Blue breathing light, but Compile times out of Web IDE
I have a photon that I cannot seem to send new code to.
The Photon is slow flashing (breathing) cyan LED.
In Web IDE, I click ‘Verify’.
Status says ‘Saving firmware’
Then
Compiling code…
And just sits there.
After a couple of minutes, it tells me that the server failed to respond, and to please try again.
Next to my device name at the bottom right, I see a grey circle. I think it’s usually cyan?
If I go to device, I see no colour icon next to my device.
If I click ‘Signal’, the device remains flashing cyan blue. Breathing style.
I don’t think it’s device specific, as ‘Verify’ shouldn’t touch my device (or should it)?
So, currently, cannot verify my code, or flash it. Is there a system error?
Is it possible for you to try using Workbench? It has a lot more functionality than the Web IDE.
You can work on projects locally, compile locally, and much more.
Thanks for the idea.
Just before reading this, I logged out, and back in again, and it’s working.
When I opened my browser this morning, I noticed I wasn’t prompted to login.
I wonder if it was a session issue - but all seems good now.
My next troubleshooting step would have been to put the device in safe mode and see if the OTA update worked then. Glad it's working again. I always make a point to close my browser tab and reopen build.particle.io if I leave it sitting open over night. I've had some strange things happen... usually when I leave a project open on my work PC, making changes at home at night, and then just refreshing the browser session at work the next day. The refresh doesn't work so well. A full close and reopen does.
