I need to have a trigger. I have to hook the particle up to a buzzer and a button.
int buttonPin = D2;
int buzzerPin = D3;
pinMode(buttonPin, INPUT);
pinMode(buzzerPin, OUTPUT);
particle.function("buzz", buzzerOn);
particle.function("silent", buzzerOff);
particle.publish
//digitalRead(buttonPin);
Wellcome to the community
However, as a first time poster politely asking a question for help rather than merely stating your need would show some courtesy to the community you hope to get help from.
One important step in here is
https://community.particle.io/t/welcome-using-particle-forums-and-forum-etiquette
Also the docs do help - look and use the search feature there first
https://docs.particle.io/tutorials/integrations/ifttt/
Not much of an answer …but there are Particle IFTT Nodes and you just set up a particle Publish and and a particle subscribe and enter the info into the IFTT node along with your information it should work
