Hi there, I am fairly experienced with arduino’s and LoRa communication however have never used bluetooth or any of the particle boards. I am currently working on a project which has two IMU’s and then a ground base which processes all of the data in real time. I am wondering if anyone has any pointers for bluetooth communication between Argons. The speed of transmission is very important (must be capable of sending 12 bytes from each IMU every 20ms ish).
Hamish
Or would it be better to use wifi communication between argons?
Have you looked at these examples?
https://docs.particle.io/tutorials/device-os/bluetooth-le/#examples
