Where is the Adafruit_BME280 library?
a few minutes ago I started with a new sketch in the online IDE. I tried to add the Adafruit BME280 library but it seems to be deleted.
But I can definitely say that it was available some time ago, because it is included in one of my other sketches. Is this just a temporary error?
Kind regards,
Tom
I can still see it
https://build.particle.io/libs/56141b8cf351300a350005eb
Thank you very much for your link @ScruffR I was able to add it this way.
But I am still not able to find it through the library search function. That’s really suspicious :slight_smile:
Try the REFRESH LIBRARIES button.
Also check out this page, it tells about the reason too
http://status.particle.io/
The refresh button did not change anything at the moment but I am sure the issue will be solved soon :smile:
thanks for the link, I have added it to my bookmarks.
