Workbench waiting for DFU mode to long.
I am creating a Photon project in Workbench. Doing a local flash. When I do my cmd-shift-b then return, the system first
puts the Photon in DFU mode. Sometimes it does this immediately then goes along and compiles, etc. PERFECT.
But about 40% of the other time, it waits and waits for the board to go into DFU mode. It finally gets a high-level JavaScript error
(several lines printed out in red), times out, then finally starts compiling, continues along and works fine.
TimeoutError [VError]
at RequestSender.delay (/Users/markolmstead/.particle/node_modules/particle-cli/node_modules/particle-usb/lib/device.js:106:13)
at /Users/markolmstead/.particle/node_modules/particle-cli/node_modules/particle-usb/lib/device.js:212:17
at async Promise.all (index 0)
at async CLI.runCommand (/Users/markolmstead/.particle/node_modules/particle-cli/dist/app/cli.js:160:7)
at async CLI.run (/Users/markolmstead/.particle/node_modules/particle-cli/dist/app/cli.js:190:14) {
jse_shortmsg: ‘’,
jse_info: {},
message: ‘’
It seems it gets buggered up when the board tries to detect DFU mode. It puts it in DFU mode ALWAYS, just does not detect this.
Its blinking yellow just fine! Has anyone seen this? Is there a work around or something for this?
