Not able to use Particle Photon after putting a debug firmware
I used Particle Workbench to put a firmware and unknowingly put a debug firmware in a Particle Photon.
Now to recover the Photon, I used the Particle CLI and programmed the tinker firmware using “particle flash --usb tinker” command which went successful but now I am not able to use the online IDE to update the firmware and says “Device is running debug firmware which does not support OTA. Reflash Device OS using Workbench or CLI (particle update)”. Also, the Photon takes a lot of time to connect to WiFi and doesn’t go to OTA update mode.
Please help me to get back to a state where I can enable the OTA update mode.
Rahul
Have you tried this suggestion?
Put the device in DFU Mode (just as you did to flash Tinker) and run particle update -v (that -v is optional for verbose output, but I prefer seeing what's going on, so I usually add it).
It didn't help and I was getting this error "
ID 2b04:d006
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCT Flash "
Downloading to address = 0x000006d9, size = 1
Download [ ] 0% 0 bytesFile too short for DFU suffix
Cannot open DFU device 2b04:d006
Error during download get_status
! An error occurred while attempting to update the system firmware of your device:
But then when I searched I found a post:
Here I was getting the same issue but used
this which solved the issue.
Thanks for your help!
