We manage a few dozen Borons that we have deployed, but this is a new one on me. Wondering if this is indicative of a Particle OS bug, or else a hardware issue with this particular Boron
It is running Particle OS 4.2.0
I scraped my application's debug log file using the following regex:
.*[0-9]{10} \[(?!app)
Here are the Particle OS error messages:
E:\Downloads\Boron_Debug_OS_Messages.txt (3 hits)
Line 3501: Line 22886: 0000018041 [ncp.client] ERROR: Failed to perform early initialization
Line 3503: Line 22888: 0000018042 [ncp.client] ERROR: Cannot hard reset the modem, it's not on
Line 3504: Line 22889: 0000018042 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
which leads me to believe that perhaps this Boron has hardware damage? The modem is not on?
Here is a snippet of the Particle OS stream that smells particularly fishy:
Line 22433: 0000002845 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
Line 22434: 0000002848 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
Line 22435: 0000002849 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
Line 22436: 0000002849 [ncp.client] TRACE: Modem already on
Line 22437: 0000002849 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 22438: =======0000002850 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
Line 22486: 0000002949 [ncp.client] TRACE: Setting UART voltage translator state 0
Line 22487: 0000003049 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 22488: 0000003050 [ncp.client] TRACE: Muxer is not currently running
Line 22489: 0000003051 [ncp.client] TRACE: Initialized muxer @ 921600 baudrate
Line 22490: 0000003051 [mux] INFO: Starting GSM07.10 muxer
Line 22491: 0000003052 [mux] INFO: GSM07.10 muxer thread started
Line 22540: 0000003351 [mux] INFO: Stopping GSM07.10 muxer
Line 22541: 0000003352 [mux] INFO: Gracefully stopping GSM07.10 muxer
Line 22542: 0000003352 [mux] INFO: Closing all muxed channels
Line 22543: 0000003353 [mux] INFO: Muxed channel 1 already closed
Line 22544: 0000003353 [mux] INFO: Muxed channel 2 already closed
Line 22545: 0000003354 [mux] INFO: Muxed channel 3 already closed
Line 22546: 0000003354 [mux] INFO: Muxed channel 4 already closed
Line 22594: |\-/0000004005 [mux] INFO: Sending CLD (multiplexer close down)
Line 22601: 0000004906 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
Line 22608: 0000004956 [mux] INFO: GSM07.10 muxer thread exiting
Line 22609: 0000004956 [mux] INFO: GSM07.10 muxer stopped
Line 22610: 0000004957 [ncp.at] TRACE: > AT
Line 22654: /|\-/|\0000005957 [ncp.at] TRACE: > AT
Line 22667: 0000006957 [ncp.client] TRACE: Modem is not responsive @ 921600 baudrate
Line 22668: 0000006958 [ncp.at] TRACE: > AT
Line 22669: 0000006960 [ncp.at] TRACE: < OK
Line 22670: 0000006960 [ncp.client] TRACE: NCP ready to accept AT commands
Line 22671: 0000006961 [ncp.at] TRACE: > AT
Line 22672: 0000006963 [ncp.at] TRACE: < OK
Line 22673: 0000006964 [ncp.at] TRACE: > ATI9
Line 22674: 0000006977 [ncp.at] TRACE: < 23.60,A01.01
Line 22675: 0000006978 [ncp.at] TRACE: < OK
Line 22676: 0000006978 [ncp.client] TRACE: App firmware: 101
Line 22677: 0000006979 [ncp.at] TRACE: > AT+UGPIOC?
Line 22678: 0000006983 [ncp.at] TRACE: < +UGPIOC:
Line 22679: 0000006983 [ncp.at] TRACE: < 16,255
Line 22680: 0000006984 [ncp.at] TRACE: < 23,255
Line 22681: 0000006985 [ncp.at] TRACE: < 24,4
Line 22682: 0000006985 [ncp.at] TRACE: < 25,5
Line 22683: 0000006986 [ncp.at] TRACE: < 34,12
Line 22684: 0000006986 [ncp.at] TRACE: < 35,12
Line 22685: 0000006987 [ncp.at] TRACE: < 36,12
Line 22686: 0000006988 [ncp.at] TRACE: < 37,12
Line 22687: 0000006988 [ncp.at] TRACE: < 42,7
Line 22688: 0000006989 [ncp.at] TRACE: < OK
Line 22689: 0000006989 [ncp.client] INFO: Using internal SIM card
Line 22690: 0000006990 [ncp.at] TRACE: > AT+CPIN?
Line 22691: 0000006994 [ncp.at] TRACE: < +CPIN: READY
Line 22692: 0000006994 [ncp.at] TRACE: < OK
Line 22693: 0000006995 [ncp.at] TRACE: > AT+CCID
Line 22694: 0000007014 [ncp.at] TRACE: < +CCID: 89314404000821550960
Line 22695: 0000007015 [ncp.at] TRACE: < OK
Line 22696: 0000007015 [ncp.at] TRACE: > AT+IFC?
Line 22697: 0000007019 [ncp.at] TRACE: < +IFC: 2,2
Line 22698: 0000007020 [ncp.at] TRACE: < OK
Line 22699: 0000007020 [ncp.at] TRACE: > AT+IFC=2,2
Line 22700: 0000007023 [ncp.at] TRACE: < OK
Line 22701: 0000007023 [ncp.at] TRACE: > AT
Line 22702: \-/0000012041 [ncp.at] TRACE: > AT
Line 22756: 0000013041 [ncp.at] TRACE: > AT
Line 22772: 0000014041 [ncp.at] TRACE: > AT
Line 22816: -/|\-/|\0000015041 [ncp.at] TRACE: > AT
Line 22829: 0000016041 [ncp.at] TRACE: > AT
Line 22873: |\-/|\-/0000017041 [ncp.at] TRACE: > AT
Line 22887: 0000018042 [ncp.client] TRACE: Setting UART voltage translator state 0
Line 22933: -0000018142 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
Line 22934: 0000018142 [net.pppncp] TRACE: NCP event 3
Line 22935: 0000018143 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
Line 22936: 0000018143 [system.nm] TRACE: Interface 4 power state changed: 4
Line 22937: 0000018153 [net.pppncp] TRACE: NCP event 3
Line 22938: 0000018153 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
Line 22939: 0000018154 [system.nm] TRACE: Interface 4 power state changed: 2
Line 22940: 0000018154 [ncp.client] TRACE: Modem powered on
Line 22941: 0000018155 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 22942: /0000018255 [ncp.client] TRACE: Setting UART voltage translator state 0
Line 22943: 0000018355 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 22944: |\-/|\-/0000019356 [ncp.at] TRACE: > AT
Line 23000: |\0000020356 [ncp.at] TRACE: > AT
Line 23001: -/|\-/|\0000021356 [ncp.at] TRACE: > AT
Line 23057: -/0000022356 [ncp.at] TRACE: > AT
Line 23058: 0000022359 [ncp.at] TRACE: < OK
Line 23059: 0000022359 [ncp.client] TRACE: NCP ready to accept AT commands
Line 23060: 0000022360 [ncp.at] TRACE: > AT
Line 23061: 0000022362 [ncp.at] TRACE: < OK
Line 23062: 0000022362 [ncp.at] TRACE: > ATI9
Line 23063: 0000022381 [ncp.at] TRACE: < 23.60,A01.01
Line 23064: 0000022381 [ncp.at] TRACE: < OK
Line 23065: 0000022382 [ncp.client] TRACE: App firmware: 101
Line 23066: 0000022382 [ncp.at] TRACE: > AT+UGPIOC?
Line 23067: 0000022386 [ncp.at] TRACE: < +UGPIOC:
Line 23068: 0000022387 [ncp.at] TRACE: < 16,255
Line 23069: 0000022387 [ncp.at] TRACE: < 23,255
Line 23070: 0000022388 [ncp.at] TRACE: < 24,4
Line 23071: 0000022389 [ncp.at] TRACE: < 25,5
Line 23072: 0000022389 [ncp.at] TRACE: < 34,12
Line 23073: 0000022390 [ncp.at] TRACE: < 35,12
Line 23074: 0000022390 [ncp.at] TRACE: < 36,12
Line 23075: 0000022391 [ncp.at] TRACE: < 37,12
Line 23076: 0000022391 [ncp.at] TRACE: < 42,7
Line 23077: 0000022392 [ncp.at] TRACE: < OK
Line 23078: 0000022393 [ncp.client] INFO: Using internal SIM card
Line 23079: 0000022393 [ncp.at] TRACE: > AT+CPIN?
Line 23080: |0000022397 [ncp.at] TRACE: < ERROR
Line 23134: 0000023397 [ncp.at] TRACE: > AT+CPIN?
Line 23135: 0000023402 [ncp.at] TRACE: < +CPIN: READY
Line 23136: 0000023402 [ncp.at] TRACE: < OK
Line 23137: 0000023403 [ncp.at] TRACE: > AT+CCID
Line 23138: 0000023423 [ncp.at] TRACE: < +CCID: 89314404000821550960
Line 23139: 0000023423 [ncp.at] TRACE: < OK
Line 23140: 0000023423 [ncp.at] TRACE: > AT+IFC?
Line 23141: 0000023427 [ncp.at] TRACE: < +IFC: 2,2
Line 23142: 0000023428 [ncp.at] TRACE: < OK
Line 23143: 0000023428 [ncp.at] TRACE: > AT+IFC=2,2
Line 23144: 0000023431 [ncp.at] TRACE: < OK
Line 23145: 0000023432 [ncp.at] TRACE: > AT
Line 23204: \-/0000024432 [ncp.at] TRACE: > AT
Line 23205: 0000024435 [ncp.at] TRACE: < OK
Line 23206: 0000024435 [ncp.at] TRACE: > AT+IPR=921600
Line 23207: 0000024439 [ncp.at] TRACE: < OK
Line 23208: 0000024441 [ncp.at] TRACE: > AT
Line 23209: 0000024442 [ncp.at] TRACE: <
Line 23210: 0000024443 [ncp.at] TRACE: < OK
Line 23211: |\-/|\-0000025441 [ncp.at] TRACE: > AT
Line 23212: 0000025443 [ncp.at] TRACE: < OK
Line 23213: 0000025443 [ncp.at] TRACE: > AT+COPS=3,2
Line 23214: /0000025446 [ncp.at] TRACE: < OK
Line 23215: 0000025446 [ncp.at] TRACE: > AT+CGEREP=1,0
Line 23216: 0000025448 [ncp.at] TRACE: < OK
Line 23217: 0000025448 [ncp.at] TRACE: > AT+UPSV?
Line 23218: 0000025451 [ncp.at] TRACE: < +UPSV: 0
Line 23219: 0000025451 [ncp.at] TRACE: < OK
Line 23220: 0000025451 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
Line 23221: |0000025580 [ncp.at] TRACE: < OK
Line 23222: 0000025580 [mux] INFO: Starting GSM07.10 muxer
Line 23223: 0000025581 [mux] INFO: Opening mux channel 0
Line 23224: 0000025581 [mux] INFO: GSM07.10 muxer thread started
Line 23225: 0000025583 [mux] INFO: Opening mux channel 1
Line 23226: 0000025586 [ncp.at] TRACE: > AT
Line 23227: 0000025589 [ncp.at] TRACE: < OK
Line 23228: 0000025589 [ncp.client] TRACE: NCP state changed: 1
Line 23229: 0000025590 [net.pppncp] TRACE: NCP event 1
Line 23230: 0000025590 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
Line 23231: 0000025591 [net.ppp.client] TRACE: State NONE -> READY
Line 23232: 0000025594 [ncp.at] TRACE: > AT
Line 23233: 0000025596 [ncp.at] TRACE: < OK
Line 23234: 0000025597 [ncp.at] TRACE: > AT+CFUN?
Line 23235: 0000025600 [ncp.at] TRACE: < +CFUN: 1,0
Line 23236: 0000025600 [ncp.at] TRACE: < OK
Line 23237: 0000025601 [ncp.at] TRACE: > AT+CCID
Line 23238: 0000025618 [ncp.at] TRACE: < +CCID: 89314404000821550960
Line 23239: 0000025618 [ncp.at] TRACE: < OK
Line 23240: 0000025619 [ncp.at] TRACE: > AT+CIMI
Line 23241: 0000025622 [ncp.at] TRACE: < 204047127292930
Line 23242: 0000025623 [ncp.at] TRACE: < OK
Line 23243: 0000025623 [ncp.at] TRACE: > AT+CGDCONT?
Line 23244: 0000025628 [ncp.at] TRACE: < +CGDCONT: 1,"IP","vfd1.korem2m.com","0.0.0.0",0,0
Line 23245: 0000025628 [ncp.at] TRACE: < OK
Line 23246: 0000025629 [ncp.at] TRACE: > AT+CFUN?
Line 23247: 0000025632 [ncp.at] TRACE: < +CFUN: 1,0
Line 23248: 0000025632 [ncp.at] TRACE: < OK
Line 23249: 0000025633 [ncp.at] TRACE: > AT+CREG=2
Line 23250: 0000025636 [ncp.at] TRACE: < OK
Line 23251: 0000025636 [ncp.at] TRACE: > AT+CGREG=2
Line 23252: 0000025639 [ncp.at] TRACE: < OK
Line 23253: 0000025640 [ncp.client] TRACE: NCP connection state changed: 1
Line 23254: 0000025640 [net.pppncp] TRACE: NCP event 2
Line 23255: 0000025640 [net.pppncp] TRACE: State changed event: 1
Line 23256: 0000025641 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
Line 23257: 0000025642 [ncp.at] TRACE: > AT+COPS?
Line 23258: 0000025644 [ncp.at] TRACE: < +COPS: 0
Line 23259: 0000025645 [ncp.at] TRACE: < OK
Line 23260: 0000025646 [ncp.at] TRACE: > AT+CREG?
Line 23261: 0000025649 [ncp.at] TRACE: < +CREG: 2,0
Line 23262: 0000025649 [ncp.at] TRACE: < OK
Line 23263: 0000025650 [ncp.at] TRACE: > AT+CGREG?
Line 23264: 0000025652 [ncp.at] TRACE: < +CGREG: 2,0
Line 23265: 0000025653 [ncp.at] TRACE: < OK
Line 23344: /===================================0000002860 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
Line 23345: 0000002862 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
Line 23347: ===============DEBUG DUMP==0000002863 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
Line 23348: 0000002864 [ncp.client] TRACE: Modem already on
Line 23349: 0000002864 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 23354: 0000002865 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
Line 23398: 0000002964 [ncp.client] TRACE: Setting UART voltage translator state 0
Line 23399: 0000003064 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 23400: 0000003065 [ncp.client] TRACE: Muxer is not currently running
Line 23401: 0000003066 [ncp.client] TRACE: Initialized muxer @ 921600 baudrate
Line 23402: 0000003066 [mux] INFO: Starting GSM07.10 muxer
Line 23403: 0000003067 [mux] INFO: GSM07.10 muxer thread started
Line 23464: 0000003366 [mux] INFO: Stopping GSM07.10 muxer
Line 23465: 0000003366 [mux] INFO: Gracefully stopping GSM07.10 muxer
Line 23466: 0000003367 [mux] INFO: Closing all muxed channels
Line 23467: 0000003367 [mux] INFO: Muxed channel 1 already closed
Line 23468: 0000003368 [mux] INFO: Muxed channel 2 already closed
Line 23469: 0000003368 [mux] INFO: Muxed channel 3 already closed
Line 23470: 0000003368 [mux] INFO: Muxed channel 4 already closed
Line 23520: |\-/0000004019 [mux] INFO: Sending CLD (multiplexer close down)
Line 23527: 0000004920 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
Line 23534: 0000004970 [mux] INFO: GSM07.10 muxer thread exiting
Line 23535: 0000004971 [mux] INFO: GSM07.10 muxer stopped
Line 23536: 0000004971 [ncp.at] TRACE: > AT
Line 23580: /|\-/|\0000005972 [ncp.at] TRACE: > AT
Line 23593: 0000006972 [ncp.client] TRACE: Modem is not responsive @ 921600 baudrate
Line 23594: 0000006973 [ncp.at] TRACE: > AT
Line 23595: 0000006974 [ncp.at] TRACE: < �AT
Line 23596: 0000006975 [ncp.at] TRACE: < OK
Line 23640: \-/|\-/0000007975 [ncp.at] TRACE: > AT
Line 23641: 0000007977 [ncp.at] TRACE: < OK
Line 23642: 0000007978 [ncp.client] TRACE: NCP ready to accept AT commands
Line 23643: 0000007978 [ncp.at] TRACE: > AT
Line 23644: 0000007980 [ncp.at] TRACE: < OK
Line 23645: 0000007980 [ncp.at] TRACE: > ATI9
Line 23646: 0000007994 [ncp.at] TRACE: < 23.60,A01.01
Line 23647: 0000007995 [ncp.at] TRACE: < OK
Line 23648: 0000007995 [ncp.client] TRACE: App firmware: 101
Line 23649: 0000007996 [ncp.at] TRACE: > AT+UGPIOC?
Line 23650: 0000008000 [ncp.at] TRACE: < +UGPIOC:
Line 23651: 0000008000 [ncp.at] TRACE: < 16,255
Line 23652: 0000008001 [ncp.at] TRACE: < 23,255
Line 23653: 0000008002 [ncp.at] TRACE: < 24,4
Line 23654: 0000008002 [ncp.at] TRACE: < 25,5
Line 23655: 0000008003 [ncp.at] TRACE: < 34,12
Line 23656: 0000008003 [ncp.at] TRACE: < 35,12
Line 23657: 0000008004 [ncp.at] TRACE: < 36,12
Line 23658: 0000008004 [ncp.at] TRACE: < 37,12
Line 23659: 0000008005 [ncp.at] TRACE: < 42,7
Line 23660: 0000008006 [ncp.at] TRACE: < OK
Line 23661: 0000008006 [ncp.client] INFO: Using internal SIM card
Line 23662: 0000008007 [ncp.at] TRACE: > AT+CPIN?
Line 23663: 0000008011 [ncp.at] TRACE: < +CPIN: READY
Line 23664: 0000008012 [ncp.at] TRACE: < OK
Line 23665: 0000008012 [ncp.at] TRACE: > AT+CCID
Line 23666: 0000008032 [ncp.at] TRACE: < +CCID: 89314404000821550960
Line 23667: 0000008032 [ncp.at] TRACE: < OK
Line 23668: 0000008033 [ncp.at] TRACE: > AT+IFC?
Line 23669: 0000008036 [ncp.at] TRACE: < +IFC: 2,2
Line 23670: 0000008037 [ncp.at] TRACE: < OK
Line 23671: 0000008037 [ncp.at] TRACE: > AT+IFC=2,2
Line 23672: 0000008040 [ncp.at] TRACE: < OK
Line 23673: 0000008041 [ncp.at] TRACE: > AT
Line 23697: /=0000002845 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
Line 23698: 0000002846 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
Line 23699: 0000002847 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
Line 23700: 0000002847 [ncp.client] TRACE: Modem already on
Line 23701: 0000002847 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 23703: ========0000002849 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
Line 23733: 0000002948 [ncp.client] TRACE: Setting UART voltage translator state 0
Line 23752: 0000003048 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 23753: 0000003048 [ncp.client] TRACE: Muxer is not currently running
Line 23754: 0000003050 [ncp.client] TRACE: Initialized muxer @ 921600 baudrate
Line 23755: 0000003050 [mux] INFO: Starting GSM07.10 muxer
Line 23756: 0000003051 [mux] INFO: GSM07.10 muxer thread started
Line 23790: 0000003351 [mux] INFO: Stopping GSM07.10 muxer
Line 23791: 0000003351 [mux] INFO: Gracefully stopping GSM07.10 muxer
Line 23792: 0000003352 [mux] INFO: Closing all muxed channels
Line 23793: 0000003352 [mux] INFO: Muxed channel 1 already closed
Line 23794: 0000003352 [mux] INFO: Muxed channel 2 already closed
Line 23795: 0000003353 [mux] INFO: Muxed channel 3 already closed
Line 23796: 0000003354 [mux] INFO: Muxed channel 4 already closed
Line 23797: 0000004004 [mux] INFO: Sending CLD (multiplexer close down)
Line 23798: 0000004905 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
Line 23799: -/|\-0000006960 [ncp.client] TRACE: Modem is not responsive @ 921600 baudrate
Line 23800: 0000006961 [ncp.at] TRACE: > AT
Line 23801: 0000006963 [ncp.at] TRACE: < OK
Line 23802: 0000006963 [ncp.client] TRACE: NCP ready to accept AT commands
Line 23803: 0000006964 [ncp.at] TRACE: > AT
Line 23804: 0000006966 [ncp.at] TRACE: < OK
Line 23805: 0000006966 [ncp.at] TRACE: > ATI9
Line 23806: /0000006980 [ncp.at] TRACE: < 23.60,A01.01
Line 23807: 0000006981 [ncp.at] TRACE: < OK
Line 23808: 0000006981 [ncp.client] TRACE: App firmware: 101
Line 23809: 0000006981 [ncp.at] TRACE: > AT+UGPIOC?
Line 23810: 0000006985 [ncp.at] TRACE: < +UGPIOC:
Line 23811: 0000006986 [ncp.at] TRACE: < 16,255
Line 23812: 0000006987 [ncp.at] TRACE: < 23,255
Line 23813: 0000006987 [ncp.at] TRACE: < 24,4
Line 23814: 0000006988 [ncp.at] TRACE: < 25,5
Line 23815: 0000006988 [ncp.at] TRACE: < 34,12
Line 23816: 0000006989 [ncp.at] TRACE: < 35,12
Line 23817: 0000006989 [ncp.at] TRACE: < 36,12
Line 23818: 0000006990 [ncp.at] TRACE: < 37,12
Line 23819: 0000006991 [ncp.at] TRACE: < 42,7
Line 23820: 0000006991 [ncp.at] TRACE: < OK
Line 23821: 0000006992 [ncp.client] INFO: Using internal SIM card
Line 23822: 0000006992 [ncp.at] TRACE: > AT+CPIN?
Line 23823: 0000006996 [ncp.at] TRACE: < +CPIN: READY
Line 23824: 0000006997 [ncp.at] TRACE: < OK
Line 23825: 0000006997 [ncp.at] TRACE: > AT+CCID
Line 23826: 0000007018 [ncp.at] TRACE: < +CCID: 89314404000821550960
Line 23827: 0000007019 [ncp.at] TRACE: < OK
Line 23828: 0000007019 [ncp.at] TRACE: > AT+IFC?
Line 23829: 0000007022 [ncp.at] TRACE: < +IFC: 2,2
Line 23830: 0000007023 [ncp.at] TRACE: < OK
Line 23831: 0000007023 [ncp.at] TRACE: > AT+IFC=2,2
Line 23832: 0000007027 [ncp.at] TRACE: < OK
Line 23833: 0000007027 [ncp.at] TRACE: > AT
Line 23889: -/|\0000008027 [ncp.at] TRACE: > AT
Line 23890: 0000008029 [ncp.at] TRACE: < OK
Line 23891: 0000008030 [ncp.at] TRACE: > AT+IPR=921600
Line 23892: 0000008034 [ncp.at] TRACE: < OK
Line 23893: 0000008035 [ncp.at] TRACE: > AT
Line 23894: 0000008036 [ncp.at] TRACE: <
Line 23895: 0000008037 [ncp.at] TRACE: < OK
Line 23896: -/|\-/|\0000009036 [ncp.at] TRACE: > AT
Line 23897: 0000009038 [ncp.at] TRACE: < OK
Line 23898: 0000009038 [ncp.at] TRACE: > AT+COPS=3,2
Line 23899: 0000009040 [ncp.at] TRACE: < OK
Line 23900: 0000009040 [ncp.at] TRACE: > AT+CGEREP=1,0
Line 23901: 0000009043 [ncp.at] TRACE: < OK
Line 23902: 0000009043 [ncp.at] TRACE: > AT+UPSV?
Line 23903: 0000009045 [ncp.at] TRACE: < +UPSV: 0
Line 23904: 0000009045 [ncp.at] TRACE: < OK
Line 23905: 0000009045 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
Line 23906: -0000009178 [ncp.at] TRACE: < OK
Line 23907: 0000009178 [mux] INFO: Starting GSM07.10 muxer
Line 23908: 0000009179 [mux] INFO: Opening mux channel 0
Line 23909: 0000009180 [mux] INFO: GSM07.10 muxer thread started
Line 23910: 0000009182 [mux] INFO: Opening mux channel 1
Line 23911: 0000009185 [ncp.at] TRACE: > AT
Line 23912: /0000009188 [ncp.at] TRACE: < OK
Line 23913: 0000009188 [ncp.client] TRACE: NCP state changed: 1
Line 23914: 0000009188 [net.pppncp] TRACE: NCP event 1
Line 23915: 0000009189 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
Line 23916: 0000009190 [net.ppp.client] TRACE: State NONE -> READY
Line 23917: 0000009193 [ncp.at] TRACE: > AT+CFUN?
Line 23918: 0000009196 [ncp.at] TRACE: < +CFUN: 1,0
Line 23919: 0000009196 [ncp.at] TRACE: < OK
Line 23920: 0000009197 [ncp.at] TRACE: > AT+CCID
Line 23921: 0000009214 [ncp.at] TRACE: < +CCID: 89314404000821550960
Line 23922: 0000009214 [ncp.at] TRACE: < OK
Line 23923: 0000009215 [ncp.at] TRACE: > AT+CIMI
Line 23924: 0000009218 [ncp.at] TRACE: < 204047127292930
Line 23925: 0000009218 [ncp.at] TRACE: < OK
Line 23926: 0000009220 [ncp.at] TRACE: > AT+CGDCONT?
Line 23927: 0000009223 [ncp.at] TRACE: < +CGDCONT: 1,"IP","vfd1.korem2m.com","0.0.0.0",0,0
Line 23928: 0000009224 [ncp.at] TRACE: < OK
Line 23929: 0000009225 [ncp.at] TRACE: > AT+CFUN?
Line 23930: 0000009228 [ncp.at] TRACE: < +CFUN: 1,0
Line 23931: 0000009228 [ncp.at] TRACE: < OK
Line 23932: 0000009229 [ncp.at] TRACE: > AT+CREG=2
Line 23933: 0000009231 [ncp.at] TRACE: < OK
Line 23934: 0000009232 [ncp.at] TRACE: > AT+CGREG=2
Line 23935: 0000009235 [ncp.at] TRACE: < OK
Line 23936: 0000009235 [ncp.client] TRACE: NCP connection state changed: 1
Line 23937: 0000009235 [net.pppncp] TRACE: NCP event 2
Line 23938: 0000009236 [net.pppncp] TRACE: State changed event: 1
Line 23939: 0000009236 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
Line 23940: 0000009237 [ncp.at] TRACE: > AT+COPS?
Line 23941: 0000009240 [ncp.at] TRACE: < +COPS: 0
Line 23942: 0000009240 [ncp.at] TRACE: < OK
Line 23943: 0000009243 [ncp.at] TRACE: > AT+CREG?
Line 23944: 0000009245 [ncp.at] TRACE: < +CREG: 2,0
Line 23945: 0000009246 [ncp.at] TRACE: < OK
Line 23946: 0000009247 [ncp.at] TRACE: > AT+CGREG?
Line 23947: 0000009250 [ncp.at] TRACE: < +CGREG: 2,0
Line 23948: 0000009250 [ncp.at] TRACE: < OK
Line 24004: |\-0000003968 [mux] INFO: Sending CLD (multiplexer close down)
Line 24005: 0000004869 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
Line 24006: 0000004919 [mux] INFO: GSM07.10 muxer thread exiting
Line 24007: 0000004919 [mux] INFO: GSM07.10 muxer stopped
Line 24008: 0000004920 [ncp.at] TRACE: > AT
Line 24120: \-/0000005920 [ncp.at] TRACE: > AT
Line 24121: |\-/|\-/0000006920 [ncp.client] TRACE: Modem is not responsive @ 921600 baudrate
Line 24122: 0000006921 [ncp.at] TRACE: > AT
Line 24123: 0000006923 [ncp.at] TRACE: < OK
Line 24124: 0000006924 [ncp.client] TRACE: NCP ready to accept AT commands
Line 24125: 0000006924 [ncp.at] TRACE: > AT
Line 24126: 0000006926 [ncp.at] TRACE: < OK
Line 24127: 0000006927 [ncp.at] TRACE: > ATI9
Line 24128: 0000006941 [ncp.at] TRACE: < 23.60,A01.01
Line 24129: 0000006941 [ncp.at] TRACE: < OK
Line 24130: 0000006941 [ncp.client] TRACE: App firmware: 101
Line 24131: 0000006942 [ncp.at] TRACE: > AT+UGPIOC?
Line 24132: 0000006946 [ncp.at] TRACE: < +UGPIOC:
Line 24133: 0000006946 [ncp.at] TRACE: < 16,255
Line 24134: 0000006947 [ncp.at] TRACE: < 23,255
Line 24135: 0000006948 [ncp.at] TRACE: < 24,4
Line 24136: 0000006948 [ncp.at] TRACE: < 25,5
Line 24137: 0000006949 [ncp.at] TRACE: < 34,12
Line 24138: 0000006949 [ncp.at] TRACE: < 35,12
Line 24139: 0000006950 [ncp.at] TRACE: < 36,12
Line 24140: 0000006951 [ncp.at] TRACE: < 37,12
Line 24141: 0000006951 [ncp.at] TRACE: < 42,7
Line 24142: 0000006952 [ncp.at] TRACE: < OK
Line 24143: 0000006952 [ncp.client] INFO: Using internal SIM card
Line 24144: 0000006952 [ncp.at] TRACE: > AT+CPIN?
Line 24145: 0000006957 [ncp.at] TRACE: < +CPIN: READY
Line 24146: 0000006957 [ncp.at] TRACE: < OK
Line 24147: 0000006958 [ncp.at] TRACE: > AT+CCID
Line 24148: 0000006977 [ncp.at] TRACE: < +CCID: 89314404000821550960
Line 24149: 0000006978 [ncp.at] TRACE: < OK
Line 24150: 0000006978 [ncp.at] TRACE: > AT+IFC?
Line 24151: |0000006982 [ncp.at] TRACE: < +IFC: 2,2
Line 24152: 0000006982 [ncp.at] TRACE: < OK
Line 24153: 0000006983 [ncp.at] TRACE: > AT+IFC=2,2
Line 24154: 0000006986 [ncp.at] TRACE: < OK
Line 24155: 0000006986 [ncp.at] TRACE: > AT
Line 24211: -/|\-0000007987 [ncp.at] TRACE: > AT
Line 24212: 0000007989 [ncp.at] TRACE: < OK
Line 24213: 0000007990 [ncp.at] TRACE: > AT+IPR=921600
Line 24214: 0000007994 [ncp.at] TRACE: < OK
Line 24215: 0000007995 [ncp.at] TRACE: > AT
Line 24216: 0000007996 [ncp.at] TRACE: <
Line 24217: 0000007997 [ncp.at] TRACE: < OK
Line 24245: 0000002845 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
Line 24253: 0000002852 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
Line 24254: 0000002855 [ncp.client] TRACE: Powering modem on, ncpId: 0x42
Line 24255: 0000002855 [ncp.client] TRACE: Modem already on
Line 24256: 0000002856 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 24259: 0000002857 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
Line 24295: 0000002956 [ncp.client] TRACE: Setting UART voltage translator state 0
Line 24296: 0000003056 [ncp.client] TRACE: Setting UART voltage translator state 1
Line 24297: 0000003057 [ncp.client] TRACE: Muxer is not currently running
Line 24298: 0000003058 [ncp.client] TRACE: Initialized muxer @ 921600 baudrate
Line 24299: 0000003058 [mux] INFO: Starting GSM07.10 muxer
Line 24300: 0000003059 [mux] INFO: GSM07.10 muxer thread started
Line 24350: 0000003358 [mux] INFO: Stopping GSM07.10 muxer
Line 24351: 0000003359 [mux] INFO: Gracefully stopping GSM07.10 muxer
Line 24352: 0000003359 [mux] INFO: Closing all muxed channels
Line 24353: 0000003359 [mux] INFO: Muxed channel 1 already closed
Line 24354: 0000003360 [mux] INFO: Muxed channel 2 already closed
Line 24355: 0000003360 [mux] INFO: Muxed channel 3 already closed
Line 24356: 0000003361 [mux] INFO: Muxed channel 4 already closed
Line 24403: |\-/0000004011 [mux] INFO: Sending CLD (multiplexer close down)
Line 24412: 0000004912 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
Line 24417: 0000004963 [mux] INFO: GSM07.10 muxer thread exiting
Line 24418: 0000004964 [mux] INFO: GSM07.10 muxer stopped
Line 24419: 0000004964 [ncp.at] TRACE: > AT
Line 24463: /|\-/|\0000005965 [ncp.at] TRACE: > AT
Line 24476: 0000006965 [ncp.client] TRACE: Modem is not responsive @ 921600 baudrate
What can you do with a drunken Boron?
