Guys I am using a project and it is working perfectly fine, except that I am using pushbullet to send notification to my mobile. Beside using pushbullet I also want to use TWILLIO or anyother sms based service to send sms notification when water level is low in my tank. This i need because the guy who supply water to my house is not using smart phone and sms is the only way forward.
I´m using an cheap Ultrasonic Sensor - HC-SR04 to detect water level in this project and use IFTTT-Services in combination with Particle Publish to trigger an alarm via E-Mail, SMS and so on.
I am using another code to sensor water level in my water tank. As soon as the water level goes down to a certain level… I receive a pushbutton message. I also wanted to integrate SMS function so that I also receive SMS when I do not have wifi. I am not a programmer so plz help me integrate this function.
#include <elapsedMillis.h>
#include "elapsedMillis/elapsedMillis.h"
String _version = "0.04";
//this reads the flood sensor every 2 seconds
#define FLOOD_READ_INTERVAL 2000
//this defines the frequency of the notifications sent to the user
#define FLOOD_FIRST_ALARM 10000 //10 seconds
#define FLOOD_SECOND_ALARM 60000 //1 minute
#define FLOOD_THIRD_ALARM 300000 //5 minutes
#define FLOOD_FOURTH_ALARM 900000 //15 minutes
#define FLOOD_FIFTH_ALARM 3600000 //1 hour
#define FLOOD_SIXTH_ALARM 14400000 //4 hours - and every 4 hours ever after, until the situation is rectified (ie no more water is detected)
#define FLOOD_NOTIF "FLOOD"
elapsedMillis flood_timer;
elapsedMillis flood_alarm_timer;
int flood_alarms_array[6]={FLOOD_FIRST_ALARM, FLOOD_SECOND_ALARM, FLOOD_THIRD_ALARM, FLOOD_FOURTH_ALARM, FLOOD_FIFTH_ALARM, FLOOD_SIXTH_ALARM};
int flood_alarm_index = 0;
bool flood_detected = false;
unsigned long flood_next_alarm = 0;
int FLOOD_SENSOR = D0;
int LED = D7;
pinMode(FLOOD_SENSOR, INPUT_PULLUP);
pinMode(LED, OUTPUT);
Spark.publish("device starting", "Firmware version: " + _version, 60, PRIVATE);
flood_check();
if ( flood_detected ) {
flood_notify_user();
* Function Name : flood_check
* Description : check water leak sensor at FLOOD_READ_INTERVAL, turns on led on D7 and raises alarm if water is detected
* Return : 0
int flood_check()
if (flood_timer < FLOOD_READ_INTERVAL) {
return 0;
//time is up, so reset timer
flood_timer = 0;
if (digitalRead(FLOOD_SENSOR)) {
//if flood is already detected, no need to do anything, since an alarm will be fired
if (flood_detected){
return 0;
flood_detected = true;
//reset alarm timer
flood_alarm_timer = 0;
//set next alarm
flood_next_alarm = flood_alarms_array[0];
digitalWrite(LED,HIGH);
} else {
digitalWrite(LED,LOW);
return 0;
* Function Name : flood_notify_user
* Description : will fire notifications to user at scheduled intervals
* Return : 0
int flood_notify_user()
if (flood_alarm_timer < flood_next_alarm) {
return 0;
//set next alarm or just keep current one if there are no more alarms to set
if (flood_alarm_index < arraySize(flood_alarms_array)-1) {
flood_alarm_index = flood_alarm_index + 1;
flood_next_alarm = flood_alarms_array[flood_alarm_index];
//send an alarm to user (this one goes to the dashboard)
Spark.publish(FLOOD_NOTIF, "Underground tank need water!", 60, PRIVATE);
//send an alarm to user (this one goes to pushbullet servers)
Spark.publish("pushbullet", "Attention!..Water tank empty. Call water service!", 60, PRIVATE);
return 0;
@somairm
Well, it's been a long time since I came up with my code and I'm not much of a programmer either but basically you go to Twilio (or someone similar), set up an account, get your Account id, set up your webhook similar to mine above, then just publish a message to trigger the specific webhook (by it's name which is the eventName) that sends the SMS.
I did find it difficult to read your code due to formatting issues, and make sure your publish function conforms to that given in the docs and the data is sent by the webhook:
// SYNTAX
Particle.publish(const char *eventName, const char *data, int ttl, PRIVATE);
Particle.publish(String eventName, String data, int ttl, PRIVATE);
I managed to send sms via Twilio. Now I am working on IFTTT coz it is free. I manage to create a new applet using IF ( partcle) and this as (SMS) but did not receive sms yet.
