Argon stuck in DFU no matter what I do
I have no idea what happened but shortly after setup, my Argon started blinking yellow. I looked it up and I assumed I was stuck in DFU mode. I’ve attempted flashing over terminal, did not work. I’ve attempted putting it into different modes, the light changed color for a moment but then returned to flashing yellow. Even tried re-setting it up on my phone but it didn’t work (though I did delete the device from my account…). At my wits end - can’t find anything describing this issue.
Sidenote: I’m very much a beginner with anything related to Terminal.
PLEASE HELP
This is something the hardly ever solves anything but often enough causes additional issues - so it's best to avoid that.
How did you do that exactly?
You can try
particle flash --usb tinker -v
particle update -v
Additionally to some possible issue with the current firmware state of your device another reason for that issue could be that your MODE/SETUP button got stuck in the connected state or you have something holding the MD pin low.
Hi @coco -
Welcome to the Forum :slight_smile:
@ScruffR gave you some good advice, let us know what whether you have been able to resolve the issue. If not, we will try to assist you further.
Regards,
Friedl.
When I do this, I get:
CarolinleelsMBP:~ Coco$ particle flash --usb tinker -v
dfu-util 0.9
Deducing device DFU version from functional descriptor length
ID 2b04:d00c
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x000d4000, size = 11972
Download [=========================] 100% 11972 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Flash success!
It's now flashing cyan!!
I did this a second time (I assume that's what you were indicating?) and I got this:
!!! I was unable to detect any devices in DFU mode...
Your device will blink yellow when in DFU mode.
If your device is not blinking yellow, please:
  1. Press and hold both the RESET/RST and MODE/SETUP buttons simultaneously.
  2. Release only the RESET/RST button while continuing to hold the MODE/SETUP button.
  3. Release the MODE/SETUP button once the device begins to blink yellow.
Error writing firmware: No DFU device found
VError: Error writing firmware: No DFU device found
at /Users/Coco/.particle/node_modules/particle-cli/dist/cmd/flash.js:208:13
at async CLI.runCommand (/Users/Coco/.particle/node_modules/particle-cli/dist/app/cli.js:160:7)
at async CLI.run (/Users/Coco/.particle/node_modules/particle-cli/dist/app/cli.js:190:14)
caused by: Error: No DFU device found
at ensureError (/Users/Coco/.particle/node_modules/particle-cli/dist/lib/utilities.js:427:14)
at /Users/Coco/.particle/node_modules/particle-cli/dist/cmd/flash.js:208:24
What should I do now that it's blinking cyan?
Yup, that was what I meant, to make sure that you actually have Tinker installed in case step 1 or 2 did fail to bring the device back to breathing cyan.
When it's breathing cyan you are set for whatever you want to do as this is the expected/default state.
Thank you so much for your help and for your fast replies! I put it into listening mode and set it up on my phone again.
