I've got a B404X than I cannot get to connect to a network. I've included a log from Device Dr and from what I've seen on a related post it may be a hardware failure but should I try anything else?
0000233566 [ncp.client] ERROR: No response from NCP
0000233567 [ncp.client] TRACE: Hard reset
0000233767 [net.pppncp] TRACE: NCP event 3
0000233768 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000233769 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000233770 [ncp.client] TRACE: Emergency hardware shutdown the modem (EXT)
0000319270 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000319370 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000320870 [net.pppncp] TRACE: NCP event 3
0000320871 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000320872 [system.nm] TRACE: Interface 4 power state changed: UP
0000320873 [ncp.client] TRACE: Powered on
0000322073 [ncp.at] TRACE: > AT
0000323074 [ncp.at] TRACE: > AT
0000324075 [ncp.at] TRACE: > AT
0000325076 [ncp.at] TRACE: > AT
0000326077 [ncp.at] TRACE: > AT
0000327078 [ncp.at] TRACE: > AT
0000328079 [ncp.at] TRACE: > AT
0000329080 [ncp.at] TRACE: > AT
0000330081 [ncp.at] TRACE: > AT
0000331082 [ncp.at] TRACE: > AT
0000332084 [ncp.at] TRACE: > AT
0000333084 [ncp.at] TRACE: > AT
0000334085 [ncp.at] TRACE: > AT
0000335086 [ncp.at] TRACE: > AT
0000336087 [ncp.at] TRACE: > AT
It's probably a hardware failure of the cellular modem. However, what version of Device OS were you running when you captured the log? And have you completely removed the USB, and battery power if you are using it, for at least 30 seconds?
It is on 6.4.1 and yes just tried disconnecting everything and still get the same results
Then it almost certainly is a hardware failure.
I've got a second one that is trying to connect but is stuck in this loop
0000180883 [net.ppp.client] TRACE: PPP phase -> Initialize
0000180883 [net.ppp.client] TRACE: PPP phase -> Establish
0000180895 [net.ppp.client] TRACE: PPP phase -> Authenticate
0000180905 [net.ppp.client] TRACE: PPP phase -> Network
0000180927 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000180929 [net.ppp.client] TRACE: PPP thread event UP data=0
0000180930 [net.ppp.client] TRACE: State CONNECTING -> CONNECTED
0000180931 [system.nm] INFO: State changed: IFACE_LINK_UP -> IP_CONFIGURED
0000180932 [net.pppncp] TRACE: Negotiated MTU: 1360
0000180933 [net.ppp.client] TRACE: PPP phase -> Running
0000180979 [system] INFO: Cloud: connecting
0000180981 [system] WARN: Failed to load session data from persistent storage
0000181197 [system] INFO: Cloud socket connected
0000181197 [comm.protocol.handshake] INFO: Establish secure connection
0000181200 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000226203 [comm.dtls] ERROR: handshake failed -6800
0000226203 [comm.dtls] ERROR: Invalid handshake state
0000226205 [comm.protocol.handshake] ERROR: Handshake failed: 17
0000233318 [system] ERROR: Failed to determine server address: 202
0000233319 [system] WARN: Internet test failed: -170 DNS
0000233319 [system] WARN: Cloud handshake failed, code=-220
0000233570 [system] INFO: Cloud: disconnecting
0000233570 [system] INFO: Cloud: disconnected
0000233570 [system] INFO: Cloud: connecting
Could I get the Device ID, ICCID, or Serial Number of the second device? You can send a private message by clicking on my name and selecting Message instead of pasting it here if you prefer. The whole log would be helpful as well.
