the argon seems to crash after some hours. i cannot say yet how long it really takes.
this is the log.
0031480308 [wiring] TRACE: begin packet FF03::1:1001#36969
0031480311 [wiring] TRACE: sendPacket size 16, FF03::1:1001#36969
0031481315 [wiring] TRACE: begin packet FF03::1:1001#36969
0031481317 [wiring] TRACE: sendPacket size 16, FF03::1:1001#36969
0031481321 [hal] ERROR: Assertion failed: openthread/third_party/NordicSemiconductor/drivers/radio/nrf_802154_request_swi.c:57 assert_interrupt_status (nrf_is_nvic_irq_enabled(NRF_80~
FATAL: term closed
the setup consists of one argon and two xenons. all running 0.8.0-rc.27.
after the argon crashes the mesh network still continues to work (at least between the two xenons). but incoming particle cloud messages do not seem to be processed by the argon anymore. also, the “heartbeat blink” does not seem to be sent through mesh anymore (i.e. the mesh message from the argon is not recieved by any of the xenons).
i have to reset the argon.
the xenons run a simple app that checks a button. if pressed the xenon will publish a message through mesh. if any xenon recieves such a message it will blick an led.
there is another photon with a button that will send a cloud message when pressed.
when the argon recieves such a cloud message it will send a mesh message and the xenons will blink.
this works for some time (i assume at least an hour). when pressing the button on the photon the two xenons will blink. when pressing the button on any xenon the other xenon will blink. that’s all basically fine.
the following is the test app.
SerialLogHandler logHandler(LOG_LEVEL_ALL);
void particlePublishHandler(char const *event, char const *data) {
if (strcmp(event, "button") == 0) {
Mesh.publish("button", "hit");
pinMode(D7, OUTPUT);
digitalWrite(D7, 0);
Particle.subscribe("button", particlePublishHandler);
Mesh.publish("heartbeat", "tick");
delay(1000);
digitalWrite(D7, !digitalRead(D7));
