We’ve deployed our products with Particle Boron (BRN402) and we’re observing that some Borons just suddenly stop connecting. We’ve had this issue with more than a few Borons this year. Cloud debug logs below from the latest Boron that has this issue:
[2022-11-16 21:41:58.630] 0000033386 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.630] 0000034386 [ncp.client] TRACE: Modem is not responsive @ 115200 baudrate
[2022-11-16 21:41:58.637] 0000034386 [ncp.client] ERROR: No response from NCP
[2022-11-16 21:41:58.638] 0000034387 [ncp.client] TRACE: Setting UART voltage translator state 0
[2022-11-16 21:41:58.638] 0000034387 [ncp.client] TRACE: Hard resetting the modem
[2022-11-16 21:41:58.638] 0000034387 [ncp.client] TRACE: Modem waiting up to 30s to power off with PWR_UC...
[2022-11-16 21:41:58.638] 0000075487 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:41:58.638] 0000075487 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
[2022-11-16 21:41:58.638] 0000075487 [system.nm] TRACE: Interface 4 power state changed: 1
[2022-11-16 21:41:58.638] 0000075488 [ncp.client] TRACE: Deinit modem serial.
[2022-11-16 21:41:58.638] 0000075489 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
[2022-11-16 21:41:58.638] 0000075489 [app] INFO: modem is not yet responding
[2022-11-16 21:41:58.638] 0000075490 [app] INFO: Still trying to connect to cellular 00:52
[2022-11-16 21:41:58.638] 0000075490 [app] INFO: Power source: USB Host
[2022-11-16 21:41:58.638] 0000075492 [app] INFO: Battery state: charged, SoC: 99.89
[2022-11-16 21:41:58.638] 0000075506 [app] INFO: modem is not yet responding
[2022-11-16 21:41:58.638] 0000075589 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
[2022-11-16 21:41:58.638] 0000075589 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:41:58.638] 0000075590 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
[2022-11-16 21:41:58.647] 0000075590 [system.nm] TRACE: Interface 4 power state changed: 4
[2022-11-16 21:41:58.647] 0000075740 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:41:58.647] 0000075740 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
[2022-11-16 21:41:58.647] 0000075740 [system.nm] TRACE: Interface 4 power state changed: 2
[2022-11-16 21:41:58.647] 0000075741 [ncp.client] TRACE: Modem powered on
[2022-11-16 21:41:58.647] 0000075741 [ncp.client] TRACE: Setting UART voltage translator state 1
[2022-11-16 21:41:58.647] 0000075841 [ncp.client] TRACE: Setting UART voltage translator state 0
[2022-11-16 21:41:58.647] 0000075941 [ncp.client] TRACE: Setting UART voltage translator state 1
[2022-11-16 21:41:58.647] > 0000076942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000077942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000078942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000079942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000080942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000081942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000082942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000083942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000084942 [ncp.at] TRACE: > AT
[2022-11-16 21:41:58.647] 0000085489 [app] INFO: Still trying to connect to cellular 01:02
[2022-11-16 21:41:58.647] 0000085489 [app] INFO: Power source: USB Host
[2022-11-16 21:41:58.647] 0000085492 [app] INFO: Battery state: charged, SoC: 99.89
[2022-11-16 21:42:22.116] Particle Cloud Debugging Tool
[2022-11-16 21:42:22.116] Enter 'help' command to list available commands
[2022-11-16 21:42:22.116] > 0000015477 [app] INFO: Starting Tests!
[2022-11-16 21:42:36.726] 0000015477 [app] INFO: Platform: Boron
[2022-11-16 21:42:36.726] 0000015477 [app] INFO: Binary compiled for: 4.0.0
[2022-11-16 21:42:36.726] 0000015478 [app] INFO: Cloud Debug Release 4.0.5
[2022-11-16 21:42:36.726] 0000015478 [app] INFO: System version: 4.0.0
[2022-11-16 21:42:36.727] 0000015479 [app] INFO: Device ID: e00fce68361717c9c8ba8d5f
[2022-11-16 21:42:36.729] 0000015479 [app] INFO: Power source: USB Host
[2022-11-16 21:42:36.729] 0000015482 [app] INFO: Battery state: charged, SoC: 99.89
[2022-11-16 21:42:36.730] 0000015482 [app] INFO: This device could have Ethernet (is 3rd generation)
[2022-11-16 21:42:36.731] 0000015483 [app] INFO: FEATURE_ETHERNET_DETECTION not enabled, so Ethernet will not be used (even i
[2022-11-16 21:42:44.739] 0000023492 [app] INFO: deviceID: e00fce68361717c9c8ba8d5f
[2022-11-16 21:42:44.739] 0000023493 [app] INFO: PMIC inputVoltageLimit: 3880 mV
[2022-11-16 21:42:44.741] 0000023494 [app] INFO: PMIC inputCurrentLimit: 500 mA
[2022-11-16 21:42:44.744] 0000023495 [app] INFO: PMIC minimumSystemVoltage: 3500 mV
[2022-11-16 21:42:44.744] 0000023496 [app] INFO: PMIC chargeCurrentValue: 896 mA
[2022-11-16 21:42:44.745] 0000023496 [app] INFO: PMIC chargeVoltageValue: 4112 mV
[2022-11-16 21:42:44.747] 0000023497 [app] INFO: modem is not yet responding
[2022-11-16 21:42:44.747] 0000023498 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
[2022-11-16 21:42:44.748] 0000023498 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
[2022-11-16 21:42:44.748] 0000023500 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
[2022-11-16 21:42:44.750] 0000023500 [ncp.client] TRACE: Modem already on
[2022-11-16 21:42:44.751] 0000023500 [ncp.client] TRACE: Setting UART voltage translator state 1
[2022-11-16 21:42:44.753] 0000023501 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
[2022-11-16 21:42:44.755] 0000023512 [app] INFO: Still trying to connect to cellular 00:00
[2022-11-16 21:42:44.758] 0000023512 [app] INFO: Power source: USB Host
[2022-11-16 21:42:44.758] 0000023515 [app] INFO: Battery state: charged, SoC: 99.89
[2022-11-16 21:42:44.842] 0000023600 [ncp.client] TRACE: Setting UART voltage translator state 0
[2022-11-16 21:42:44.945] 0000023700 [ncp.client] TRACE: Setting UART voltage translator state 1
[2022-11-16 21:42:44.945] 0000023701 [ncp.client] TRACE: Muxer is not currently running
[2022-11-16 21:42:44.947] 0000023702 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
[2022-11-16 21:42:44.947] 0000023702 [mux] INFO: Starting GSM07.10 muxer
[2022-11-16 21:42:44.949] 0000023703 [mux] INFO: GSM07.10 muxer thread started
[2022-11-16 21:42:45.246] 0000024002 [mux] INFO: Stopping GSM07.10 muxer
[2022-11-16 21:42:45.248] 0000024003 [mux] INFO: Gracefully stopping GSM07.10 muxer
[2022-11-16 21:42:45.248] 0000024003 [mux] INFO: Closing all muxed channels
[2022-11-16 21:42:45.248] 0000024003 [mux] INFO: Muxed channel 1 already closed
[2022-11-16 21:42:45.250] 0000024004 [mux] INFO: Muxed channel 2 already closed
[2022-11-16 21:42:45.250] 0000024004 [mux] INFO: Muxed channel 3 already closed
[2022-11-16 21:42:45.250] 0000024004 [mux] INFO: Muxed channel 4 already closed
[2022-11-16 21:42:45.898] 0000024656 [mux] INFO: Sending CLD (multiplexer close down)
[2022-11-16 21:42:46.801] 0000025559 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
[2022-11-16 21:42:46.853] 0000025609 [mux] INFO: GSM07.10 muxer thread exiting
[2022-11-16 21:42:46.853] 0000025610 [mux] INFO: GSM07.10 muxer stopped
[2022-11-16 21:42:46.855] 0000025610 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
[2022-11-16 21:42:46.855] 0000025611 [mux] INFO: Starting GSM07.10 muxer
[2022-11-16 21:42:46.857] 0000025611 [mux] INFO: GSM07.10 muxer thread started
[2022-11-16 21:42:47.155] 0000025911 [mux] INFO: Stopping GSM07.10 muxer
[2022-11-16 21:42:47.158] 0000025912 [mux] INFO: Gracefully stopping GSM07.10 muxer
[2022-11-16 21:42:47.158] 0000025912 [mux] INFO: Closing all muxed channels
[2022-11-16 21:42:47.160] 0000025912 [mux] INFO: Muxed channel 1 already closed
[2022-11-16 21:42:47.160] 0000025913 [mux] INFO: Muxed channel 2 already closed
[2022-11-16 21:42:47.160] 0000025913 [mux] INFO: Muxed channel 3 already closed
[2022-11-16 21:42:47.160] 0000025913 [mux] INFO: Muxed channel 4 already closed
[2022-11-16 21:42:47.808] 0000026565 [mux] INFO: Sending CLD (multiplexer close down)
[2022-11-16 21:42:48.711] 0000027468 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
[2022-11-16 21:42:48.760] 0000027518 [mux] INFO: GSM07.10 muxer thread exiting
[2022-11-16 21:42:48.762] 0000027519 [mux] INFO: GSM07.10 muxer stopped
[2022-11-16 21:42:48.763] 0000027520 [ncp.at] TRACE: > AT
[2022-11-16 21:42:49.761] 0000028520 [ncp.at] TRACE: > AT
[2022-11-16 21:42:50.764] 0000029521 [ncp.client] TRACE: Modem is not responsive @ 460800 baudrate
[2022-11-16 21:42:50.764] 0000029522 [ncp.at] TRACE: > AT
[2022-11-16 21:42:51.767] 0000030522 [ncp.at] TRACE: > AT
[2022-11-16 21:42:52.764] 0000031523 [ncp.at] TRACE: > AT
[2022-11-16 21:42:53.765] 0000032524 [ncp.at] TRACE: > AT
[2022-11-16 21:43:36.873] 0000033525 [ncp.at] TRACE: > AT
[2022-11-16 21:43:36.874] 0000034526 [ncp.client] TRACE: Modem is not responsive @ 115200 baudrate
[2022-11-16 21:43:36.874] 0000034527 [ncp.client] ERROR: No response from NCP
[2022-11-16 21:43:36.876] 0000034527 [ncp.client] TRACE: Setting UART voltage translator state 0
[2022-11-16 21:43:36.878] 0000034527 [ncp.client] TRACE: Hard resetting the modem
[2022-11-16 21:43:36.878] 0000034528 [ncp.client] TRACE: Modem waiting up to 30s to power off with PWR_UC...
[2022-11-16 21:43:36.879] 0000075627 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:43:36.879] 0000075628 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
[2022-11-16 21:43:36.881] 0000075628 [system.nm] TRACE: Interface 4 power state changed: 1
[2022-11-16 21:43:36.881] 0000075628 [ncp.client] TRACE: Deinit modem serial.
[2022-11-16 21:43:36.887] 0000075629 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
[2022-11-16 21:43:36.887] 0000075630 [app] INFO: modem is not yet responding
[2022-11-16 21:43:36.888] 0000075630 [app] INFO: Still trying to connect to cellular 00:52
[2022-11-16 21:43:36.888] 0000075630 [app] INFO: Power source: USB Host
[2022-11-16 21:43:36.888] 0000075633 [app] INFO: Battery state: charged, SoC: 99.89
[2022-11-16 21:43:36.888] 0000075646 [app] INFO: modem is not yet responding
[2022-11-16 21:43:36.972] 0000075729 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
[2022-11-16 21:43:36.972] 0000075730 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:43:36.974] 0000075730 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
[2022-11-16 21:43:36.974] 0000075730 [system.nm] TRACE: Interface 4 power state changed: 4
[2022-11-16 21:43:37.123] 0000075880 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:43:37.123] 0000075881 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
[2022-11-16 21:43:37.124] 0000075881 [system.nm] TRACE: Interface 4 power state changed: 2
[2022-11-16 21:43:37.125] 0000075881 [ncp.client] TRACE: Modem powered on
[2022-11-16 21:43:37.125] 0000075882 [ncp.client] TRACE: Setting UART voltage translator state 1
[2022-11-16 21:43:37.222] 0000075981 [ncp.client] TRACE: Setting UART voltage translator state 0
[2022-11-16 21:43:37.323] 0000076081 [ncp.client] TRACE: Setting UART voltage translator state 1
[2022-11-16 21:43:38.323] 0000077082 [ncp.at] TRACE: > AT
[2022-11-16 21:43:39.325] 0000078083 [ncp.at] TRACE: > AT
[2022-11-16 21:43:40.325] 0000079084 [ncp.at] TRACE: > AT
[2022-11-16 21:43:41.327] 0000080085 [ncp.at] TRACE: > AT
[2022-11-16 21:43:42.328] 0000081086 [ncp.at] TRACE: > AT
[2022-11-16 21:43:43.328] 0000082087 [ncp.at] TRACE: > AT
[2022-11-16 21:43:44.330] 0000083088 [ncp.at] TRACE: > AT
[2022-11-16 21:43:45.330] 0000084089 [ncp.at] TRACE: > AT
[2022-11-16 21:43:46.331] 0000085090 [ncp.at] TRACE: > AT
[2022-11-16 21:43:46.873] 0000085630 [app] INFO: Still trying to connect to cellular 01:02
[2022-11-16 21:43:46.873] 0000085630 [app] INFO: Power source: USB Host
[2022-11-16 21:43:46.874] 0000085633 [app] INFO: Battery state: charged, SoC: 99.89
[2022-11-16 21:44:34.444] 0000086091 [ncp.at] TRACE: > AT
[2022-11-16 21:44:34.444] 0000087093 [ncp.at] TRACE: > AT
[2022-11-16 21:44:34.444] 0000088093 [ncp.at] TRACE: > AT
[2022-11-16 21:44:34.444] 0000089094 [ncp.at] TRACE: > AT
[2022-11-16 21:44:34.447] 0000090095 [ncp.at] TRACE: > AT
[2022-11-16 21:44:34.447] 0000091096 [ncp.at] TRACE: > AT
[2022-11-16 21:44:34.447] 0000092097 [ncp.client] ERROR: No response from NCP
[2022-11-16 21:44:34.447] 0000092098 [ncp.client] TRACE: Setting UART voltage translator state 0
[2022-11-16 21:44:34.448] 0000092098 [ncp.client] TRACE: Hard resetting the modem
[2022-11-16 21:44:34.450] 0000092098 [ncp.client] TRACE: Modem waiting up to 30s to power off with PWR_UC...
[2022-11-16 21:44:34.451] 0000133198 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:44:34.451] 0000133199 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
[2022-11-16 21:44:34.453] 0000133199 [system.nm] TRACE: Interface 4 power state changed: 1
[2022-11-16 21:44:34.453] 0000133199 [ncp.client] TRACE: Deinit modem serial.
[2022-11-16 21:44:34.455] 0000133200 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
[2022-11-16 21:44:34.455] 0000133201 [app] INFO: modem is not yet responding
[2022-11-16 21:44:34.456] 0000133201 [app] INFO: Still trying to connect to cellular 01:49
[2022-11-16 21:44:34.457] 0000133201 [app] INFO: Power source: USB Host
[2022-11-16 21:44:34.458] 0000133204 [app] INFO: Battery state: charged, SoC: 99.89
[2022-11-16 21:44:34.459] 0000133219 [app] INFO: modem is not yet responding
[2022-11-16 21:44:34.541] 0000133300 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
[2022-11-16 21:44:34.542] 0000133301 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:44:34.542] 0000133301 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
[2022-11-16 21:44:34.544] 0000133301 [system.nm] TRACE: Interface 4 power state changed: 4
[2022-11-16 21:44:34.691] 0000133451 [net.pppncp] TRACE: NCP event 3
[2022-11-16 21:44:34.693] 0000133452 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
[2022-11-16 21:44:34.694] 0000133452 [system.nm] TRACE: Interface 4 power state changed: 2
[2022-11-16 21:44:34.695] 0000133452 [ncp.client] TRACE: Modem powered on
[2022-11-16 21:44:34.695] 0000133453 [ncp.client] TRACE: Setting UART voltage translator state 1
[2022-11-16 21:44:34.792] 0000133552 [ncp.client] TRACE: Setting UART voltage translator state 0
[2022-11-16 21:44:34.894] 0000133652 [ncp.client] TRACE: Setting UART voltage translator state 1
