I’ve tried setting up my core for the first time via the app. It sends it into blinking green mode (iPhone 5, router is 2.4ghz).
Try same thing with USB - same thing, sends core into blinking green.
Tried to get firmware patched - and I get these two errors during make:
make[1]: arm-none-eabi-gcc: No such file or directory
make[1]: *** [obj/CC3000_Host_Driver/cc3000_common.o] Error 1
make: *** [check_external_deps] Error 2
Any idears?
Dave
May 8, 2014, 9:28pm
2
Just popping in here since Justin and I are emailing directly as well.
In the case of this specific error, it would be because the arm-none-eabi-gcc toolchain isn’t installed and in the path, there are some instructions on getting a local build environment setup here: https://github.com/spark/core-firmware#1-gcc-for-arm-cortex-processors
David
Thanks Dave,
So here is the latest. Able to install new patch (device goes magenta).
When I connect with my phone, or usb serial, the blinking blue turns to blinking green and stays there.
So - it’s communicating with the core. But it’s apparently unable to connect to the internet? Thoughts?
@Stophinal ,
Just wondering when you buy the core? A CC3000 patch should solve the problem.
If you have a u.fl version of the core, you need to attach an external antenna
Solution! I’m not sure if there wasn’t also a firmware patch issue. Regardless, I got things finally working by adjusting my router. This may have been common sense for spark elite. I have an ASUS RT-N56U - I needed to set the wireless mode to g/b NOT auto and DEF NOT n mode.
I wrote up more here: http://www.trailspice.com/2014/05/connecting-with-spark-core.html
That’s right!
Sometimes the Auto mode causes some issue
