Hello everyone! I just got my Boron 2G/3G board connected to the particle cloud and am able to send events. However, I am now having issues trying to connect to Ubidots with a Particle Webhook. I configured the webhook according to Ubidots tutorial, as shown below:
I am getting the following error message:
Hello Michael!
Seems like an issue with the URL:
You would not need to replace the string PARTICLE_DEVICE_ID by your particular device id like you did, you just leave the string there and the webhook will do the replacement on the fly:
Please try and let me know.
Gustavo.
Yeah, replacing the device ID with the PARTICLE_DEVICE_ID resolved that error. I also discovered that I was using the API Key instead of the token. Using the token resolved my issue completely.
Thank you for the assistance.
@gusgonnet Do you also have experience subscribing to Ubidots events? I am now trying to do this example: 5. Create Ubidots Webhook to Particle to Control Things.
Ubidots is registering the events when I toggle the digital switch however Particle is not receiving. Do you have any suggestions?
Hi, I do and maybe other people around the forum do also.
I’d suggest you post the question, in a new topic could be better since this one is already solved.
Gustavo.
