Setting up 5 B404x's fresh out of the box.
I'll be honest, it rarely goes smooth and connection can take a while.
However these five just really don't want to connect today. Will try again in the morning.
I am suspicious that there is something up with the particle side, as some of these devices will go from green to blinking cyan, but then two DFU mode color blinks and the cycle starts again.
While recording the attached logs, this device never left the blinking green phase.
0000000330 [system.nm] TRACE: Request to power on interface 4
0000000331 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000000331 [ncp.client] TRACE: Already on
0000000332 [system.nm] INFO: State changed: DISABLED -> IFACE_DOWN
0000000531 [ncp.client] TRACE: Muxer is not currently running
0000000532 [ncp.client] TRACE: Initialized muxer @ 460800 baudrate
0000000533 [mux] INFO: Starting GSM07.10 muxer
0000000534 [mux] INFO: GSM07.10 muxer thread started
0000000834 [mux] INFO: Stopping GSM07.10 muxer
0000000835 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000000835 [mux] INFO: Closing all muxed channels
0000000841 [mux] INFO: Muxed channel 1 already closed
0000000842 [mux] INFO: Muxed channel 2 already closed
0000000842 [mux] INFO: Muxed channel 3 already closed
0000000843 [mux] INFO: Muxed channel 4 already closed
0000000844 [mux] INFO: Sending CLD (multiplexer close down)
0000000847 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000000848 [mux] INFO: GSM07.10 muxer thread exiting
0000000848 [mux] INFO: GSM07.10 muxer stopped
0000000849 [ncp.client] TRACE: Initialized muxer @ 115200 baudrate
0000000850 [mux] INFO: Starting GSM07.10 muxer
0000000851 [mux] INFO: GSM07.10 muxer thread started
0000001151 [mux] INFO: Stopping GSM07.10 muxer
0000001152 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000001152 [mux] INFO: Closing all muxed channels
0000001153 [mux] INFO: Muxed channel 1 already closed
0000001154 [mux] INFO: Muxed channel 2 already closed
0000001154 [mux] INFO: Muxed channel 3 already closed
0000001155 [mux] INFO: Muxed channel 4 already closed
0000001156 [mux] INFO: Sending CLD (multiplexer close down)
0000001717 [app] INFO: Auto-connect disabled
0000002056 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000002106 [mux] INFO: GSM07.10 muxer thread exiting
0000002107 [mux] INFO: GSM07.10 muxer stopped
0000002108 [ncp.at] TRACE: > AT
0000002110 [ncp.at] TRACE: < OK
0000002111 [ncp.client] TRACE: NCP ready to accept AT commands
0000002111 [ncp.at] TRACE: > AT
0000002114 [ncp.at] TRACE: < OK
0000002114 [ncp.at] TRACE: > ATI9
0000002117 [ncp.at] TRACE: < 03.15,A00.01
0000002118 [ncp.at] TRACE: < OK
0000002118 [ncp.client] TRACE: App firmware: 1
0000002119 [ncp.at] TRACE: > AT+UGPIOC?
0000002121 [ncp.at] TRACE: < +UGPIOC:
0000002122 [ncp.at] TRACE: < 16,255
0000002122 [ncp.at] TRACE: < 19,255
0000002123 [ncp.at] TRACE: < 23,0
0000002124 [ncp.at] TRACE: < 24,255
0000002124 [ncp.at] TRACE: < 25,255
0000002125 [ncp.at] TRACE: < 33,255
0000002125 [ncp.at] TRACE: < 42,255
0000002126 [ncp.at] TRACE: < 46,255
0000002127 [ncp.at] TRACE: < OK
0000002127 [ncp.at] TRACE: > AT+UGPIOR=23
0000002130 [ncp.at] TRACE: < +UGPIOR: 23,1
0000002131 [ncp.at] TRACE: < OK
0000002131 [ncp.client] INFO: Using internal SIM card
0000002132 [ncp.at] TRACE: > AT+CPIN?
0000002134 [ncp.at] TRACE: < +CPIN: READY
0000002135 [ncp.at] TRACE: < OK
0000002135 [ncp.at] TRACE: > AT+CCID
0000002176 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000002177 [ncp.at] TRACE: < OK
0000002177 [ncp.at] TRACE: > AT+IFC?
0000002180 [ncp.at] TRACE: < +IFC: 2,2
0000002181 [ncp.at] TRACE: < OK
0000002181 [ncp.at] TRACE: > AT+IFC=2,2
0000002184 [ncp.at] TRACE: < OK
0000002185 [ncp.at] TRACE: > AT
0000002187 [ncp.at] TRACE: < OK
0000002187 [ncp.at] TRACE: > AT+IPR=460800
0000002190 [ncp.at] TRACE: < OK
0000003191 [ncp.at] TRACE: > AT
0000003194 [ncp.at] TRACE: < OK
0000003195 [ncp.at] TRACE: > AT+CCID
0000003265 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000003266 [ncp.at] TRACE: < OK
0000003267 [ncp.at] TRACE: > AT+UMNOPROF?
0000003271 [ncp.at] TRACE: < +UMNOPROF: 90
0000003272 [ncp.at] TRACE: < OK
0000003272 [ncp.at] TRACE: > AT+UBANDMASK?
0000003276 [ncp.at] TRACE: < +UBANDMASK: 0,185473183,1048578
0000003277 [ncp.at] TRACE: < OK
0000003277 [ncp.at] TRACE: > AT+COPS=3,2
0000003280 [ncp.at] TRACE: < OK
0000003281 [ncp.at] TRACE: > AT+CGEREP=1,0
0000003283 [ncp.at] TRACE: < OK
0000003284 [ncp.at] TRACE: > AT+URAT?
0000003286 [ncp.at] TRACE: < +URAT: 7
0000003287 [ncp.at] TRACE: < OK
0000003287 [ncp.at] TRACE: > AT+CPSMS?
0000003291 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000003292 [ncp.at] TRACE: < OK
0000003292 [ncp.at] TRACE: > AT+CEDRXS?
0000003296 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000003296 [ncp.at] TRACE: < OK
0000003297 [ncp.at] TRACE: > AT+UPSV?
0000003299 [ncp.at] TRACE: < +UPSV: 1,2000,1
0000003300 [ncp.at] TRACE: < OK
0000003301 [ncp.at] TRACE: > AT+UPSV=0
0000003304 [ncp.at] TRACE: < OK
0000003304 [ncp.at] TRACE: > AT+UPSV=1
0000003308 [ncp.at] TRACE: < OK
0000003308 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000003311 [ncp.at] TRACE: < OK
0000003312 [mux] INFO: Starting GSM07.10 muxer
0000003313 [mux] INFO: Opening mux channel 0
0000003313 [mux] INFO: GSM07.10 muxer thread started
0000003317 [mux] INFO: Opening mux channel 1
0000004585 [ncp.at] TRACE: > AT
0000004590 [ncp.at] TRACE: < OK
0000004591 [ncp.client] TRACE: NCP state changed: 1
0000004591 [net.pppncp] TRACE: NCP event 1
0000004592 [app] INFO: cellular is on
0000004593 [ncp.at] TRACE: > AT+CFUN?
0000004596 [ncp.at] TRACE: < +CFUN: 1,7
0000004597 [ncp.at] TRACE: < OK
0000004599 [ncp.at] TRACE: > AT+CCID
0000004622 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000004624 [ncp.at] TRACE: < OK
0000004626 [ncp.at] TRACE: > AT+CGSN
0000004630 [ncp.at] TRACE: < 351457830365612
0000004631 [ncp.at] TRACE: < OK
0000004632 [ncp.at] TRACE: > ATI9
0000004635 [ncp.at] TRACE: < 03.15,A00.01
0000004636 [ncp.at] TRACE: < OK
0000004640 [ncp.at] TRACE: > AT+CCID
0000004663 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000004665 [ncp.at] TRACE: < OK
0000004667 [ncp.at] TRACE: > AT+CGMI
0000004670 [ncp.at] TRACE: < u-blox
0000004671 [ncp.at] TRACE: < OK
0000004673 [ncp.at] TRACE: > AT+CGMM
0000004676 [ncp.at] TRACE: < SARA-R510S
0000004678 [ncp.at] TRACE: < OK
0000004680 [ncp.at] TRACE: > AT+CGMR
0000004683 [ncp.at] TRACE: < 03.15
0000004684 [ncp.at] TRACE: < OK
0000004685 [ncp.at] TRACE: > AT+CGSN
0000004689 [ncp.at] TRACE: < 351457830365612
0000004690 [ncp.at] TRACE: < OK
0000006011 [ncp.at] TRACE: > AT+CFUN?
0000006014 [ncp.at] TRACE: < +CFUN: 1,7
0000006015 [ncp.at] TRACE: < OK
0000006017 [ncp.at] TRACE: > AT+CCID
0000006040 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000006042 [ncp.at] TRACE: < OK
0000006044 [ncp.at] TRACE: > AT+CGSN
0000006048 [ncp.at] TRACE: < 351457830365612
0000006049 [ncp.at] TRACE: < OK
0000006050 [ncp.at] TRACE: > ATI9
0000006053 [ncp.at] TRACE: < 03.15,A00.01
0000006054 [ncp.at] TRACE: < OK
0000006333 [system.nm] INFO: State changed: IFACE_DOWN -> IFACE_REQUEST_UP
0000006335 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000006336 [net.ppp.client] TRACE: State NONE -> READY
0000006339 [ncp.at] TRACE: > AT+CFUN?
0000006342 [system.nm] INFO: State changed: IFACE_REQUEST_UP -> IFACE_UP
0000006343 [ncp.at] TRACE: < +CFUN: 1,7
0000006344 [ncp.at] TRACE: < OK
0000006345 [ncp.at] TRACE: > AT+CCID
0000006369 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000006370 [ncp.at] TRACE: < OK
0000006371 [ncp.at] TRACE: > AT+CGDCONT?
0000006376 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super","0.0.0.0",0,0,0,2,0,0,0,0,0,0,0
0000006377 [ncp.at] TRACE: < OK
0000006377 [ncp.at] TRACE: > AT+CFUN?
0000006381 [ncp.at] TRACE: < +CFUN: 1,7
0000006382 [ncp.at] TRACE: < OK
0000006383 [ncp.at] TRACE: > AT+CEREG=2
0000006386 [ncp.at] TRACE: < OK
0000006386 [ncp.client] TRACE: NCP connection state changed: 1
0000006387 [net.pppncp] TRACE: NCP event 2
0000006387 [net.pppncp] TRACE: State changed event: 1
0000006388 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000006389 [ncp.at] TRACE: > AT+COPS?
0000006393 [ncp.at] TRACE: < +COPS: 0
0000006394 [ncp.at] TRACE: < OK
0000006395 [ncp.at] TRACE: > AT+CEREG?
0000006398 [ncp.at] TRACE: < +CEREG: 2,3
0000006399 [ncp.at] TRACE: < OK
0000021400 [ncp.at] TRACE: > AT+CEREG?
0000021403 [ncp.at] TRACE: < +CEREG: 2,3
0000021404 [ncp.at] TRACE: < OK
0000021405 [ncp.at] TRACE: > AT+UCGED?
0000021411 [ncp.at] TRACE: < +UCGED: 2
0000021412 [ncp.at] TRACE: < 6,2,fff,fff
0000021413 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000021414 [ncp.at] TRACE: < OK
0000036514 [ncp.at] TRACE: > AT+CEREG?
0000036517 [ncp.at] TRACE: < +CEREG: 2,3
0000036518 [ncp.at] TRACE: < OK
0000036519 [ncp.at] TRACE: > AT+UCGED?
0000036525 [ncp.at] TRACE: < +UCGED: 2
0000036526 [ncp.at] TRACE: < 6,2,fff,fff
0000036526 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000036528 [ncp.at] TRACE: < OK
0000051628 [ncp.at] TRACE: > AT+CEREG?
0000051631 [ncp.at] TRACE: < +CEREG: 2,3
0000051632 [ncp.at] TRACE: < OK
0000051633 [ncp.at] TRACE: > AT+UCGED?
0000051639 [ncp.at] TRACE: < +UCGED: 2
0000051640 [ncp.at] TRACE: < 6,2,fff,fff
0000051641 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000051642 [ncp.at] TRACE: < OK
0000066443 [ncp.at] TRACE: > AT+CIMI
0000066490 [ncp.at] TRACE: < 234507088330970
0000066491 [ncp.at] TRACE: < OK
0000066692 [ncp.at] TRACE: > AT+CEREG?
0000066695 [ncp.at] TRACE: < +CEREG: 2,3
0000066696 [ncp.at] TRACE: < OK
0000066697 [ncp.at] TRACE: > AT+UCGED?
0000066703 [ncp.at] TRACE: < +UCGED: 2
0000066704 [ncp.at] TRACE: < 6,2,fff,fff
0000066704 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000066705 [ncp.at] TRACE: < OK
0000081806 [ncp.at] TRACE: > AT+CEREG?
0000081810 [ncp.at] TRACE: < +CEREG: 2,3
0000081811 [ncp.at] TRACE: < OK
0000081811 [ncp.at] TRACE: > AT+UCGED?
0000081818 [ncp.at] TRACE: < +UCGED: 2
0000081819 [ncp.at] TRACE: < 6,2,fff,fff
0000081819 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000081820 [ncp.at] TRACE: < OK
0000096921 [ncp.at] TRACE: > AT+CEREG?
0000096925 [ncp.at] TRACE: < +CEREG: 2,3
0000096926 [ncp.at] TRACE: < OK
0000096926 [ncp.at] TRACE: > AT+UCGED?
0000096933 [ncp.at] TRACE: < +UCGED: 2
0000096934 [ncp.at] TRACE: < 6,2,fff,fff
0000096934 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000096936 [ncp.at] TRACE: < OK
0000112036 [ncp.at] TRACE: > AT+CEREG?
0000112040 [ncp.at] TRACE: < +CEREG: 2,3
0000112040 [ncp.at] TRACE: < OK
0000112041 [ncp.at] TRACE: > AT+UCGED?
0000112048 [ncp.at] TRACE: < +UCGED: 2
0000112048 [ncp.at] TRACE: < 6,2,fff,fff
0000112049 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000112050 [ncp.at] TRACE: < OK
0000126551 [ncp.at] TRACE: > AT+CIMI
0000126576 [ncp.at] TRACE: < 234507088330970
0000126577 [ncp.at] TRACE: < OK
0000127078 [ncp.at] TRACE: > AT+CEREG?
0000127082 [ncp.at] TRACE: < +CEREG: 2,3
0000127082 [ncp.at] TRACE: < OK
0000127083 [ncp.at] TRACE: > AT+UCGED?
0000127090 [ncp.at] TRACE: < +UCGED: 2
0000127090 [ncp.at] TRACE: < 6,2,fff,fff
0000127091 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000127092 [ncp.at] TRACE: < OK
0000142193 [ncp.at] TRACE: > AT+CEREG?
0000142196 [ncp.at] TRACE: < +CEREG: 2,3
0000142197 [ncp.at] TRACE: < OK
0000142198 [ncp.at] TRACE: > AT+UCGED?
0000142204 [ncp.at] TRACE: < +UCGED: 2
0000142205 [ncp.at] TRACE: < 6,2,fff,fff
0000142206 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000142207 [ncp.at] TRACE: < OK
0000157208 [ncp.at] TRACE: > AT+CEREG?
0000157211 [ncp.at] TRACE: < +CEREG: 2,3
0000157212 [ncp.at] TRACE: < OK
0000157213 [ncp.at] TRACE: > AT+UCGED?
0000157219 [ncp.at] TRACE: < +UCGED: 2
0000157220 [ncp.at] TRACE: < 6,2,fff,fff
0000157221 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000157222 [ncp.at] TRACE: < OK
0000172223 [ncp.at] TRACE: > AT+CEREG?
0000172226 [ncp.at] TRACE: < +CEREG: 2,3
0000172227 [ncp.at] TRACE: < OK
0000172228 [ncp.at] TRACE: > AT+UCGED?
0000172234 [ncp.at] TRACE: < +UCGED: 2
0000172235 [ncp.at] TRACE: < 6,2,fff,fff
0000172236 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000172237 [ncp.at] TRACE: < OK
0000182537 [ncp.at] TRACE: < +CEREG: 5,"a1f9","0074cf01",7
0000182538 [ncp.client] TRACE: NCP connection state changed: 2
0000182539 [mux] INFO: Opening mux channel 2
0000183368 [net.pppncp] TRACE: NCP event 100
0000183369 [net.pppncp] TRACE: New auth info
0000183371 [net.pppncp] TRACE: NCP event 2
0000183372 [net.pppncp] TRACE: State changed event: 2
0000183373 [ncp.at] TRACE: > AT+CIMI
0000183373 [net.ppp.client] TRACE: PPP thread event LOWER_UP data=0
0000183374 [net.ppp.client] TRACE: State READY -> CONNECT
0000183374 [ncp.at] TRACE: < +CEREG: 0
0000183377 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000183475 [ncp.at] TRACE: < 234104099951971
0000183475 [ncp.at] TRACE: < OK
0000183476 [ncp.at] TRACE: > AT+CPOL?
0000183589 [ncp.at] TRACE: < OK
0000183590 [ncp.at] TRACE: > AT
0000183594 [ncp.at] TRACE: < OK
0000183594 [ncp.at] TRACE: > AT+CGATT?
0000183598 [ncp.at] TRACE: < +CGATT: 1
0000183599 [ncp.at] TRACE: < OK
0000184601 [ncp.at] TRACE: > AT
0000184604 [ncp.at] TRACE: < OK
0000184605 [ncp.at] TRACE: > AT+UPORTFWD=100,1
0000184608 [ncp.at] TRACE: < +UPORTFWD: 100,1
0000184609 [ncp.at] TRACE: < OK
0000184610 [ncp.at] TRACE: > ATD99**1#
0000364611 [ncp.client] ERROR: Failed to enter data mode
0000364612 [net.ppp.client] ERROR: Failed to dial
0000364613 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0000364612 [net.pppncp] TRACE: NCP event 3
0000364615 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000364616 [system.nm] TRACE: Interface 4 power state changed: POWERING_DOWN
0000364617 [ncp.client] TRACE: Powering off using AT command
0000364618 [ncp.at] TRACE: > AT+CPWROFF
0000364618 [ncp.at] TRACE: < +CEREG: 3
0000364715 [net.ppp.client] TRACE: State CONNECT -> CONNECTING
0000366952 [ncp.at] TRACE: < OK
0000366952 [ncp.client] TRACE: Waiting to be turned off
0000366992 [net.pppncp] TRACE: NCP event 3
0000366993 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000366993 [system.nm] TRACE: Interface 4 power state changed: DOWN
0000366994 [ncp.client] TRACE: 42 ms to power off the modem.
0000366995 [mux] INFO: Stopping GSM07.10 muxer
0000366995 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000366996 [mux] INFO: Closing all muxed channels
0000366997 [mux] INFO: Closing mux channel 1
0000366997 [mux] INFO: Closing mux channel 2
0000366998 [mux] INFO: Muxed channel 3 already closed
0000366998 [mux] INFO: Muxed channel 4 already closed
0000366999 [mux] INFO: GSM07.10 muxer thread exiting
0000367000 [ncp.client] TRACE: NCP connection state changed: 1
0000367000 [net.pppncp] TRACE: NCP event 2
0000367001 [net.pppncp] TRACE: State changed event: 1
0000367002 [mux] INFO: GSM07.10 muxer stopped
0000367002 [ncp.client] TRACE: Soft power off success
0000367003 [ncp.client] TRACE: Deinit UART
0000367004 [net.pppncp] ERROR: Failed to initialize cellular NCP client: -210
0000367004 [ncp.client] ERROR: Failed to enter data mode
0000367005 [net.ppp.client] ERROR: Failed to dial
0000367006 [net.ppp.client] TRACE: State CONNECTING -> CONNECT
0000367008 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000367009 [net.ppp.client] TRACE: State CONNECT -> DISCONNECT
0000367011 [net.ppp.client] TRACE: State DISCONNECT -> DISCONNECTING
0000367013 [net.ppp.client] TRACE: PPP thread event ERROR data=5
0000367014 [net.pppncp] ERROR: PPP error event data=5
0000367015 [net.ppp.client] TRACE: PPP thread event DOWN data=0
0000367015 [net.ppp.client] TRACE: State DISCONNECTING -> DISCONNECTED
0000367018 [net.ppp.client] TRACE: State DISCONNECTED -> READY
0000367105 [ncp.client] TRACE: Already off
0000367106 [ncp.client] TRACE: Soft power off success
0000367106 [ncp.client] TRACE: Deinit UART
0000367107 [ncp.client] TRACE: NCP connection state changed: 0
0000367108 [net.pppncp] TRACE: NCP event 2
0000367108 [net.pppncp] TRACE: State changed event: 0
0000367109 [ncp.client] TRACE: NCP state changed: 0
0000367109 [net.pppncp] TRACE: NCP event 1
0000367110 [ncp.client] TRACE: Powering on, ncpId: 0x47
0000367111 [net.pppncp] TRACE: NCP event 3
0000367111 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000367109 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000367112 [system.nm] TRACE: Interface 4 power state changed: POWERING_UP
0000368613 [net.pppncp] TRACE: NCP event 3
0000368614 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000368614 [system.nm] TRACE: Interface 4 power state changed: UP
0000368615 [ncp.client] TRACE: Powered on
0000369815 [ncp.at] TRACE: > AT
0000370170 [ncp.at] TRACE: < OK
0000370171 [ncp.client] TRACE: NCP ready to accept AT commands
0000370172 [ncp.at] TRACE: > AT
0000370174 [ncp.at] TRACE: < OK
0000370174 [ncp.at] TRACE: > ATI9
0000370177 [ncp.at] TRACE: < 03.15,A00.01
0000370178 [ncp.at] TRACE: < OK
0000370178 [ncp.client] TRACE: App firmware: 1
0000370179 [ncp.at] TRACE: > AT+UGPIOC?
0000370182 [ncp.at] TRACE: < +UGPIOC:
0000370182 [ncp.at] TRACE: < 16,255
0000370183 [ncp.at] TRACE: < 19,255
0000370184 [ncp.at] TRACE: < 23,0
0000370184 [ncp.at] TRACE: < 24,255
0000370185 [ncp.at] TRACE: < 25,255
0000370185 [ncp.at] TRACE: < 33,255
0000370186 [ncp.at] TRACE: < 42,255
0000370187 [ncp.at] TRACE: < 46,255
0000370187 [ncp.at] TRACE: < OK
0000370188 [ncp.at] TRACE: > AT+UGPIOR=23
0000370191 [ncp.at] TRACE: < +UGPIOR: 23,1
0000370192 [ncp.at] TRACE: < OK
0000370192 [ncp.client] INFO: Using internal SIM card
0000370193 [ncp.at] TRACE: > AT+CPIN?
0000370196 [ncp.at] TRACE: < ERROR
0000371196 [ncp.at] TRACE: > AT+CPIN?
0000371199 [ncp.at] TRACE: < +CPIN: READY
0000371200 [ncp.at] TRACE: < OK
0000371200 [ncp.at] TRACE: > AT+CCID
0000371426 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000371427 [ncp.at] TRACE: < OK
0000371427 [ncp.at] TRACE: > AT+IFC?
0000371430 [ncp.at] TRACE: < +IFC: 2,2
0000371430 [ncp.at] TRACE: < OK
0000371431 [ncp.at] TRACE: > AT+IFC=2,2
0000371434 [ncp.at] TRACE: < OK
0000371435 [ncp.at] TRACE: > AT
0000371437 [ncp.at] TRACE: < OK
0000371437 [ncp.at] TRACE: > AT+IPR=460800
0000371440 [ncp.at] TRACE: < OK
0000372440 [ncp.at] TRACE: > AT
0000372514 [ncp.at] TRACE: < OK
0000372515 [ncp.at] TRACE: > AT+CCID
0000372558 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000372559 [ncp.at] TRACE: < OK
0000372560 [ncp.at] TRACE: > AT+UMNOPROF?
0000372564 [ncp.at] TRACE: < +UMNOPROF: 90
0000372564 [ncp.at] TRACE: < OK
0000372565 [ncp.at] TRACE: > AT+UBANDMASK?
0000372569 [ncp.at] TRACE: < +UBANDMASK: 0,185473183,1048578
0000372570 [ncp.at] TRACE: < OK
0000372570 [ncp.at] TRACE: > AT+COPS=3,2
0000372573 [ncp.at] TRACE: < OK
0000372573 [ncp.at] TRACE: > AT+CGEREP=1,0
0000372576 [ncp.at] TRACE: < OK
0000372576 [ncp.at] TRACE: > AT+URAT?
0000372579 [ncp.at] TRACE: < +URAT: 7
0000372579 [ncp.at] TRACE: < OK
0000372580 [ncp.at] TRACE: > AT+CPSMS?
0000372584 [ncp.at] TRACE: < +CPSMS: 0,,,"00010011","00000011"
0000372584 [ncp.at] TRACE: < OK
0000372585 [ncp.at] TRACE: > AT+CEDRXS?
0000372589 [ncp.at] TRACE: < +CEDRXS: 4,"0000"
0000372589 [ncp.at] TRACE: < OK
0000372590 [ncp.at] TRACE: > AT+UPSV?
0000372593 [ncp.at] TRACE: < +UPSV: 0
0000372593 [ncp.at] TRACE: < OK
0000372594 [ncp.at] TRACE: > AT+UPSV=1
0000372597 [ncp.at] TRACE: < OK
0000372598 [ncp.at] TRACE: > AT+CMUX=0,0,,1509,,,,,
0000372601 [ncp.at] TRACE: < OK
0000372602 [mux] INFO: Starting GSM07.10 muxer
0000372603 [mux] INFO: Opening mux channel 0
0000372603 [mux] INFO: GSM07.10 muxer thread started
0000372607 [mux] INFO: Opening mux channel 1
0000372610 [ncp.at] TRACE: > AT
0000372614 [ncp.at] TRACE: < OK
0000372614 [ncp.client] TRACE: NCP state changed: 1
0000372615 [net.pppncp] TRACE: NCP event 1
0000372616 [net.ppp.client] TRACE: PPP thread event ADM_UP data=0
0000372619 [ncp.at] TRACE: > AT
0000372622 [ncp.at] TRACE: < OK
0000372623 [ncp.at] TRACE: > AT+CFUN?
0000372627 [ncp.at] TRACE: < +CFUN: 1,7
0000372627 [ncp.at] TRACE: < OK
0000372628 [ncp.at] TRACE: > AT+CCID
0000372652 [ncp.at] TRACE: < +CCID: 89883070000036162327
0000372652 [ncp.at] TRACE: < OK
0000372654 [ncp.at] TRACE: > AT+CGDCONT?
0000372658 [ncp.at] TRACE: < +CGDCONT: 1,"IP","super","0.0.0.0",0,0,0,2,0,0,0,0,0,0,0
0000372659 [ncp.at] TRACE: < OK
0000372660 [ncp.at] TRACE: > AT+CFUN?
0000372664 [ncp.at] TRACE: < +CFUN: 1,7
0000372664 [ncp.at] TRACE: < OK
0000372665 [ncp.at] TRACE: > AT+CEREG=2
0000372669 [ncp.at] TRACE: < OK
0000372669 [ncp.client] TRACE: NCP connection state changed: 1
0000372670 [net.pppncp] TRACE: NCP event 2
0000372670 [net.pppncp] TRACE: State changed event: 1
0000372671 [net.ppp.client] TRACE: PPP thread event LOWER_DOWN data=0
0000372672 [ncp.at] TRACE: > AT+COPS?
0000372676 [ncp.at] TRACE: < +COPS: 0
0000372677 [ncp.at] TRACE: < OK
0000372677 [ncp.at] TRACE: > AT+CEREG?
0000372681 [ncp.at] TRACE: < +CEREG: 2,0
0000372682 [ncp.at] TRACE: < OK
0000387782 [ncp.at] TRACE: > AT+CEREG?
0000387785 [ncp.at] TRACE: < +CEREG: 2,0
0000387786 [ncp.at] TRACE: < OK
0000387787 [ncp.at] TRACE: > AT+UCGED?
0000387793 [ncp.at] TRACE: < +UCGED: 2
0000387794 [ncp.at] TRACE: < 6,2,fff,fff
0000387794 [ncp.at] TRACE: < 65535,255,255,255,ffff,0000000,65535,00000000,ffff,ff,255,255,255,1,255,255,255,255,255,0,255,255,0
0000387795 [ncp.at] TRACE: < OK
0000402896 [ncp.at] TRAC0000432726 [ncp.at] TRACE: > AT+CIMI
