3d printed particle photon case?
Hi
Has anybody printed a particle photon 3d case? I have seen several models in thingiverse, but none of them fits what i want, as those are totally closed cases.
I have a dht22 sensor and a pms5003 sensor, so i need some space to hold the sensor (i think it needs to be out of the case to read properly the temperature) and also for the wiring for the pms sensor
Any suggestions on how could i do this?
Hi Javi-
Would this work for you? I haven’t printed it myself but it looks like it fits your criteria.
Yeah, I saw that. If I don’t put the cover it gets dusty (that’s why I wanted the case) and if I put the cover, the temp readings will be higher ;(
