gidi
1
Hi everyone,
I’m trying to set up a Wi-Fi Access Point on my Particle Tachyon using hostapd
with the built-in wlan0
interface.
Steps I took:
Installed hostapd
and dnsmasq
Configured /etc/hostapd/hostapd.conf
with SSID, password, and 2.4 GHz channel.
Started hostapd
manually. Terminal shows:
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
wlan0: AP-CSA-FINISHED freq=2437 dfs=0
Problem: the SSID does not appear on any devices. Running iw list
gives no output, so I can’t check supported modes.
Questions:
Does the built-in wlan0
support Access Point mode?
If yes, are there additional steps or drivers to make the SSID visible?
If not, what’s the recommended way to provide a Wi-Fi hotspot from the Tachyon?
Thanks in advance for any advice!
Hey, not sure about what interface does support AP, but @mrlambchop has mentioned many many times he’s been running his Tachyon as an AP on the road.
ThomasK
3
Hi there,
maybe take a look at my script as well
All the best
Thomas
