Can not scan SSID
Case 1: I try to scan wifi after close hotspot because I would like to simulate lost connection. Then led on photon turns to blinking orange.And when I try scanning again.SSID is returning empty and stop working while scanning.
Case 2: Same as the case 1, but this time I’m not connect a photon with cloud. Everything can work fine and can scan SSID.
Have you tried tearing down cloud (Particle.disconnect()) and WiFi (WiFi.disconnect()) connection once you encounter the loss of connectivity?
Thanks you so much for your support. It can work. :grin:
