I saw in the release notes for 5.8.0, there may have been a fix for wifi scanning sometimes not returning results,
Specifically in #2752 there is a link to a Shortcut story mentioning wifi scan failure.
I cant view that of course but it may be related to my issue. Was that included in 5.8.0 or is it a related ongoing issue? I have my P2 on 5.8.0, but I still sometimes have issues that so far require a power cycle or multiple WiFi.scan() calls to have a chance at resolving.
I'm generally doing a wifi scan while connected to a device in provisioning mode through a controlr request. Sometimes when that fails by returning 0 networks, I'm still able to call a cloud function that scans for wifi networks with a callback. Though sometimes that fails too. This seems to happen more often while in the office where there are >25 SSIDs present but that may be unrelated.
If it fails after a BLE control request, it does so pretty quickly. Usually scanning blocks for about ~5 seconds, but if it returns 0 networks it will do so in ~200 ms.
0003494996 [wiring.ble] TRACE: Connected
0003495060 [system.ctrl.ble] TRACE: Connected
0003495104 [app] INFO: BLE Event detected: ble_prov_mode_connected
0003503668 [system.ctrl.ble] TRACE: Handshake done
0003503715 [app] INFO: BLE Event detected: ble_prov_mode_handshake_done
0003503819 [system.ctrl.ble] TRACE: Received a request message; type: 20, ID: 35465
0003504043 [system.ctrl.ble] TRACE: Enqueued a reply message for sending; ID: 35465
0003504225 [system.ctrl.ble] TRACE: Received a request message; type: 506, ID: 35466
0003504418 [system.ctrl.ble] TRACE: Enqueued a reply message for sending; ID: 35466
^ The above scan from the control request only took ~200 ms to return 0 results ^
0003531920 [app] INFO: result_count=0
^ The above scan from WiFi.scan() also returned 0 results ^
0003544895 [app] INFO: ssid= security=1 channel=48 rssi=-73
0003544899 [app] INFO: ssid=MFH security=3 channel=48 rssi=-73
0003544902 [app] INFO: ssid=InnoVets security=3 channel=48 rssi=-73
0003544906 [app] INFO: ssid=ECE Guest security=3 channel=48 rssi=-73
0003544911 [app] INFO: ssid= security=3 channel=48 rssi=-73
0003544914 [app] INFO: ssid=MassRobotics security=3 channel=120 rssi=-74
0003544918 [app] INFO: ssid=RasLabs-5G security=3 channel=153 rssi=-77
0003544921 [app] INFO: ssid=InnoVets security=3 channel=44 rssi=-79
0003544926 [app] INFO: ssid=MFH security=3 channel=44 rssi=-79
0003544930 [app] INFO: ssid=ECE Guest security=3 channel=44 rssi=-80
0003544933 [app] INFO: ssid= security=3 channel=44 rssi=-80
0003544937 [app] INFO: ssid= security=1 channel=44 rssi=-80
0003544941 [app] INFO: ssid=MassRobotics security=3 channel=64 rssi=-80
0003544945 [app] INFO: ssid= security=1 channel=44 rssi=-86
0003544948 [app] INFO: ssid=InnoVets security=3 channel=44 rssi=-86
0003544953 [app] INFO: ssid= security=3 channel=44 rssi=-87
0003544957 [app] INFO: ssid=MFH security=3 channel=44 rssi=-88
0003544960 [app] INFO: ssid=ECE Guest security=3 channel=44 rssi=-89
0003544964 [app] INFO: ssid= security=3 channel=44 rssi=-90
0003544968 [app] INFO: ssid= security=3 channel=36 rssi=-91
0003544971 [app] INFO: ssid=MFH security=3 channel=1 rssi=-92
0003544974 [app] INFO: ssid=ECE Guest security=3 channel=1 rssi=-93
0003544978 [app] INFO: ssid= security=3 channel=1 rssi=-93
0003544982 [app] INFO: ssid=RasLabs security=3 channel=5 rssi=-99
0003544986 [app] INFO: ssid=ECE Guest security=3 channel=6 rssi=-99
0003544989 [app] INFO: ssid=MFH security=3 channel=11 rssi=-110
0003544994 [app] INFO: result_count=26
^ Retrying with a WiFi.scan() took ~5 seconds and returned many results ^
0003545006 [app] INFO: LOOP TOOK A WHILE: top->top[4513] end->top[4513]
Has anyone else had issues with scanning for wifi networks on P2?
