Asset Tracker instructions?
Just purchased the Asset Tracker kit. I’ve connected, but is there a set of instructions specifically for it? I can see things that apply in the projects area, but is there documentation for the kit itself?
The parts are electron, gps shield and a power shield.
I’m not certain how the power board is physically connected to the kit, if at all.
Does this help?
https://docs.particle.io/datasheets/particle-shields/#electron-asset-tracker
That should not be part of the Asset Tracker Kit :confused:
Or was this another order?
The Electron has all the power stuff on-board.
Got a photo of the Power Shield?
Oh. You’re right. I ordered it separately. Thanks
