I’m trying to read through the spec sheet on the p1 and it says that it has 24 GPIO. When I look at the Pinout Diagrams I see 3 diagrams. How am I to read which of these pins are the 24 GPIO’s that I will be able to use?
@incorvia, did you see this?
https://docs.particle.io/datasheets/p1-datasheet/#pin-description
@peekay123 thanks for that resource. So it appears, according to that resource that the following can be used as digital GPIO
D0-D7 (8)
A0-A7 (8)
DAC (1)
RX (1)
TX (1)
P1S0-P1S(6)
That’s 25 but the sheet I referenced says 24 GPIO… am I off by one?
DAC and A6 are the same pin, so I think you counted that twice.
Thanks everyone got it!
