Particle Workbench hosed my Photon
Tried to use Particle Workbench to flash my Photon. The laptop crashed halfway through. Now, when using Webbuild, to try to flash it, I get a message that says modules needed to flash are not on the device.
Any ideas on how to fix it, or is time to shell out another $29.00?
Try to go to safe mode then flash with Tinker then flash with your app
Thanks for the suggestion.
I tried that. It didn’t work.
(Edit: realized it sounded harsh)
Would be good to get a more specific problem description.
What does the Photon do?
What does particle serial inspect (in Listening Mode) tell you about the device?
Have you tried particle update -v (in DFU Mode)?
BTW, the topic title does come across click-baity. Your Laptop crashing probably was the reason, that Workbench caused that crash is not that likely tho’
The laptop crashing is undoubtedly what caused the problem, but I think it crashed because of Workbench. I wish I had stayed with Webbuild, but it's file management sucks.
I tried running Particle Doctor and got the following response.
Your device is ready for a system update.
This process should take about 30 seconds. Here it goes!
! An error occurred while attempting to update the system firmware of your device:
File too short for DFU suffix
Error during download get_status
Please visit our community forums for help with this error:
https://community.particle.io/
The Doctor didn't complete successfully. Cannot read property 'code' of undefined
I hope it's not totally fried.
Try this out. I used search feature :slight_smile:
Thanks dreamER. You fixed my problem.
