Cellular Boron Stuck with Flashing Green Status Light
I have a bench device that has been running for months with the same firmware. Starting yesterday the device got "stuck" with flashing green status light. My firmware code is running in the expected loop, but not publishing data as the device is not connected to cellular. Below is the trace from the serial port, any ideas why this is stuck? What can be done to defend against?
0392722468 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0392722568 [ncp.client] TRACE: Powering modem on, ncpId: 0x47
0392722568 [ncp.client] TRACE: Modem already on
0392722569 [net.pppncp] TRACE: NCP event 3
0392722570 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0392722570 [system.nm] TRACE: Interface 4 power state changed: UP
0392722570 [ncp.client] TRACE: Setting UART voltage translator state 1
0392722671 [ncp.client] TRACE: Setting UART voltage translator state 0
0392722771 [ncp.client] TRACE: Setting UART voltage translator state 1
0392723772 [ncp.at] TRACE: > AT
0392724772 [ncp.at] TRACE: > AT
0392725772 [ncp.at] TRACE: > AT
0392726772 [ncp.at] TRACE: > AT
0392727772 [ncp.at] TRACE: > AT
0392728772 [ncp.at] TRACE: > AT
0392729772 [ncp.at] TRACE: > AT
0392730772 [ncp.at] TRACE: > AT
0392731772 [ncp.at] TRACE: > AT
0392732772 [ncp.at] TRACE: > AT
0392733772 [ncp.at] TRACE: > AT
0392734773 [ncp.at] TRACE: > AT
0392735773 [ncp.at] TRACE: > AT
0392736773 [ncp.at] TRACE: > AT
0392737773 [ncp.at] TRACE: > AT
0392738773 [ncp.client] ERROR: No response from NCP
0392738773 [ncp.client] TRACE: Setting UART voltage translator state 0
0392738774 [ncp.client] TRACE: Hard resetting the modem
0392738974 [net.pppncp] TRACE: NCP event 3
0392738974 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0392738975 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0392738975 [ncp.client] TRACE: Emergency hardware shutdown the modem
0392747254 [app] TRACE: Publishing readings... ttl = 1723561240
0392747255 [app] TRACE: Message sent: {"version":12,"deviceid":"xxxxxx460f","datetime":1722956440}
0392747257 [app] TRACE: Free RAM 102312 bytes
0392747258 [app] TRACE: Entering sleep mode loop for 900 mins
0392764476 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0392764576 [ncp.client] TRACE: Powering modem on, ncpId: 0x47
0392764576 [ncp.client] TRACE: Modem already on
0392764577 [net.pppncp] TRACE: NCP event 3
0392764577 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0392764578 [system.nm] TRACE: Interface 4 power state changed: UP
0392764578 [ncp.client] TRACE: Setting UART voltage translator state 1
0392764678 [ncp.client] TRACE: Setting UART voltage translator state 0
0392764778 [ncp.client] TRACE: Setting UART voltage translator state 1
0392765779 [ncp.at] TRACE: > AT
0392766779 [ncp.at] TRACE: > AT
0392767779 [ncp.at] TRACE: > AT
0392768779 [ncp.at] TRACE: > AT
0392769779 [ncp.at] TRACE: > AT
0392770779 [ncp.at] TRACE: > AT
0392771779 [ncp.at] TRACE: > AT
0392772779 [ncp.at] TRACE: > AT
0392773779 [ncp.at] TRACE: > AT
0392774779 [ncp.at] TRACE: > AT
0392775779 [ncp.at] TRACE: > AT
0392776780 [ncp.at] TRACE: > AT
0392777780 [ncp.at] TRACE: > AT
0392778780 [ncp.at] TRACE: > AT
0392779780 [ncp.at] TRACE: > AT
0392780780 [ncp.client] ERROR: No response from NCP
0392780780 [ncp.client] TRACE: Setting UART voltage translator state 0
0392780781 [ncp.client] TRACE: Hard resetting the modem
0392780981 [net.pppncp] TRACE: NCP event 3
0392780981 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0392780982 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0392780983 [ncp.client] TRACE: Emergency hardware shutdown the modem
Hi @jdr2023!
What model is your boron? Did you try something to bring it back after the issue started?
That looks like it could be a hardware failure, but you should run Device Restore USB to restore default software to make sure it's not something in your code.
Also, in the future, you should check for Particle.connected() before publishing. If you publish before connected Particle.publish() will block, sometimes for up to 10 minutes, which can cause unexpected behavior.
Boron LTE-M (NorAm) with EtherSIM (BRN404X). I have not tried to recover the device yet, still in endless loop in case there is any additional data to collect to help with diagnostics. I can pull the plug on the device next to see if it recovers after power cycle.
