I’m trying to use the Grove SHT35 high accuracy temperature and humidity sensor with my particle boron using the particle build IDE and there doesn’t seem to be a library that I can use from their libraries. There is a library on GitHub but I can’t figure out how to import it. Any help would be greatly appreciated. Thank you.
Posting a link to the library you found could be helpful
You can use this library
