DHT20 (replacement for DHT22) Library
Hi All,
Can anyone point me in the right direction to get this sensor working with a photon?
I see there are arduino libraries, but nothing in build.Particle.io.
I’ve never ported a library, so I am unsure how to proceed.
Have you tried any of the Arduino libraries?
With I2C libraries there often is virtually no more porting effort required than adding a #include <Particle.h> at the top of the library’s header file.
Here is a stripped down version of the Adafruit library (legacy support removed)
Thanks @ScruffR, I’ll give that a try.
J
@ScruffR Yes, that worked! Thanks.
