Which P1 Spare pin define is correct?
Hi Everyone
I’m try to compile firmware for P1, I can use P1S0 to P1S6 in the firmware without compile error,
So which of those 7 pins (P1S0 to P!S6) corespondent to the 6 spare Pins on P1, any help is much appreciated!
Edward
Have you checked the data sheet?
https://docs.particle.io/datasheets/p1-datasheet/#pin-out-diagrams
