I’ve already submitted a ticket but a device that had been publishing data out in the field for days is now unabled to connect (likely after a battery running out of power). The LTE Boron is blinking green and after running the clouddebug tool I get logs that seem to indicate a bricked modem (I’ll post these as a comment). From what I’ve seen on this forum, this was a common failure about a year ago but was supposedly resolved. So my questions are as follows:
- Can somone confirm from logs that I’ve correctly identified the issue?
- Is anyone else seeing this issue with Device OS 2.0.1?
- Is there a way to recover a device’s modem in this state?
- How can I prevent this from happening to devices out in the field?
Hi @rkast4321 - can you please open a support ticket that references the device’s Serial Number so we can take a closer look? Can you also please provide the complete log (at least 10 minutes, however redundant) from cloud debug?
Can you also please note whether or not you are using a 3rd Party SIM?
A ticket has already been submitted with the device ID, ticket # is 101283. It is using the built in SIM card, so not 3rd party. And I’ll attach logs momentarily.
0000036152 [hal] ERROR: No response from NCP
deviceID=e00fce68f7ab565d07fdaba0
manufacturer=
model=
firmware version=
ordering code=
IMEI=
IMSI=
ICCID=
0000117152 [app] INFO: enabling trace logging
0000117153 [ncp.at] TRACE: > AT+CGDCONT?
0000127154 [ncp.at] TRACE: > AT+CSQ
attempting to connect to the cellular network…
0000137156 [system.nm] INFO: State changed: IFACE_DOWN → IFACE_REQUEST_UP
0000137160 [hal] TRACE: PPP netif → 8
0000137161 [net.ifapi] INFO: Netif pp3 state UP
0000137164 [hal] TRACE: Powering modem on
0000137166 [system.nm] INFO: State changed: IFACE_REQUEST_UP → IFACE_UP
0000137315 [hal] TRACE: Modem powered on
0000137317 [hal] TRACE: Setting UART voltage translator state 1
0000138319 [ncp.at] TRACE: > AT
0000139320 [ncp.at] TRACE: > AT
0000140320 [ncp.at] TRACE: > AT
0000141320 [ncp.at] TRACE: > AT
0000142320 [ncp.at] TRACE: > AT
0000143320 [ncp.at] TRACE: > AT
0000144320 [ncp.at] TRACE: > AT
0000145321 [ncp.at] TRACE: > AT
0000146321 [ncp.at] TRACE: > AT
0000147321 [ncp.at] TRACE: > AT
0000148321 [ncp.at] TRACE: > AT
0000149321 [ncp.at] TRACE: > AT
0000150322 [ncp.at] TRACE: > AT
0000151322 [ncp.at] TRACE: > AT
0000152322 [ncp.at] TRACE: > AT
0000153322 [ncp.at] TRACE: > AT
0000154322 [ncp.at] TRACE: > AT
0000155322 [ncp.at] TRACE: > AT
0000156322 [ncp.at] TRACE: > AT
0000157323 [ncp.at] TRACE: > AT
0000158323 [hal] ERROR: No response from NCP
0000158324 [hal] TRACE: Setting UART voltage translator state 0
0000158326 [hal] TRACE: Hard resetting the modem
0000169327 [net.pppncp] TRACE: Failed to initialize ublox NCP client: -210
0000169328 [hal] TRACE: Setting UART voltage translator state 0
0000169330 [hal] TRACE: Modem already off
0000169431 [hal] TRACE: Powering modem on
0000169581 [hal] TRACE: Modem powered on
0000169583 [hal] TRACE: Setting UART voltage translator state 1
0000170584 [ncp.at] TRACE: > AT
0000171584 [ncp.at] TRACE: > AT
0000172585 [ncp.at] TRACE: > AT
0000173585 [ncp.at] TRACE: > AT
0000174585 [ncp.at] TRACE: > AT
0000175586 [ncp.at] TRACE: > AT
0000176586 [ncp.at] TRACE: > AT
0000177586 [ncp.at] TRACE: > AT
0000178586 [ncp.at] TRACE: > AT
0000179586 [ncp.at] TRACE: > AT
0000180586 [ncp.at] TRACE: > AT
0000181586 [ncp.at] TRACE: > AT
0000182586 [ncp.at] TRACE: > AT
0000183586 [ncp.at] TRACE: > AT
0000184587 [ncp.at] TRACE: > AT
0000185587 [ncp.at] TRACE: > AT
0000186587 [ncp.at] TRACE: > AT
0000187587 [ncp.at] TRACE: > AT
0000188587 [ncp.at] TRACE: > AT
0000189587 [ncp.at] TRACE: > AT
0000190587 [hal] ERROR: No response from NCP
0000190589 [hal] TRACE: Setting UART voltage translator state 0
0000190591 [hal] TRACE: Hard resetting the modem
0000201592 [net.pppncp] TRACE: Failed to initialize ublox NCP client: -210
0000201594 [hal] TRACE: Setting UART voltage translator state 0
0000201596 [hal] TRACE: Modem already off
0000201697 [hal] TRACE: Powering modem on
0000201847 [hal] TRACE: Modem powered on
0000201848 [hal] TRACE: Setting UART voltage translator state 1
0000202850 [ncp.at] TRACE: > AT
0000203850 [ncp.at] TRACE: > AT
0000204850 [ncp.at] TRACE: > AT
0000205850 [ncp.at] TRACE: > AT
0000206850 [ncp.at] TRACE: > AT
0000207850 [ncp.at] TRACE: > AT
0000208850 [ncp.at] TRACE: > AT
0000209850 [ncp.at] TRACE: > AT
0000210850 [ncp.at] TRACE: > AT
0000211851 [ncp.at] TRACE: > AT
0000212851 [ncp.at] TRACE: > AT
0000213852 [ncp.at] TRACE: > AT
0000214853 [ncp.at] TRACE: > AT
0000215853 [ncp.at] TRACE: > AT
0000216853 [ncp.at] TRACE: > AT
0000217853 [ncp.at] TRACE: > AT
0000218853 [ncp.at] TRACE: > AT
0000219853 [ncp.at] TRACE: > AT
0000220853 [ncp.at] TRACE: > AT
0000221853 [ncp.at] TRACE: > AT
0000222853 [hal] ERROR: No response from NCP
0000222855 [hal] TRACE: Setting UART voltage translator state 0
0000222857 [hal] TRACE: Hard resetting the modem
0000233858 [net.pppncp] TRACE: Failed to initialize ublox NCP client: -210
0000233860 [hal] TRACE: Setting UART voltage translator state 0
0000233862 [hal] TRACE: Modem already off
0000233963 [hal] TRACE: Powering modem on
0000234114 [hal] TRACE: Modem powered on
0000234115 [hal] TRACE: Setting UART voltage translator state 1
0000235116 [ncp.at] TRACE: > AT
0000236116 [ncp.at] TRACE: > AT
0000237116 [ncp.at] TRACE: > AT
0000238116 [ncp.at] TRACE: > AT
0000239116 [ncp.at] TRACE: > AT
0000240116 [ncp.at] TRACE: > AT
0000241117 [ncp.at] TRACE: > AT
0000242117 [ncp.at] TRACE: > AT
0000243117 [ncp.at] TRACE: > AT
0000244117 [ncp.at] TRACE: > AT
0000245118 [ncp.at] TRACE: > AT
0000246118 [ncp.at] TRACE: > AT
0000247118 [ncp.at] TRACE: > AT
0000248118 [ncp.at] TRACE: > AT
0000249118 [ncp.at] TRACE: > AT
0000250118 [ncp.at] TRACE: > AT
0000251118 [ncp.at] TRACE: > AT
0000252118 [ncp.at] TRACE: > AT
0000253118 [ncp.at] TRACE: > AT
0000254118 [ncp.at] TRACE: > AT
0000255118 [hal] ERROR: No response from NCP
0000255120 [hal] TRACE: Setting UART voltage translator state 0
0000255122 [hal] TRACE: Hard resetting the modem
0000266122 [net.pppncp] TRACE: Failed to initialize ublox NCP client: -210
0000266124 [hal] TRACE: Setting UART voltage translator state 0
0000266126 [hal] TRACE: Modem already off
0000266227 [hal] TRACE: Powering modem on
0000266377 [hal] TRACE: Modem powered on
0000266378 [hal] TRACE: Setting UART voltage translator state 1
0000267380 [ncp.at] TRACE: > AT
0000268381 [ncp.at] TRACE: > AT
0000269381 [ncp.at] TRACE: > AT
0000270381 [ncp.at] TRACE: > AT
0000271381 [ncp.at] TRACE: > AT
0000272381 [ncp.at] TRACE: > AT
0000273381 [ncp.at] TRACE: > AT
0000274381 [ncp.at] TRACE: > AT
0000275381 [ncp.at] TRACE: > AT
0000276381 [ncp.at] TRACE: > AT
0000277381 [ncp.at] TRACE: > AT
0000278381 [ncp.at] TRACE: > AT
0000279381 [ncp.at] TRACE: > AT
0000280381 [ncp.at] TRACE: > AT
0000281381 [ncp.at] TRACE: > AT
0000282382 [ncp.at] TRACE: > AT
0000283382 [ncp.at] TRACE: > AT
0000284382 [ncp.at] TRACE: > AT
0000285382 [ncp.at] TRACE: > AT
0000286383 [ncp.at] TRACE: > AT
0000287383 [hal] ERROR: No response from NCP
0000287384 [hal] TRACE: Setting UART voltage translator state 0
0000287386 [hal] TRACE: Hard resetting the modem
0000298387 [net.pppncp] TRACE: Failed to initialize ublox NCP client: -210
0000298389 [hal] TRACE: Setting UART voltage translator state 0
0000298391 [hal] TRACE: Modem already off
0000298492 [hal] TRACE: Powering modem on
0000298643 [hal] TRACE: Modem powered on
0000298645 [hal] TRACE: Setting UART voltage translator state 1
0000299646 [ncp.at] TRACE: > AT
0000300646 [ncp.at] TRACE: > AT
0000301647 [ncp.at] TRACE: > AT
0000302647 [ncp.at] TRACE: > AT
0000303647 [ncp.at] TRACE: > AT
0000304647 [ncp.at] TRACE: > AT
0000306647 [ncp.at] TRACE: > AT
0000307647 [ncp.at] TRACE: > AT
0000308647 [ncp.at] TRACE: > AT
0000309647 [ncp.at] TRACE: > AT
0000310647 [ncp.at] TRACE: > AT
0000311647 [ncp.at] TRACE: > AT
0000312647 [ncp.at] TRACE: > AT
0000313647 [ncp.at] TRACE: > AT
0000314647 [ncp.at] TRACE: > AT
0000315647 [ncp.at] TRACE: > AT
0000317647 [ncp.at] TRACE: > AT
0000318647 [ncp.at] TRACE: > AT
0000319647 [hal] ERROR: No response from NCP
0000319649 [hal] TRACE: Setting UART voltage translator state 0
0000319651 [hal] TRACE: Hard resetting the modem
