See subject. App can see Photon by its SSID but attempting to connect times out - sometimes with error “Please try running setup again after resetting your Photon and putting it back into…”. Photon blinks blue as it should. Tried a few power cycles, resets, holding setup button, etc - no help at all.
…and the CLI process is zero help…
OBVIOUSLY I have internet connection - I am typing this on the same machine that Particle CLI told me I don’t have a connection on…
on 5th attempt (without changing anything in between, just restarting powershell and starting over), the CLI setup worked…
