Hi there,
i’m new to particle and I have a problem with the inclusion of a library.
I connected my RaspberryPi Zero W to particle and I want to read the BMP180 sensor.
Into Particle Dev (on Windows) i create a new project and I included the library “Adafruit_BMP085” from Particle library panel. I copied the library into my project.
To include the library i used "#include “Adafruit_BMP085.h”.
When I compile I receive the error “…/Adafruit_BMP085.h: No such file or directory”.
I also try to include: "#include “Adafruit_BMP085/Adafruit_BMP085.h” but nothing change.
If i use the web compiler everything work and I can read the temperature.
Where I’m wrong during the library inclusion?
Thanks for the help!
