Im currently running through one of the BLE examples and am wondering if there is a way to shorten the range of detection. In the example im doing i have 2 argon boards, 1 as the main device and 1 that advertises. The main device turns on an LED depending on the other devices signal strength and assigned colour.
I have pasted my code but unsure where or how to shorten the signal detection, i think its something to do with the rssi, currently the device is detected from quite a distance but i’d like to experiment with shortening it if possible.
any advice would be appreciated.
#include "Particle.h"
// This example does not require the cloud so you can run it in manual mode or
// normal cloud-connected mode
// SYSTEM_MODE(MANUAL);
const size_t SCAN_RESULT_MAX = 30;
int Led1 = D4;
BleScanResult scanResults[SCAN_RESULT_MAX];
LEDStatus ledOverride(RGB_COLOR_WHITE, LED_PATTERN_SOLID, LED_SPEED_NORMAL, LED_PRIORITY_IMPORTANT);
(void)logHandler; // Does nothing, just to eliminate the unused variable warning
pinMode(Led1, OUTPUT);
BLE.on();
// Only scan for 500 milliseconds
BLE.setScanTimeout(50);
int count = BLE.scan(scanResults, SCAN_RESULT_MAX);
uint32_t curColorCode;
int curRssi = -999;
for (int ii = 0; ii < count; ii++) {
uint8_t buf[BLE_MAX_ADV_DATA_LEN];
size_t len;
// When getting a specific AD Type, the length returned does not include the length or AD Type so len will be one less
// than what we put in the beacon code, because that includes the AD Type.
len = scanResults[ii].advertisingData.get(BleAdvertisingDataType::MANUFACTURER_SPECIFIC_DATA, buf, BLE_MAX_ADV_DATA_LEN);
if (len == 7) {
// We have manufacturer-specific advertising data (0xff) and it's 7 bytes (without the AD type)
// Byte: BLE_SIG_AD_TYPE_MANUFACTURER_SPECIFIC_DATA (0xff)
// 16-bit: Company ID (0xffff)
// Byte: Internal packet identifier (0x55)
// 32-bit: Color code
if (buf[0] == 0xff && buf[1] == 0xff && buf[2] == 0x55) {
// Company ID and internal packet identifier match
uint32_t colorCode;
memcpy(&colorCode, &buf[3], 4);
Log.info("colorCode: 0x%lx rssi=%d address=%02X:%02X:%02X:%02X:%02X:%02X ",
colorCode, scanResults[ii].rssi,
scanResults[ii].address[0], scanResults[ii].address[1], scanResults[ii].address[2],
scanResults[ii].address[3], scanResults[ii].address[4], scanResults[ii].address[5]);
if (scanResults[ii].rssi > curRssi) {
// Show whatever device has the strongest signal
curRssi = scanResults[ii].rssi;
curColorCode = colorCode;
digitalWrite(Led1, HIGH);
else {
digitalWrite(Led1, LOW);
if (curRssi != -999) {
ledOverride.setColor(curColorCode);
ledOverride.setActive(true);
else {
ledOverride.setActive(false);
Thank you,
Devin
- updated link)
