Video Series: Particle.io Photon High School Robotics
Finally got around to making a few videos (hoping for about 18 videos when it is done to cover my High School Robotics course). The youtube video link is at:
Rocksetta Playlist at
The Github site that follows the videos is at:
Working on improving the quality of these videos.
##The following videos are finished:
###Click on these direct links
a00-intro An introduction to teaching robotics using the particle.io photon. Shows several student examples from June 2017.
a01-console Got ta love the console.
a02-voltage-divider Measuring 2 prong sensors
a03-DAC-to-ADC Using the DAC pins (A6, A3) to test the Analog read pins (A0 --> A5)
a04-SOS-programming A tiny bit of programming, more to build confidence than anything else.
a05-tinker speaks for itself
a06-web-app My flagship Photon and Raspberry Pi3 controlling web page, view it live at https://hpssjellis.github.io/particle.io-photon-high-school-robotics/ Plug in your Photon ID and Access token and activate your D7 LED now.
a07-mobile-App Convert a web page into a mobile app using Phonegap Build
a08-ifttt Control anything onthe internet with your Photon
a09-servo Operating a servo motor using an external power source, without destroying the photon.
a10-transistor Showing how to use a transistor to protect the photon from slightly higher amps and volts
a11-DC-motor-drivers using the Pololu Big motor driver To 24V Max and 12 Amp Max and the dual motor driver to 13.5 V max and 1.2 Amp Max
a12-stepper-motor-driver using the Pololu stepper and driver
a13-arduino using the photon to make a non-wifi Arduino
a14-serial-I2C using the Groove OLED
a15-serial-SPI using the amazing Pixy camera.
a16-serial-uART using a finger print scanner
Advanced: Using the Raspberry Pi3 on the Particle.io Cloud IDE and being able to control it using my web app.
Advanced: Web Sockets Is the Particle Cloud 1200 ms delay to slow for you? Try this using your own nodejs server to get a 10 ms delay
my IOT Rant Written in 2015 when I switched from just coding to robotics (I new very little about electronics)
##The videos are at:
Just Google search for particle.io photon high school robotics
or copy
https://www.youtube.com/playlist?list=PL57Dnr1H_egsL0r4RXPA4PY2yZhOJk5Nr
##The Github site is at:
github.com/hpssjellis/particle.io-photon-high-school-robotics
Thank you so much for sharing this all!
No problem @KyleG making the videos helps me remember how to teach the stuff. Just finishing the introduction tonight.
Thanks for the likes.
The a00 intro is at https://youtu.be/bOPonnhGOUg?list=PL57Dnr1H_egsL0r4RXPA4PY2yZhOJk5Nr
It has several student examples:
Wifi OpenRC Formula 1
Wifi cell phone 2 axis holder
Wifi Mouse Trap
Wifi Hand and Glove
GPS and Acceleration tracker
Wifi RFID Tag Notifications
(Looks like in this image the photon has been removed)
Wifi Baby Duck
Wifi Racoon Motion Dector and Notifications
