What is the correct way to handle libraries?
I had a Grove Temperature and Humidity Sensor V2.0 (DHT20) and I ran into an old topic from 2022 in this Particle Community adressing the Library needed for this device (<DHT20 (replacement for DHT22) Library>). The topic ended with a solution as proposed by ScruffR to copy an app to Particle Web IDE from the shared apps in: Particle Web IDE
Which I did and that worked fine.
However: that copied app is now on my Web IDE under the very same name as it was in the shared apps (in this particular case: DHT_I2C)
Now if I want to use this DHT_I2C app as a part of another app, I follow that same procedure, resulting in several different apps in my Web IDE however with the very same name.
That should of course not be the case. What did I do wrong?
There is no good way to do this from the WebIDE, which is one of the many reasons you should use Particle Workbench instead.
There is no way to rename a project, so the only solution is to create a project from scratch with the same source files and same libraries as the original, manually.
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
