Hi guys,
I want to sniff all packets that goes through wi-fi, regardless of their nature. For instance, I want to know how many people are forgetting their wi-fi on while in a plane. How can I approach that?
I have found that somehow I may call wwd_wifi_enable_monitor_mode and set a callback routine, but I’m not sure how I can access directly this call from the application. In addition, this will prevent me for having other TCP connections during monitor mode, which is not ideal.
Another way I think is to somehow hook into the host_network_process_ethernet_data and just sniff all the incoming packets without hurting the network stack. This would be actually the ideal road to go.
Does anybody know how can I achieve this? It seems to me that I may need to rebuild the WICED (which I would prefer not to). What would be the consequences of doing that?
Cezane.
