Argon stuck in dfu mode after sos+10
Hey all, got my argon stuck in SOS+10, after a lot of flashing attempts it appeared to be recovered. but now seems to be stuck in dfu mode. tried a lot of steps to no avail, when I tried particle doctor, I get this:
The Doctor didn't complete sucesfully. Error writing firmware: file does not exist and no known app found.
VError: Error writing firmware: file does not exist and no known app found.
    at Promise.resolve.then.then.then.then.then.then.catch.err (C:\Users\Kevin\AppData\Local\particle\node_modules\particle-cli\dist\cmd\flash.js:198:13)
    at <anonymous>
    at process._tickCallback (internal/process/next_tick.js:189:7)
caused by: Error: file does not exist and no known app found.
    at Promise.resolve.then.then.then (C:\Users\Kevin\AppData\Local\particle\node_modules\particle-cli\dist\cmd\flash.js:117:17)
    at <anonymous>
I’ll take any drastic steps you have to offer… tried to factory reset and that failed for me as well.
thanks for any help
Can you check if particle --version returns 1.41.0?
If so (or higher), you can try
particle flash --usb tinker -v
particle update -v
If not, run particle update-cli
thanks for the quick reply,
first tinker flash ran but put argon back in sos+10
back in dfu, particle update ran and left the argon in listen mode
back in dfu for final flash left argon in listen mode again.
hmm… when I bring up putty and type ‘c’, get Device claimed: no… guess I’ll work on reclaiming.
did a ‘w’ in listen mode, now breathing cyan… yay! so much easier with your help! thanks
OK, since I am on a roll, here are my current issues with the Argon:
  1. I got here in the first place trying to setup a debug session with particle programmer. it would be great if someone could publish a step by step procedure for getting this to work… I spent several days with the programmer shield and a photon… tried all kinds of things that didn’t work, suddenly it did work and I have no idea why. and I never was able to complete the debug session without crashing the photon sos+x.
this next one is just an annoyance… I recently started using the serial logger, but I am getting a ton of messages presumably from the firmware… they look like trace level messages, but they are set as INFO, any way to filter these out?
0000024994 [gsm0710muxer] INFO: Mux channel 2 already opened
0000027890 [net.ifapi] INFO: Netif wl3 link UP
0000027890 [system.nm] INFO: State changed: IFACE_UP -> IFACE_LINK_UP
0000028140 [hal] INFO: DNS server list changed
0000028141 [system.nm] INFO: State changed: IFACE_LINK_UP -> IP_CONFIGURED
0000028142 [system.nm] INFO: Checking gateway status with the device cloud
0000028143 [system] INFO: Cloud: connecting
0000028145 [system] INFO: Read Server Address = type:1,domain:$id.udp-mesh.particle.io
0000028146 [system] INFO: Loaded cloud server address and port from session data
0000028147 [system] INFO: Cloud socket=0, connecting to 34.237.176.160#5684
0000028149 [system] INFO: Cloud socket connected
0000028150 [system] INFO: Starting handshake: presense_announce=0
0000028150 [comm.protocol.handshake] INFO: Establish secure connection
0000028393 [comm.dtls] WARN: session has 0 uses
0000028399 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=0
0000028400 [comm.dtls] INFO: out_ctr 0,1,0,0,0,0,0,106, next_coap_id=4e
0000028401 [comm.dtls] INFO: app state crc: cached: d366bb72, actual: 465617de
0000028401 [comm.dtls] INFO: restored session from persisted session data. next_msg_id=78
0000028402 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 2
0000028403 [comm.protocol.handshake] INFO: Sending HELLO message
0000028642 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000028643 [comm.protocol.handshake] INFO: Handshake completed
0000028645 [system] INFO: Send spark/hardware/max_binary event
0000028647 [system] INFO: Send spark/device/last_reset event
0000028650 [system] INFO: Send subscriptions
0000028651 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000028652 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000028653 [comm] INFO: Sending TIME request
0000028692 [comm.protocol] INFO: Posting 'M' describe message
0000028694 [comm.protocol] INFO: rcv'd message type=1
0000028695 [system] INFO: Cloud connected
0000028696 [system.nm] INFO: Checking gateway status with the device cloud
IP: 192.168.0.137
0000028797 [comm] INFO: Forcing a cloud ping
0000028799 [comm.protocol] INFO: message id 80 complete with code 0.00
0000028800 [comm.protocol] INFO: rcv'd message type=13
0000028901 [comm.protocol] INFO: message id 81 complete with code 0.00
0000028901 [comm.protocol] INFO: rcv'd message type=13
0000029002 [comm.protocol] INFO: message id 82 complete with code 0.00
0000029002 [comm.protocol] INFO: rcv'd message type=13
0000029043 [vdots   ] INFO: WiFi Connected - SSID: KevZone2.4
0000029044 [vdots   ] INFO: waiting for Serial Connection
0000029103 [comm.protocol] INFO: message id 83 complete with code 0.00
0000029103 [comm.protocol] INFO: rcv'd message type=13
0000029204 [comm.protocol] INFO: message id 84 complete with code 0.00
0000029204 [comm.protocol] INFO: rcv'd message type=13
0000029305 [comm.protocol] INFO: message id 85 complete with code 0.00
0000029305 [comm.protocol] INFO: rcv'd message type=13
0000029406 [comm.protocol] INFO: message id 86 complete with code 2.05
0000029406 [comm.protocol] INFO: Received TIME response: 1559093845
0000029407 [comm.protocol] INFO: rcv'd message type=12
0000029508 [comm.protocol] INFO: message id 87 complete with code 0.00
0000029508 [comm.protocol] INFO: rcv'd message type=13
0000030046 [Msg     ] INFO: MsgPacket default Constructor
0000030047 [Msg     ] INFO: MsgIO constructor
0000030048 [LoopTmr ] INFO: loopTmr init
0000030595 [comm.protocol] INFO: Posting 'S' describe message
0000030601 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000031045 [LoopTmr ] INFO: loopTmr init
0000031144 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000031144 [comm.protocol] INFO: rcv'd message type=1
0000031248 [comm.protocol] INFO: Posting 'A' describe message
0000031251 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 4
0000031254 [comm.dtls] INFO: session cmd (CLS,DIS,MOV,LOD,SAV): 3
0000031257 [comm.protocol] INFO: rcv'd message type=1
I know this is off topic, just thought since I had your attention… :slight_smile:
Are you using Particle Workbench?
Or are you looking for something like this
https://docs.particle.io/support/particle-tools-faq/jtag/#installing-openocd-manually
You can filter the Log level
See here
https://docs.particle.io/reference/device-os/firmware/argon/#logging-levels
oops… yes, particle work bench
With Workbench you may want to read this (the forum search feature here does work :wink: but needs to be used too)
