When will Device OS 6.3.0 be available in Workbench?
Hey Particle Team,
I saw that Device OS 6.3.0 was released earlier today (congrats on the new update!), and I noticed that it’s already available in the Web IDE and CLI. However, I don’t see it listed yet in Particle Workbench.
Do you have an ETA on when it will be available there? I’d like to start testing with it in my development environment.
Workbench releases typically come out a day or two after the Device OS release.
I just restarted Workbench and still no v6.3.0?
Is there a means to force an update??
Thx in advance
Make sure you've enabled pre-release versions otherwise 6.3.0 won't appear.
Thanks for that hint @rickkas7
Does this mean that v6.3.0 is not released as mentioned above?
It is released, but it's a pre-release version, as opposed to GA.
This basically means it's not intended to be released to production fleets, but should be tested with.
Hoping this release mitigates the Photon2 connectivity issues experienced... we have a couple pilot devices on a Starlink site that have experienced inexplicable cloud connection losses (both LAN and WAN based).
