Particle:Install Local Compiler Toolchain is not showing 5.6.0.
Can I pull the new version or is this something that hasn't been done yet?
Hi Will, this usually takes a day or so. I'll keep an eye on the Slack channel for a sign that the Workbench package is live.
Over keen to try out the Ethernet fixes!! Maybe tomorrow.
Setting "particle.firmwareVersion": "5.6.0" in settings.json seemed to work for me, now when I inspect my device it shows as being on 5.6.0.
System module #1 - version 5600, main location, 1572864 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
Bootloader module #0 - version 2400
Should be out by EOD
James
I don't see how that would work.
If I tried that it would tell me that it was an unrecognised configuration for P2. The toolchain isn't available yet?
What is that in UTC?
¯_(ツ)_/¯
Who knows maybe particle serial inspect is gaslighting me
All good now
