I have two Sparks with chip antenna but they looks like they loosing wifi connection some times, can i put a cable or something as antenna to help it find wifi?
How often does it loose the connection and how far is the access point from the
Core?
As far as adding an antenna goes, you’ll have to add a connector to be able to attach one. A wire may not be the right solution.
