Can't Connect To Cellular Anymore
Hello, I've been using a BRN404 for a while and it just stopped working on 5/17/2024 all of a sudden. The light flashes green and never connects. I have tried device doctor several times but it says "It appears that your device connected to the cloud, then got a firmware update that erased the setup firmware. This prevents logs and other diagnostic data from being displayed, but your device should be fully functional."
I have tried another antenna as well.
I do get some logs so hopefully it's helpful to determine what happened.
Device ID: 1293429129329841789471293478afsafds
ICCID:
IMEI:
IMSI:
Modem Manufacturer:
Modem Model:
Modem Firmware Version:
Modem Application Version:
Power Supply:
Battery:
Battery SoC:
Country:
Carrier:
Access Technology:
Band:
Cellular Global Identity:
ning
0000000471 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000471 [mux] INFO: Starting GSM07.10 muxer
0000000472 [mux] INFO: GSM07.10 muxer thread started
0000000772 [mux] INFO: Stopping GSM07.10 muxer
0000000773 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000000773 [mux] INFO: Closing all muxed channels
0000000774 [mux] INFO: Muxed channel 1 already closed
0000000774 [mux] INFO: Muxed channel 2 already closed
0000000775 [mux] INFO: Muxed channel 3 already closed
0000000776 [mux] INFO: Muxed channel 4 already closed
0000001426 [mux] INFO: Sending CLD (multiplexer close down)
0000002327 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000002377 [mux] INFO: GSM07.10 muxer thread exiting
0000002378 [mux] INFO: GSM07.10 muxer stopped
0000002378 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000002379 [mux] INFO: Starting GSM07.10 muxer
0000002380 [mux] INFO: GSM07.10 muxer thread started
0000002680 [mux] INFO: Stopping GSM07.10 muxer
0000002681 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000002681 [mux] INFO: Closing all muxed channels
0000002682 [mux] INFO: Muxed channel 1 already closed
0000002682 [mux] INFO: Muxed channel 2 already closed
0000002683 [mux] INFO: Muxed channel 3 already closed
0000002684 [mux] INFO: Muxed channel 4 already closed
0000002805 [app] INFO: Auto-connect disabled
0000003334 [mux] INFO: Sending CLD (multiplexer close down)
0000004235 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000004285 [mux] INFO: GSM07.10 muxer thread exiting
0000004286 [mux] INFO: GSM07.10 muxer stopped
0000004287 [ncp.at] TRACE: > AT
0000005287 [ncp.at] TRACE: > AT
0000006287 [ncp.client] TRACE: Modem is not responsive @ 460800 baudrate
0000006288 [ncp.at] TRACE: > AT
0000007288 [ncp.at] TRACE: > AT
0000008288 [ncp.at] TRACE: > AT
0000009288 [ncp.at] TRACE: > AT
0000010288 [ncp.at] TRACE: > AT
0000011288 [ncp.client] TRACE: Modem is not responsive @ 115200 baudrate
0000011289 [ncp.client] ERROR: No response from NCP
0000011292 [app.cellinterp] INFO: processLog match ts=11289 category=ncp.client level=ERROR msg=No response from NCP
0000011293 [app] INFO: got no response from NCP
0000011289 [ncp.client] TRACE: Setting UART voltage translator state 0
0000011290 [ncp.client] TRACE: Hard resetting the modem
0000011290 [ncp.client] TRACE: Modem waiting up to 30s to power off with PWR_UC...
0000052390 [net.pppncp] TRACE: NCP event 3
0000052390 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000052391 [system.nm] TRACE: Interface 4 power state changed: 1
0000052392 [ncp.client] TRACE: Deinit modem serial.
0000052393 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000052394 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0000052395 [net.pppncp] TRACE: NCP event 3
0000052397 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000052398 [system.nm] TRACE: Interface 4 power state changed: 4
0000052548 [net.pppncp] TRACE: NCP event 3
0000052548 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000052549 [system.nm] TRACE: Interface 4 power state changed: 2
0000052550 [ncp.client] TRACE: Modem powered on
0000052550 [ncp.client] TRACE: Setting UART voltage translator state 1
0000052650 [ncp.client] TRACE: Setting UART voltage translator state 0
0000052750 [ncp.client] TRACE: Setting UART voltage translator state 1
0000053751 [ncp.at] TRACE: > AT
0000054751 [ncp.at] TRACE: > AT
0000055751 [ncp.at] TRACE: > AT
0000056751 [ncp.at] TRACE: > AT
0000057751 [ncp.at] TRACE: > AT
0000058751 [ncp.at] TRACE: > AT
0000059751 [ncp.at] TRACE: > AT
0000060751 [ncp.at] TRACE: > AT
0000061751 [ncp.at] TRACE: > AT
0000062751 [ncp.at] TRACE: > AT
0000063751 [ncp.at] TRACE: > AT
0000064752 [ncp.at] TRACE: > AT
0000065752 [ncp.at] TRACE: > AT
0000066752 [ncp.at] TRACE: > AT
0000067752 [ncp.at] TRACE: > AT
0000068752 [ncp.client] ERROR: No response from NCP
0000068755 [app.cellinterp] INFO: processLog match ts=68752 category=ncp.client level=ERROR msg=No response from NCP
0000068756 [app] INFO: got no response from NCP
0000068753 [ncp.client] TRACE: Setting UART voltage translator state 0
0000068753 [ncp.client] TRACE: Hard resetting the modem
0000068754 [ncp.client] TRACE: Modem waiting up to 30s to power off with PWR_UC...
0000109754 [net.pppncp] TRACE: NCP event 3
0000109754 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000109755 [system.nm] TRACE: Interface 4 power state changed: 1
0000109756 [ncp.client] TRACE: Deinit modem serial.
0000109757 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0000109757 [net.pppncp] TRACE: NCP event 3
0000109758 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000109758 [system.nm] TRACE: Interface 4 power state changed: 4
0000109908 [net.pppncp] TRACE: NCP event 3
0000109908 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000109909 [system.nm] TRACE: Interface 4 power state changed: 2
0000109910 [ncp.client] TRACE: Modem powered on
0000109910 [ncp.client] TRACE: Setting UART voltage translator state 1
0000110010 [ncp.client] TRACE: Setting UART voltage translator state 0
0000110110 [ncp.client] TRACE: Setting UART voltage translator state 1
0000111111 [ncp.at] TRACE: > AT
0000112111 [ncp.at] TRACE: > AT
0000113111 [ncp.at] TRACE: > AT
0000114111 [ncp.at] TRACE: > AT
0000115111 [ncp.at] TRACE: > AT
0000116111 [ncp.at] TRACE: > AT
0000117111 [ncp.at] TRACE: > AT
0000118111 [ncp.at] TRACE: > AT
0000119111 [ncp.at] TRACE: > AT
0000120111 [ncp.at] TRACE: > AT
0000121111 [ncp.at] TRACE: > AT
0000122112 [ncp.at] TRACE: > AT
0000123112 [ncp.at] TRACE: > AT
0000124112 [ncp.at] TRACE: > AT
0000125112 [ncp.at] TRACE: > AT
0000126112 [ncp.client] ERROR: No response from NCP
0000126115 [app.cellinterp] INFO: processLog match ts=126112 category=ncp.client level=ERROR msg=No response from NCP
0000126116 [app] INFO: got no response from NCP
0000126113 [ncp.client] TRACE: Setting UART voltage translator state 0
0000126113 [ncp.client] TRACE: Hard resetting the modem
0000126114 [ncp.client] TRACE: Modem waiting up to 30s to power off with PWR_UC...
0000167114 [net.pppncp] TRACE: NCP event 3
0000167114 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000167115 [system.nm] TRACE: Interface 4 power state changed: 1
0000167116 [ncp.client] TRACE: Deinit modem serial.
0000167117 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000167217 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0000167218 [net.pppncp] TRACE: NCP event 3
0000167218 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000167219 [system.nm] TRACE: Interface 4 power state changed: 4
0000167369 [net.pppncp] TRACE: NCP event 3
0000167369 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000167370 [system.nm] TRACE: Interface 4 power state changed: 2
0000167371 [ncp.client] TRACE: Modem powered on
0000167371 [ncp.client] TRACE: Setting UART voltage translator state 1
0000167471 [ncp.client] TRACE: Setting UART voltage translator state 0
0000167571 [ncp.client] TRACE: Setting UART voltage translator state 1
0000168572 [ncp.at] TRACE: > AT
0000169572 [ncp.at] TRACE: > AT
0000170572 [ncp.at] TRACE: > AT
0000171572 [ncp.at] TRACE: > AT
0000172572 [ncp.at] TRACE: > AT
0000173572 [ncp.at] TRACE: > AT
0000174572 [ncp.at] TRACE: > AT
0000175572 [ncp.at] TRACE: > AT
0000176572 [ncp.at] TRACE: > AT
0000177572 [ncp.at] TRACE: > AT
0000178572 [ncp.at] TRACE: > AT
0000179573 [ncp.at] TRACE: > AT
0000180574 [ncp.at] TRACE: > AT
0000181574 [ncp.at] TRACE: > AT
0000182574 [ncp.at] TRACE: > AT
0000183574 [ncp.client] ERROR: No response from NCP
0000183577 [app.cellinterp] INFO: processLog match ts=183574 category=ncp.client level=ERROR msg=No response from NCP
0000183578 [app] INFO: got no response from NCP
0000183575 [ncp.client] TRACE: Setting UART voltage translator state 0
0000183575 [ncp.client] TRACE: Hard resetting the modem
0000183576 [ncp.client] TRACE: Modem waiting up to 30s to power off with PWR_UC...
0000224576 [net.pppncp] TRACE: NCP event 3
0000224576 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000224577 [system.nm] TRACE: Interface 4 power state changed: 1
0000224578 [ncp.client] TRACE: Deinit modem serial.
0000224579 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000224679 [ncp.client] TRACE: Powering modem on, ncpId: 0x44
0000224680 [net.pppncp] TRACE: NCP event 3
0000224680 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000224681 [system.nm] TRACE: Interface 4 power state changed: 4
Unfortunately from the logs this appears to be a hardware failure of the cellular modem module. See TAN004 for more information.
I see it now. Wish I had know about it. It was running off of a lithium battery. The battery stat was ~38% when it stopped working.
