Android App - Particle Setup Problems
Also, could you elaborate a bit further on the issues you're seeing regarding the CLI? I'm sure @nexxy would be interested in hearing those.
You can also use a serial terminal to configure wifi credentials if needed, might be a decent alternative?
I see you've already done so :wink:
