 [ncp.at] TRACE: < ERROR
0000105564 [ncp.client] ERROR: Failed to perform early initialization
0000105565 [ncp.client] TRACE: Hard reset
0000105765 [net.pppncp] TRACE: NCP event 3
0000105766 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000105767 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000105767 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000105867 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000105868 [ncp.client] TRACE: Already on
0000105868 [net.pppncp] TRACE: NCP event 3
0000105869 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000105870 [system.nm] TRACE: Interface 4 power state changed: UP
0000107071 [ncp.at] TRACE: > AT
0000107077 [ncp.at] TRACE: < OK
0000107077 [ncp.client] TRACE: NCP ready to accept AT commands
0000107078 [ncp.at] TRACE: > AT
0000107080 [ncp.at] TRACE: < OK
0000107081 [ncp.at] TRACE: > ATI9
0000107084 [ncp.at] TRACE: < 03.15,A00.01
0000107084 [ncp.at] TRACE: < OK
0000107085 [ncp.client] TRACE: App firmware: 1
0000107085 [ncp.at] TRACE: > AT+UGPIOC?
0000107087 [ncp.at] TRACE: < +UGPIOC:
0000107088 [ncp.at] TRACE: < 16,255
0000107089 [ncp.at] TRACE: < 19,255
0000107089 [ncp.at] TRACE: < 23,0
0000107090 [ncp.at] TRACE: < 24,255
0000107090 [ncp.at] TRACE: < 25,255
0000107091 [ncp.at] TRACE: < 33,255
0000107092 [ncp.at] TRACE: < 42,255
0000107092 [ncp.at] TRACE: < 46,255
0000107093 [ncp.at] TRACE: < OK
0000107093 [ncp.at] TRACE: > AT+UGPIOR=23
0000107097 [ncp.at] TRACE: < +UGPIOR: 23,1
0000107097 [ncp.at] TRACE: < OK
0000107098 [ncp.client] INFO: Using internal SIM card
0000107098 [ncp.at] TRACE: > AT+CPIN?
0000107101 [ncp.at] TRACE: < ERROR
0000108101 [ncp.at] TRACE: > AT+CPIN?
0000108104 [ncp.at] TRACE: < ERROR
0000109103 [ncp.at] TRACE: > AT+CPIN?
0000109106 [ncp.at] TRACE: < ERROR
0000110105 [ncp.at] TRACE: > AT+CPIN?
0000110108 [ncp.at] TRACE: < ERROR
0000111107 [ncp.at] TRACE: > AT+CPIN?
0000111110 [ncp.at] TRACE: < ERROR
0000112109 [ncp.at] TRACE: > AT+CPIN?
0000112112 [ncp.at] TRACE: < ERROR
0000113111 [ncp.at] TRACE: > AT+CPIN?
0000113114 [ncp.at] TRACE: < ERROR
0000114113 [ncp.at] TRACE: > AT+CPIN?
0000114116 [ncp.at] TRACE: < ERROR
0000115115 [ncp.at] TRACE: > AT+CPIN?
0000115118 [ncp.at] TRACE: < ERROR
0000116117 [ncp.at] TRACE: > AT+CPIN?
0000116120 [ncp.at] TRACE: < ERROR
0000117119 [ncp.client] ERROR: Failed to perform early initialization
0000117120 [ncp.client] TRACE: Hard reset
0000117320 [net.pppncp] TRACE: NCP event 3
0000117321 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000117322 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000117322 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000117422 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000117423 [ncp.client] TRACE: Already on
0000117423 [net.pppncp] TRACE: NCP event 3
0000117424 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000117425 [system.nm] TRACE: Interface 4 power state changed: UP
0000118626 [ncp.at] TRACE: > AT
0000118632 [ncp.at] TRACE: < OK
0000118632 [ncp.client] TRACE: NCP ready to accept AT commands
0000118633 [ncp.at] TRACE: > AT
0000118635 [ncp.at] TRACE: < OK
0000118635 [ncp.at] TRACE: > ATI9
0000118638 [ncp.at] TRACE: < 03.15,A00.01
0000118639 [ncp.at] TRACE: < OK
0000118639 [ncp.client] TRACE: App firmware: 1
0000118640 [ncp.at] TRACE: > AT+UGPIOC?
0000118642 [ncp.at] TRACE: < +UGPIOC:
0000118643 [ncp.at] TRACE: < 16,255
0000118643 [ncp.at] TRACE: < 19,255
0000118644 [ncp.at] TRACE: < 23,0
0000118644 [ncp.at] TRACE: < 24,255
0000118645 [ncp.at] TRACE: < 25,255
0000118646 [ncp.at] TRACE: < 33,255
0000118646 [ncp.at] TRACE: < 42,255
0000118647 [ncp.at] TRACE: < 46,255
0000118648 [ncp.at] TRACE: < OK
0000118648 [ncp.at] TRACE: > AT+UGPIOR=23
0000118651 [ncp.at] TRACE: < +UGPIOR: 23,1
0000118652 [ncp.at] TRACE: < OK
0000118653 [ncp.client] INFO: Using internal SIM card
0000118653 [ncp.at] TRACE: > AT+CPIN?
0000118656 [ncp.at] TRACE: < ERROR
0000119656 [ncp.at] TRACE: > AT+CPIN?
0000119659 [ncp.at] TRACE: < ERROR
0000120659 [ncp.at] TRACE: > AT+CPIN?
0000120662 [ncp.at] TRACE: < ERROR
0000121662 [ncp.at] TRACE: > AT+CPIN?
0000121665 [ncp.at] TRACE: < ERROR
0000122665 [ncp.at] TRACE: > AT+CPIN?
0000122668 [ncp.at] TRACE: < ERROR
0000123668 [ncp.at] TRACE: > AT+CPIN?
0000123671 [ncp.at] TRACE: < ERROR
0000124671 [ncp.at] TRACE: > AT+CPIN?
0000124674 [ncp.at] TRACE: < ERROR
0000125674 [ncp.at] TRACE: > AT+CPIN?
0000125677 [ncp.at] TRACE: < ERROR
0000126677 [ncp.at] TRACE: > AT+CPIN?
0000126680 [ncp.at] TRACE: < ERROR
0000127680 [ncp.at] TRACE: > AT+CPIN?
0000127683 [ncp.at] TRACE: < ERROR
0000128683 [ncp.client] ERROR: Failed to perform early initialization
0000128684 [ncp.client] TRACE: Hard reset
0000128884 [net.pppncp] TRACE: NCP event 3
0000128885 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000128886 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000128886 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000128986 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000128987 [ncp.client] TRACE: Already on
0000128987 [net.pppncp] TRACE: NCP event 3
0000128988 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000128989 [system.nm] TRACE: Interface 4 power state changed: UP
0000130190 [ncp.at] TRACE: > AT
0000130196 [ncp.at] TRACE: < OK
0000130196 [ncp.client] TRACE: NCP ready to accept AT commands
0000130197 [ncp.at] TRACE: > AT
0000130199 [ncp.at] TRACE: < OK
0000130200 [ncp.at] TRACE: > ATI9
0000130203 [ncp.at] TRACE: < 03.15,A00.01
0000130203 [ncp.at] TRACE: < OK
0000130204 [ncp.client] TRACE: App firmware: 1
0000130204 [ncp.at] TRACE: > AT+UGPIOC?
0000130206 [ncp.at] TRACE: < +UGPIOC:
0000130207 [ncp.at] TRACE: < 16,255
0000130208 [ncp.at] TRACE: < 19,255
0000130208 [ncp.at] TRACE: < 23,0
0000130209 [ncp.at] TRACE: < 24,255
0000130210 [ncp.at] TRACE: < 25,255
0000130210 [ncp.at] TRACE: < 33,255
0000130211 [ncp.at] TRACE: < 42,255
0000130211 [ncp.at] TRACE: < 46,255
0000130212 [ncp.at] TRACE: < OK
0000130213 [ncp.at] TRACE: > AT+UGPIOR=23
0000130216 [ncp.at] TRACE: < +UGPIOR: 23,1
0000130216 [ncp.at] TRACE: < OK
0000130217 [ncp.client] INFO: Using internal SIM card
0000130218 [ncp.at] TRACE: > AT+CPIN?
0000130220 [ncp.at] TRACE: < ERROR
0000131219 [ncp.at] TRACE: > AT+CPIN?
0000131222 [ncp.at] TRACE: < ERROR
0000132221 [ncp.at] TRACE: > AT+CPIN?
0000132224 [ncp.at] TRACE: < ERROR
0000133224 [ncp.at] TRACE: > AT+CPIN?
0000133227 [ncp.at] TRACE: < ERROR
It looks like there are two separate but possibly related issues. It is unusual for this to happen to this many devices.
Situations where this happens repeatedly, even after "Hard reset" in the log, and also if you've removed the battery and USB power indicate that the modem is no longer working.
On older devices with the R410 modem, this can occur more frequently if power has been removed unexpectedly. On R510 devices (including the Boron 404X) removing the power should not cause the modem to fail, but it could be damaged by ESD or power issues, or it could be failure of the bq24195 PMIC which powers the modem. Since the MCU is on a different power rail, the MCU can still boot even if the cellular modem cannot.
The other failure is this:
This typically indicates that the MFF2 SIM card has failed. This could occur if power was removed from the SIM while it was updating, ESD, or other hardware failure. It can happen, but it would be unusual for it to happen to many devices.
Do we have any means to fix them?
I am having issues with new b404x connecting for first time as well
